Question about Apple iPod shuffle Second Gen. Silver (1 GB) MP3 Player (MA564LL/A)
I don't know how to charge a battery for my mp3 player. It has two lights, one is red and the other is yellow. When I plug the battery into the socket, 2 lights are all bright and never turn off untill I unplug the battery. So I can't know when the battery is full (it doesn't have screen). Pls help me!! How to charge the mp3 player and to know when it's full. My mp3 ia JVJ ONE and I have surfed on it's website but i can't find any instruction informations. :( Pls help me! Thank to all!!
  • Apple Master
  • 6,993 Answers
the red light means its charging. You need to leave it until it shows green. The green means battery full.
The yellow is just an indicator.
Take care
Posted on Feb 08, 2010
When i charge the unit all i see is a light , no print, nothing. i remove already all the files, videos, but still it has steady light. and when i unplug it, the screen turned black and when try to...
That little led is a battery 's warning,when green the battery is fully charged,when yellow or orange the battery is half way or so and tells you to charge it pretty soon,once the led goes red then the screen becomes black because no much power.
when you charge the Mp3 the display stays on at all the time,it is not an issue or a problem. Hope i understood what you want to know and if you still need help ,please explain it better in the reply!
thank you,
Cris,the best you can find on Fixya
Jun 29, 2014 | Philips GOGEAR SA6045 MP3 Player
Pronto M6 chair will not work. When the power switch is turned on, the LED light flash Red followed by three Green. I can't find what this error code meas.... Pls Help thanks Phil
Phil the red means battery is low and the green is a speed limit code because of the low battery if you have charged your batteries and you still get the red then you need to check the charger after charging all night does the yellow light on the charger turn green? if when you first plug in the charger if the red light is on and the other light is green then there is a problem with the wiring or connection to the batteries from the charger and you aren't charging the batteries. if when you plug the charger in and you get a red and yellow light then the charger is working but you don't ever ge a green light and the battery level gauge is still showing red then you need to replace the batteries Hope this helps
Apr 12, 2011 | Invacare Supply Group Pronto M61 Standard...
Battery discharge quickly, I have replaced new batteries and module control and problem still exist.
Don your charger is probably not charging the batteries. When you charge your chair overnite the charger should have a red and green light showing charge complete. When you first plug it in the lights should be red and yellow. If you are getting a red and green light when you first plug it in then there is a problem with the charger or with the charging circuit to the batteries. You should have a charger port on the battery box try plugging the charger into that port and see if you can get the batteries charged. When you do you should have a red and yellow light on the charger changing to red and green when fully charged. Hope this helps
Nov 07, 2010 | Pride Go Chair Travel Power Chair
Ipod shuffle cannot hear music through headphones
Is it really a Head phone issue? lets find out that first.
If your headphones don't work as expected or not at all, connect the headphones to another audio source, such as your computer's speaker jack or another audio device that has a 3.5 mm stereo headphone jack, and test them. If your headphones are under warranty and still don't work, you can order replacement iPod headphones - Link - https://selfsolve.apple.com/GetWarranty.do;jsessionid=1B9ED1B556F0978A6C914A52711E59AA
And about the yellow and green LEDs
The yellow LED shows when the player is charging and a blinking green LED indicates you've paused the player.
At the back is another LED, the 'Battery Status' button, just below the toggle switch; when pressed, it flashes to give you a general idea of how much battery charge remains... green indicates a full charge... yellow, a low charge... red, very low charge... and no glow means its given up its ghost.
Hope this helps :-))
Dec 24, 2009 | Apple iPod shuffle MP3 Player
How do i charge my sansa mp3?
  • Step 1:Plug the appropriate end of the USB link cable that came with your SanDisk MP3 player into the MP3 player itself. The port for this cable can be found on the right side of most models of SanDisk MP3 players.
  • Step 2:Plug the other end of the USB link cable into a free USB port on your computer. This will effectively connect your SanDisk MP3 player to your computer.
  • Step 3:Turn your computer on. This will cause your SanDisk MP3 player to automatically begin drawing power from the computer and charging its battery. On the screen, an indicator light will flash yellow while the player is charging.
  • Step 4:Disconnect the cable from both your MP3 player and your computer when the device has finished charging. You will be able to tell when the charge is complete when the indicator light that previously was flashing yellow appears as solid green.
  • Sep 17, 2009 | Audio Players & Recorders
    COBY PMP3520 - first charge, but still red light
    dont know that model till i get hold of the manual for it, but i think it means is fully charged.
    Jan 01, 2009 | Coby PMP-3520 (20 GB) Digital Media Player...
    My MP3 YP-U3 don´t power up
    the battery might be dead. or u might have to take it apart and charge the battery by hand. ive done this before and it workd. i used a usb cord (5 Volts Max) wat ever u do do not charge the battery with anything over 5 volts. the battery inside the mp3 player is 3.7 volts, so be careful. It unplugs from the chip inside and the battery is easy to get out DO AT UR OWN RISK - PARTS ARE SMALL AND CAN BRAKE WHEN HANDLE CARELESSLY all u gotta do is find the seems on the sides and pull the player apart until it cracks open. then pull the connection tabs up for the usb and buttons from the chip, then by the hold button the chip will be guled to a ground, pull it apart and filp over the chip and u will see a lil clear plug with black (-) and red (+) wires on it, un plug it and set everything else aside, all u need is the battery. Now u need to find a old usb cord laying around and cut the end off that doesnt conect to the computer, splice the cord so that the wires are showing, cut them off EXCEPT FOR THE BLACK AND RED, now plug in the cord to a computer, or game console (ex. Xbox 360, Wii, PS2) then forcefuly slide the black wire onto the black (-) prong on the battery plug, same thing with the red one (+)
    then let it set for 15 mins. now u have to conect everything back the way it was and snap the player back together and see if it will come on, if not you might have to take it back and get a new one if you have ur receat. i hope this works remember be very careful with the inside componets. Good Luck!
    Jan 01, 2009 | Samsung YP-U3 MP3 Player
    My Mambo- Mano MP4-MP3 does no charge
    it does not seems to charge / or turn ON either from the computer or when plugged to an electrical outlet to the wall. Red light is still ON after the whole night . What's wrong ?? Can you please HELP - CODY STELLER MINE IS A 4 GIGA BITE MP4 PLEASE HELP ONLY
    Sep 01, 2008 | Kaser Corporation Mambo Mano Digital Media...
    Apple iPod  shuffle Second Gen. Silver (1 GB) MP3 Player (MA564LL/A) Logo
    70 people viewed this question
    Top Apple Audio Players & Recorders Experts
    Nagendra Baliga
    Parshiv Luthra
    Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
