I have a perkins 4108 diesel in my sailboat,last fall i removed the how water heater and ran the inline to the outline,i replaced the exhaust elbow , had the heat exchanger removed and cleaned and replaced the 160 ther4mostat with a 140.as soon as i put the motor under load(in gear) it heats up to about 220 and we can smell antifreeze in the cabin.currently it is 100 percent antifreeze in the cooling system.i replaced the old(original alternator with a 120 amp high output(this seems to put more drag on the motor)
  • 421 Answers
Two things spring to mind.
1. Are you sure that the system doesn't have an air lock?
2. Has the removal of the heater reduced the systems capacity to cool the engine?
Posted on Feb 08, 2010
Does a 2005 dodge diesel have a in-line fuel filter on the fuel line
Diesel injection equipment requires a high degree of precision to reliably work at such high pressures and give a long life and the fuel must have a similar high degree of precision. The fuel must be free of water and other contaminants and particles, therefore most diesel systems include a prefilter, a sedimenter and a very good main filter.
Heavy duty filtration can have a prefilter, at least two main filters and and two sedimenters.
A diesel system does have an inline filter but not in the typical way of petrol engines. The inline filter of a diesel is generally a fairly large replaceable element filter usually situated in the engine compartment, usually incorporates a sediment bowl and often includes a water detector and sometimes a heater.
Nov 16, 2017 | Dodge Cars & Trucks
How to resolve oily bilge water problem.
Could be fuel line leak or even exhaust fume condensation.
Mar 05, 2017 | Cars & Trucks
Perkins engine
check for fuel blockage or water in the filter. try bleeding air out of the system
Jun 03, 2013 | Diesel Jlg Aerial Work Platform S2 Liftlux...
Squeeling sound and lower pressure from gas water heater
Probably the factory-installed heat trap nipples are clogged.
Open following links.
http://waterheatertimer.org/Low-hot-water-pressure.html
http://waterheatertimer.org/Low-hot-water-pressure.html#trap
Noisy whistling and humming and low pressure are common problem with heat trap nipples and inserts from factory.
Replace heat-trap nipples with pex-lined nipples, or remove heat trap inserts with screwdriver or needle nose... careful not to break insert so it falls into tank ... which can then get lodged in hot water line elbow or under-sink shut off.
Factory-installed heat traps are part of overall strategy so manufactures can claim more efficient water heaters, without requiring customers to any thinking.
Other strategies include foam insulation instead of fiberglass (so that wires cannot be replaced on electric units), reducing factory-set temperature from previous 130-135 to 100-120, and re-estimating downward the hot water use for average family.
So some of the strategies are useful, while others problematic or imaginary.
Call manufacturer to pay-for or provide new pex-line nipples. Warranty for fist year covers Labor and parts, and after 1st year, warranty covers parts
http://waterheatertimer.org/Water-heater-manufacturers.html
Save $10 a month in future replacement costs: maintain water heater so it lasts longer:
http://waterheatertimer.org/How-to-maintain-water-heater.html
Apr 25, 2013 | Rheem Tankless water heater for 1-2...
On my diesel DZ-4108 I changed all of the batteries and the hour and minuet hands are working, but the digital display is not working the batteries are brand new but on digital display what can I do?
I just figured this out. When you replace the batteries, there's the white plastic cover secured with two screws. Remove them and you'll see an area with two exposed 'pads' that says 'reset'. Simply touch them together with a paperclip, screwdriver or whatever and the watch starts right up. :)
Jun 15, 2012 | Diesel DZ4108 Pocket Watch
Leaking antifreeze inside car. i want to bypass heater core if could until we can get it fixed. how do i do it?
Trace the 2 water hoses going into the firewall from the engine. Remove 1 and measure the inside diameter, most but not all GM heater hose is 1/2 inch. Go to the hardware store and get a plastic 90 degree plumbing elbow the same size and a couple screw hose clamps. Remove the heater hose from the firewall and connect them to the elbow with the hose clamps. Make sure they can't rub on the exhaust manifold and top up the rad and you are good. Hope this helps.
Jul 13, 2011 | Chevrolet Impala Cars & Trucks
Heater core 1991 corsica needs to be replaced. how do i get to it?
1991 VEHICLES
  1. Disconnect the negative battery cable.
  2. Drain the cooling system into a suitable container.
  3. Properly disable the SIR system, as outlined earlier in this section.
  4. Remove the instrument panel as outlined in this section.
  5. Remove the screws and floor outlet, turning clockwise and to the right to release from the rear floor air outlet.
  6. Raise the vehicle and support it safely.
  7. Detach the heater hoses from the heater core.
  8. Disconnect the drain tube elbow from the heater core cover.
  9. Carefully lower the vehicle.
  10. Unfasten the retaining screws, then remove the heater core cover.
  11. Remove the core screws, clamps and heater core from the vehicle.
Fig. : Exploded view of the heater core and related components - 1991-92 vehicles without A/C
To install:
  1. Reposition the heater core and install the straps and screws.
  2. Install the heater core cover and attaching screws.
  3. Install the floor outlet and retaining screws.
  4. Install the instrument panel.
  5. Raise the vehicle and support it safely.
  6. Connect the heater hoses to the heater core.
  7. Carefully lower the vehicle.
  8. Fill the cooling system with the proper type and amount of coolant.
  9. Enable the SIR system, as outlined earlier in this section.
  10. Connect the negative battery cable, then start the engine and check for coolant leaks. Check the coolant level, and add if necessary.
Hope this help (remember rated this post). Good luck.
May 15, 2010 | 1991 Chevrolet Corsica
The elbow is broken and the air from the hot water tank is leaked
Any exhaust air coming from the gas water heater is potentionally life threating. I would get it fixed. Do you have a CO2 meter close by the water heater? If it is leaking air back into the house that has CO2, after a certain amount the alarm will go off. If you dont have one get one. A must have with gas appliances.
Jan 09, 2010 | Fasco Bradford White Hot Water Heater...
Diesel mixed with oil in the sump
You run again the generator but before running, check & mark the oil level. Then stop the generator & wait until the oil settle to the bottom of oil pan. Check the oil level again & if the oil level is higher than the marking before that's means you have an engine gasket leak.You need to replace that gasket.
Mar 19, 2009 | Pramac GBW30P Encl Diesel Genset w/Perkins...
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
