I have a jump drive that metal piece is bent and will not read. My question is can the metal piece be fix. or is there something else I can do to make it read.
    Scholar:
  • 88 Answers
Bust out the soldering iron and a magnifying glass. Unfortunately when the lead break off the connector on a flash drive, that's your best bet.
Posted on Apr 04, 2010
My computer keeps beeping like there is something connecting to the USB drive, but there is nothing connected there
Check if there is something in one of the USB ports. Also check all of USB ports; is there any bent metal? Usually, the metal is bent and short the port.
Feb 11, 2014 | HEWLETT-PACKARD EliteBook 8530p
I bent my flashdrive and now it won't read. I initially was able to wiggle it around and once it read, I could drag one file to the desk top. Now, I can't it to read at all. What shall I do?
I would check the pins in the end of the flash drive and see if any of them are bent back. If these metal pieces aren't in the right place then the flash drive won't be able to connect to your laptop. I would try bending them back into place with a small flat head screwdriver. If you don't want to fix it yourself then I suggest you either buy a new flash drive or take it to an electronics store for more help.
May 01, 2011 | Verbatim VER95327 USB Hard Drive
I have a WD1600. When I turn the computer on, I hear a ticking noise from the hard drive. It ticks 10 times and pauses, and again until I get a hard drive failure on my screen.
The ticking is the reading head trying to read the data. Since it fails that means that the hard disk has died. This is unfixable and all the data on it is lost. Just take it out and replace it.
Sep 01, 2010 | Western Digital Caviar WD1600 (1600YD) 160...
I have a on going problem with my 99 gmc sonoma. The drive shaft is not well balanced. It is a three piece shaft, could I replace it with a older model straight drive shaft with no problem?
You will need to remove the hanger for the steady bearing because the one piece can hit on it, especially if you put something in the box. Other than that, it shouldn't be a problem if you can find one the right length. Hope this helps.
Mar 10, 2010 | 1999 GMC Sonoma
Negative metal piece gone for battery
Yes, you can replace it. If you are creative you can jury rig something to work. This type of failure of battery connections is fairly common.
Find a piece of metal that can be soldered and bent as needed.
You will need to take care in dis-assembly of the unit.
Sep 10, 2009 | Zoom H4 Handy Recorder
500G my book clicks and it is not recognized by my computer
Did you recently drop it? Usually the clicking noise means there is a slight bent metal object that is hitting when it tried to read. There is nothing to fix it. You'll will have to purchase a new one if it still doesn't decided to read
Aug 20, 2009 | Western Digital My Book Essential Edition...
Mysterious metal piece under vacuum motor?
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
fdgf
May 07, 2009 | Bissell 8910 ProHeat Clear View Upright...
Blades won't turn to cut grass
On the chute where the grass comes out there is a black piece of metal under the edge of the deck held on by the 2 big thumb screws is probably bent. You will need to try to move the blade on the side near the chute by hand (Make sure the mower is not running when you do this) if the blade touches the black piece of metal it will kill the mower if you engage the blades and try moving forward. Anyway you need to take the black metal piece off and bend the corner out of the way (I used a crescent and clamped it to the hitch on my pickup). I am guessing i went over something like a street curb with the deck when it was to low and that bent it. Now when ever I move the mower from someones yard or drive it across the street I always raise the deck up all the way. I hope this helps
Apr 19, 2009 | Ariens 34 In. Zoom Series Riding Mower
Formed metal wire inside handle
this bent metal wire goes right at the surface in a grove where the two pieces of the handle go together where your fingers grip it. I think it is to discharge static electricity.
Mar 27, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Gas hatch will not release on my rav4, How can I get it open. Need to fill up.
e most common problem is the spring on the fuel door breaks off. Have someone pull on the release cable handle, insert a credit card or something like that under the edge of the gas door, see if it will open that way. If it opens, look at the hinged end, you will probably see a piece of plastic, which holds a piece of bent springy metal. If the bent piece of metal is missing, you need to buy another at a Toyota dealer parts dept. If the bent piece of metal IS there, bend it further open to increase the tension. Try this, & if neither helps, get back to me for further info.
Oct 01, 2008 | 2006 Toyota RAV4
Computers & Internet Logo
111 people viewed this question
David Payne
David Payne
