Question about Whirlpool GEW9250 Electric Dryer
How stop soot stains in Whirlpool Duet 7MGGW9200MW0?
  • 2 more comments
  • ccmorris Feb 08, 2010
    The Whirlpool DUET 7MGGW9200MW0 is a dryer, not a washer.
  • ccmorris Feb 09, 2010
    The Duet 7MGGW9200MW0 is a gas dryer, not a washer. Please revise answer accordingly.
    Thanks,
    Carson
    Light cleaners aren't strong enough; wife's been using Goof-Off or a toluene -based cleaner and scrubbed the stains. Soot seems to be a bit greasy. Also, in addition to knowing how to get rid of stains, would like to know what's causing them.
    Thanks
    I'm asking how to prevent the soot in the dryer from occurring; not how to remove it from the drum. I've been removing it successfully since it first started.
  • 3,741 Answers
Soak Use the Soak cycle to remove small spots of set-in stains on fabrics. This cycle provides a soak time with warm or cold water followed by drain. Extra water, a short tumbling phase for equal distribution of the laundry, and a soaking time without basket movement improve the removal of set-in stains. Drain without spin assures gentle treatment even for delicate articles. click this link directly and check out page number 21 https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf also in the link its mentioned all the settings and trouble shooting for your washing machine. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Feb 09, 2010
  • Whirlpool Master
  • 8,220 Answers
Do you have the correct conversion kit for the type gas you are using?
You may need to open the air shutter on the burner if you are on propane gas. The dryer must have the correct burner for the type of gas in your home. Burner info is located on the rating plate in the door of your dryer.
They don't recommend a novice converting this dryer. Get your gas provider out there to check it out. DUET
  • Dan Webster
    Dan Webster Feb 09, 2010
    The soot is being cause by the nasty yellow flames shooting out the burner because the air to gas ratio is wrong. That gas needs to come out that burner all nice and pretty blue. The soot is the unburned gas by products being slung out along with the into the heated air. LOL
  • 10,865 Answers
Hello. To remove stains on your dryer's tumbler, apply spray cleaner, a mild abrasive, or laundry stain treatment to the affected area of the dryer tumbler and wipe with a damp cloth. Then dry a load of old towels or rags for about 30 minutes. These steps will remove the stain on your dryer's tumbler. Even if a mark remains on the dryer tumbler, the color won't transfer onto your clean laundry.
Regards, Joe
Posted on Feb 08, 2010
  • 10,515 Answers
Do you use Softner and Cold Water?
If Yes, these spots are caused by this ,softners and soap will not break down with cold water and flush out so it builds up under the tub and in the hoses.Get some stuff called washer magic and run a couple loads with hot water and no clothes.This will break it down and flush it out ,, use more hot water.This stuff shows for front loading washers but i have used it with top loaders too and it works really good
If Not, More often it is an Indication of Bad Transmission. Usually Transmissions do have 5 Years Warranty and if your washer is 7 - 10 years old ( which i assume as this usually is an indicate end of life for washers ), better to invest in new Washer.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Whirlpool duet electric dryer staining clothes
Are you sure it is the dryer? Most staining occurs in the washer and it usually because of fabric softened. Either because you are using to much or you haven't clean the dispenser
Mar 14, 2015 | Whirlpool Dryers
My Whirlpool duet sport machine occasionally has "stained" laundry. I can't figure out what causes it since I don't wash colors and whites together. The stains appear to be blue. Could this be a fabric...
Make sure you are diluting the fabric softener before putting it into the dispenser drawer. Full strength softener will sometimes stain clothing that's why in the owners manual they always tell you to dilute it first before adding ,plus it last a lot longer and is just as affective... Hope tis helps
Sep 16, 2010 | Washing Machines
Duet GHW9150P Front Load Washer: REDDISH BROWN STAINS FROM WHIRLPOOL GAS DRYER...
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Gas dryer leaves black grease spots on clothes
the soot is coming from the flame at the gas heater box the drier needs to be converted to propane the flame is too large without the conversion kit installed and thus creates soot at the vent. contact a local repair place for this one it can be tricky.
Sep 12, 2009 | Whirlpool LGR5636L Gas Dryer
My front loader gas Duet dryer has left brownish stains
Sounds like bad drum seals. Check all the way around the drum at the wall for sections of seals missing or an uneven gap around the drum at the wall.
Hope this helps.
Aug 14, 2009 | Whirlpool Dryers
Whirlpool Duet Washer/Dryer get brown streaks on clothing
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Jul 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have been getting brown stains in the shape of a line on items of clothing washed in my Whirlpool duet washer. I can not get these stains out with anything and they are ruining numerous items of...
I have been getting brown stains in the shape of a line on items of clothing washed in my Whirlpool duet washer. I can not get these stains out with anything and they are ruining numerous items of clothing. I have no idea what is causing them - I have manually cleaned the inside of the washer. same thing here. I have been having this problem for a few weeks, cant wash anything white without ruining it.
Apr 23, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Whirlpool front loader staining..
i have the same washer and i am some times perplexed about stain that appear after washing> i always blamed colors tranfer from other items .I'll keep a closer eye and see if i can find any more. does your washer have any oders that bother you mine does. for the price i feel cheated
Mar 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GEW9250 Electric Dryer Logo
77 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
