Question about Sharper Image Ionic Breeze® Quadra® 4.0 Silent Air Purifier Air Purifier
I have an ionic breeze quadra. When I turn it on,
I have an ionic breeze quadra. When I turn it on, the green light on top flashes instead of staying lit. It is not working at all. Can it be repaired?
  • 28 Answers
The company went under and doesn't service them anymore. It's possible you could find a local repair place that might be able to do something, but there is no authorized or trained service station. Good luck!
Posted on Mar 09, 2010
SHARPER IMAGE IONIC BREEZE QUADRA RED LIGHT ON
I had one that had the "needs cleaning" light was on. After cleaning, the light stayed on. I checked around at the time and learned it couldn't be fixed, and it was out of warrantee. I believe that's why they stopped making them. Mine was just thrown away.
Apr 02, 2012 | Sharper Image Air Purifiers
WHAT ARE THE GREEN AND BLUE LIGHTS FOR
To let you know when the ionic breeze is working properly (Green Light) and when it needs to be cleaned (Blue light). Hope this helps.
Apr 19, 2010 | Sharper Image Professional Plus Ionic...
There is a red blinking light and it is not cleaning.
My Ionic Breeze would work for a short time after cleaning and the blue light would start flashing and the unit would stop working. I checked the wall cube power adapter with a volt meter. It was putting out only 10 volts instead of the needed 12 volts. It seems The Ionic Breeze needs a full 12-13 volts to work. So I went to Radio Shack and bought a universal 12 volt 800ma power adapter. I checked the voltage in the new adapter, it was 13 volts. This fixed the flashing blue light problem. However the Ionic Breeze produces harmful Ozone gas, so I don't use it anymore.
Aug 09, 2009 | Sharper Image Professional Plus Ionic...
Ionic breeze quadra s1857 Red light continues to blink needs cleaning even after cleaning. not filtering. help
Mine is a Pro-series Quadra. It needed better cleaning.
The front and rear plastic grill scome off (release catch at the bottom of each), allowing access to the central core. I cleaned it with a damp rag (let it dry before you turn it back on). Be very careful of the two wires running the length of the unit -- if you break these it will not work. I did, however, gently clean them.
When I restarted it there was an unusual smell for a few minutes, but all is working well again.
Apr 13, 2009 | Sharper Image Ionic Breeze® Quadra® Air...
Ionic Breeze Professional GP series.....question regarding lights
red light will not go off what do you do or is it still working or not and the red light is just on
Apr 04, 2009 | Sharper Image Professional Plus Ionic...
Is my Ionic Breeze Quadra hopelessly broken and beyond repair?
This unit can be replaced on ebay for around $45.00 which is under any labor cost to repair the unit you currently have. You can always post your unit for sale on ebay for parts.
Feb 19, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
Ionic Breeze - Press Blue - Press Geen button
The blue means the germicidal lamp is operating. Re: green light - Normal operation at all power levels involves a pre-programmed cycle of altering high and low air movement. Press the the green to override the regular power control setting and run the unit at maximum power for five minutes. Your previously selected power level will resume after the five minutes has elapsed.
Dec 11, 2008 | Sharper Image Ionic Breeze 3.0 Air...
Ionic breeze quadra s 1837
I had a problem with my Ionic Breeze Quadra. Green light would only blink for a second then the red light stayed on. I cleaned unit very good but problem came right back. I blew out the breeze with an air compressor. Not much came out, but now I am green and back in action. I used about 75 psi to clean out.
Mar 23, 2008 | Sharper Image Ionic Breeze® Quadra® Air...
No power.
there is a small micro switch that is actuated by the grid. This is mounted on the side of the top control piece. There are two wires attached to the little circuit board, usually one is corroded so you need to cut it back and soder it to the center pin of the switch.
Jan 29, 2008 | Sharper Image Ionic Breeze GP (SI730) Air...
Sharper Image Ionic Breeze® Quadra® 4.0 Silent Air Purifier Air Purifier Logo
420 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Mike Squire
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
