Picture goes black after awhile. front led goes out too. sound ok unplug for an hour, and set works and pict ok again for awhile
  • 2 more comments
  • Frank Feb 08, 2010
    Which capacitor? I've replaced several. Circuit id or location would help
  • Frank Feb 09, 2010
    It is a samsung LNT 4032HX
    I know you mean well, but I HAVE been in the electronics business for 20+ years, and know about CLEARLY visable "puffed" capacitors, and the ease of just changing the whole board. What I was after is a more pointed, recurrent problem that may have existed in this unit. As you know, there are often problems of this nature, and it can save hours of exploration if you can "pick" the brains of someone "smarter" than your self on a certain issue. YOU choose to answer my inquiry, but NONE of what you have said is any further than I was prior to posting my problem. Maybe you are just too used to end users posting problems.
    Thank's for you effort though..............Frank
    Picture on an lcd Samsung tv goes out after on for awhile. Screen goes completely black. Sound is ok. Remote functions work fine. After unpluging set for a half hour, works normaly again for a short time. I have no schematics on this set, and am not sure if it's a backlight inverter problem or not. I would like to deal with a likely component problem, rather than "hit and miss" board changing.
  • 5,807 Answers
a ) Most likely power supply circuits, or a failed communication on the
circuits board.
b ) Possible causes can be from a resistor , to the low voltage
regulators on the SMPS ,
could also be from the feedback circuits
either in the horizontal deflection circuits ( if CRT type ) or " Power
Supply Unit " for the lamp if it is LCD , Plasma or LED type.
c ) Troubleshooting the unit , requires checking out the output
voltages of the power supply and check for possible bad capacitor .
d ) There are also instances that communication to the " Modules "
are failing thus triggering protection circuits or are activated.
e ) If you feel can work on the circuits , indicate the Model, Brand.
chassis number ( if available ) and the things you have done to
remedy the cause.
f ) It can also be caused by a cracked solder joints on the circuit Board,
around the flyback area ( if CRT type )
g ) Those are just possibilities there could be other causes , but try
those circuits first.
h ) Let me know if you need further assistance after you have started
probing around .( Only if you feel you can work on these circuits ).
Thanks for choosing Fixya for assistance!
Posted on Feb 09, 2010
  • 4 more comments
  • Rommel Cana
    Rommel Cana Feb 09, 2010
    Servicing the unit requires a
    LNT 4032HX Service Manual
    like these one , only with a fee
    You may need to check for the Power Supply VS ( depends on the label on your unit )
    it has a feedback circuits which cut off the supply in case , there is no detection on the
    Inverter Circuit.
    like these
    like your other output voltages
  • Rommel Cana
    There are also possibilities that osc are blocked.
  • Rommel Cana
    Rommel Cana Feb 22, 2010
    Hope you have checked voltages and checked for cold solder joints on the power supply.
    If the power supply seems OK , then proceed to backlight circuits.
  • Rommel Cana
  • Rommel Cana
    If you like component level troubleshooting, then you really need to have one.
    possible causes can be :
    it could also be on the oscillator circuits / IC
  • Rommel Cana
    can you possibly post the chassis number?
  • 5,138 Answers
Bad capacitor on power supply board 1000uf 16v
Posted on Feb 08, 2010
  • 1 more comment
  • ladywinn
    ladywinn Feb 08, 2010
    I need The Name and Model number to TV which will be printed on back of TV.
  • ladywinn
    ladywinn Feb 09, 2010
    If you have any bad capacitors, Look at the top of them if they are puffed up or vented on top they are bad, Here is a company that List all Boards for this TV Encompass Parts Distrubtion you can go to their website and type in your model number for list of Parts and Part numbers.1-800-638-3328
  • ladywinn
    You can start with a can of freeze Spray when troubleshooting on a componet Level.
Charging battery
Sometimes if charged too long or your not around when the light does go off, after awhile the battery looses its charge. when that happens the charger will start to charge again and it will seem that it isn't working right or charging. in your instruction booklet it should tell you how long it should take to charge. some say 45 min some say hours. set a timer once you find the time recommended for your device, once it goes off unplug if light is off. good luck
Dec 07, 2013 | Case Logic IKBT-50 Bluetooth Keyboard...
TV Sony sound but no picture
Hello
Check the horizontal output section. Check the LOYT [Line Output Transformer]
Mar 09, 2012 | Sony Televison & Video
JVC LT47 that picture goes black (sound fine) after being on for awhile. Can turn TV off, then back on & it's fine. But then happens again about ever hour or so.
Hello
Hello
It is due to some loose soldering points [dry soldering we say it technically], in the power supply section of the TV. Just check for it. Check the solderings of all components, that will heat up to an extent when the TV works on. Repeated heating and cooling may make solderings to the terminals of that components to get loose. Just resolder all the suspected solder terminals, by applying a little more solder, without making any solder bridge short in between adjecent solder terminals. This must solve the problem to your tV. OK.
Feb 11, 2012 | JVC Televison & Video
The tv went black no sound or picture. We
U have a solid green light from the LED power light indicator right?U have this DLP tv for awhile like two or three years,and use it alots right?Never change the lamp and the ballast right?Change the lamp and the ballast should solved ur problems.
Apr 01, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Mitsubishi WD5725 DLP set. Picture is Ok before
The set has over 150 capacitors that could be causing the problem but it is at least 1 doing this. Contact Mitsubishi. Some people have been able to get new replacment TVs because of this problem
Mar 04, 2010 | Mitsubishi Televison & Video
I have a Philips Plasma tv 42pf5321d/37 with sound but no picture
Thats the great sound of Exploding capacitors on either the power supply board. or another one in there. Now the set is in fault protection. It tried to warn you with the RED blinking LED that there was something amiss by shutting itself down. When you unplugged you reset the error and allowed it to do it again.
Best Regards and Smper Fi
Jun 23, 2009 | Philips 42PF9630A 42 in. Plasma Television
Picture goes black but hear the sound
this is the problem related to display of ur TV screen...please contact the service centre...plz dont try to repair it urself..
Apr 30, 2009 | Sharp Aquos LC-C3234U 32 in. LCD TV
Picture stopped, same pic stayed on for a while, sound went dead
Don't know how I did it. Shut tv off and left it off for awhile put it it back on and picture and sound were OK. Thank you for your concern.
Apr 05, 2009 | Hitachi 51F59 51" HDTV Projection...
No picture, new lamp
Did you reset the hours on the lamp with the menu options on your set? Sometimes, if you do not do that it can mess with the tv performance thinking that its over hours. It needs to be reset to 0 again...
Sep 24, 2007 | Samsung HLN4365W 43" Rear Projection...
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
Electro Med Services...
