Question about Refrigerators
GE TFX26PPDA side by side refrigerator.the plastic lines going to the ice and water connections on the back of the appliance are missing. i have the new lines but can not find a diagram for hooking the lines up to the right connections. brian
  • 4,070 Answers
This diagram shows a few part that may help. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=228822&diagram_id=21247529#d21247529
The Ice maker line goes up the right side of the back an connects to the fill tube which is covered by a cover going into the rear wall to the ice maker. The line to the water dispenser goes to the left into the back of the fridge to the water chiller reservoir and then under the floor to the freezer door bottom hinge. The water inlet valve has one connector on one side for the water supply from the floor or wall. It has two connectors on the other side. The right side usually goes to the ice maker. (looking from the back of the freezer). You can check this out by depressing the water dispenser switch and seeing which side of the valve works. You probably have the quick connect valves. You make sure you have a smooth cut on the end of the line and push it into the valve.
Posted on Feb 08, 2010
Door dispenser not working
Is the ice maker working properly? There is a water filter in the refrigerator through which both the ice maker and water dispenser are supplied and over time it will slow down the flow and eventually block. Have you changed it recently? Often, ice cubes will get smaller as it blocks and the ice maker will also quit.
Also, have you checked the water supply line that goes to the ice maker and water dispenser? It should be a small diameter copper or plastic line that connects to the back of the refrigerator.
Ed
Jan 08, 2014 | GE GSH25JSTSS Stainless Steel Side by Side...
Water & Ice Maker installation schematics. Need diagram of back of refrigerator
You need to get the model number... look up the DUAL water valves (which seem to be missing) and hook up the water & ice RESPECTIVELY
Watch those supplier videos...
Those new press connectors are a snap to
use (and release)...
appliancepartspros
Search Over 2 1 Million Appliance Parts
partselect
PartSelect Appliance Parts and Repair Help
repairclinic
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
kit LIKE THIS... (can't tell w/o model number)
Amazon com 2181730 Quality Replacement Dual Water Valve Kit for...
Carnac the Magnificent
May 21, 2017 | Amana Refrigerators
Water is leaking down the side and back of the freezer from the ice maker. I have the GE CAN9 ice maker. Were is the ice maker water valve located ?
Bottom right in back of ref.<br /> Its what the water line from the wall attaches to.<br /> <br /> <br /> If this was helpful please rate me.<br />IMUFO2<br />Leo Ponder Appliance-Tyler,Texas<br /><a href="mailto:imufo2@sbcglobal.net">imufo2@sbcglobal.net</a> <br />
Aug 30, 2010 | GE Profile PSW26P Stainless Steel Side by...
Hi there, We are having problems with our ice maker on our GE Profile Model # SRD2054W, purchased October 1995. I know it's old, but it has been a good appliance until now. The ice maker fills but the...
What you think is probably correct. Water valves can seep water and freeze the fill tube. Remove the ice maker and the fill tube remove ice from the fill tube and replace the water valve.
Apr 16, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Ice isn't working and water isn't working..what could be the problem?? thanks ya'll. its a ge side by side too..gonna guess maybe 10yrs old..
Probably there is not water going to your side by side reffrigerator.Pull out the refrigerator and you'll see awater supply line (copper or plastic)that is connected to a valve in the wall or under the kitchen sink,check if the valve is off or if the line is kinked or broken.
Apr 07, 2009 | GE GSL25JFPBS Side by Side Refrigerator
GE GSS25SGRE side by side water dispenser...
The same thing happened to me. If you pull the refrigerator out and remove the large silver panel, you will see the water lines on the left. The line going to the ice maker was fine, but the line going to the water dispenser was split. You may have the same issue.
Jan 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leak From Back Of Fridge
hi that small hose is going in to the ice maker. buy a small clamp at the hardware store, and clamp the plastic hose holder. thanks the appliance doc
Oct 16, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
GE Profile side by side no water
trace the water lines, from the sink, to the filter and to the solenoids going to the tank and ice maker. you may need to purge the air inside the water lines.
tnx 4 using fixya,
drcool
Oct 11, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE side by side leaks water onto floor, no ice
There is a pipe that runs up the back of the appliance and feeds the ice maker , if this freezes inside then it canpush the fitting off the back of the appliance and cause water to go everywhere. Usual problem is a leaky watervalve causeing water to drip into the pipe which freezes and builds up until it is totally blocked.
Aug 16, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
296 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
