Question about JVC Audio Players & Recorders
JVC RX 709V Will not turn on stanby keeps flashing on and off.
  • 506 Answers
There is most likely a fault in the power supply that is causing the amplifier to go into protection. This receiver more than likely has a switching power supply you can tell by the weight of the amp. Heavy = linear power supply and light = switching power supply. Common problems with switch mode power supplies are the FETs used for switching and the PWM (pulse width modulation generator) If you know someone into electronic repair it should be too difficult. The FETs won't be cheap. Though. All in all the unit should be no more than 100 dollars to repair between labor and parts.
Posted on Feb 10, 2010
How do i turn off the linear pcm on a jvc rx-6018v
The nature of a source's digital bitstream is automatically detected at the receiver. Look at your unidentified source and ITS manual for that answer.
http://www.retrevo.com/support/JVC-RX-6018VBKJ-Receivers-manual/id/315ag011/t/2/
See the box on page 14.
Sep 23, 2011 | JVC RX-6018V Receiver
Overload keeps flashing
Remove anything that may be sitting on top of it, and give it at least 6" of clearance all the way around it to help dissipate heat and leave it that way
permanently.
Next check that the speakers you are using have a compatible Ohm rating for the receiver.
Dec 19, 2009 | JVC RX-558V
Overload flashs
there will be 6 amp circuit in your receiver. you can't unplug them one by one. with a multi-meter you may be able to find the shorted channel. (most JVC receivers use discrete circuits instead of an output IC) Check for shorted transistors attached to the heat sink. You will possibly find some open resistors also. Generally this is a job for a pro.
Feb 26, 2009 | JVC RX-6042 Receiver
JVC RX-318 keeps blowing fuses
could be several things, speaker wires touching,shorted output transistors, a shorted rectifier diode,bad filter caps in the power supply,those are the most common
Jan 06, 2009 | JVC RX-318 Receiver
Sony FD Trinitron Vega 2004 Stanby Flashes TV will not turn on
This unit shouldb e flashing a repeated count on the standby light. That count will indicate the circuit in which a problem was detected causig the shutdown. Please post that count and we should be able to provide details on the repair.
Thanks,
Dan
Jul 07, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
New Sharp Aquos LC37X20E. After 30 mins turns itself off to standby and comes back on after 2-5mins (even though the automatic return to stanby has been set to "disable"). Eventually after...
According to Sharp it is a software problem. Engineer came, installed software update ,10 minute job.....TV worked fine for 1/2 day unfortunately: Then images turned black and white in all channels TV turned itself off, and stanby and OPC buttons started flashing. When TV came back on its own 10 mins later , screen had 2 large square staines superimposed in image (as if it was a burnt screen)...Engineer will be back next week...all quite sad really for a new TV.....will keep u posted
Jul 03, 2008 | Sharp Televison & Video
Overload
The audio amplifier IC of your device are damaged you gotta send to a repair center.
Jun 04, 2008 | JVC RX-6042 Receiver
671 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
