Question about HP Compaq Presario 2200 Notebook
Need harddrive adapter - HP Compaq Presario 2200 Notebook
    President:
  • 949 Answers
Hardrive removal
Simple as pie... you will see the harddrive mounted horizontally in a small shelf after you tae the cover off. You have to unscrew the philips screws that hold it in the shelf and unplug the connectors. make sure you label the wires so you know which ones came from that harddrive... they is usually room for 2 harddrives and two complete sets of connectors, don't mix them up. (One is the master and the other called a slave.) There is an adapter for the harddrive that you should always keep should you need to replace the harddrive, (comes in two pieces on either side) the new ones don't come with the adapters to fit them in the case; they are bare bones. If you don't want to go through the gymnastics of taking the other tower apart and installing the 2nd harddrive in it to read it... an internal HDD adapter can be purchased from Tiger Direct for a nominal cost. I allows you plug you internal HDD into a USB socket in any PC (desktop or laptop) and read it as you would a Flashdrive.
Jun 02, 2014 | Gateway E-4300 E4300 Matxhrn Lux Pc - XP...
Dell latitude d600 setup screen
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
May 11, 2013 | Computers & Internet
Hard drive door unscrewed and hard drive was hanging... Now this screen?
This is a network PXE boot screen. This is usually the last boot device it will try if it doesn't detect a HDD or cd/dvd drive with bootable media. You should be able to see a hard drive in bios, if not replce it and re-install your operating system.
Dec 25, 2012 | Computers & Internet
WD500H1U-00 Western Digital 500GB MY BOOK external hard drive does not turn on power. There are two cables, one goes from external hard drive to computer and then another one is a power cable. It does not...
Believe it or not, unplug the AC adapter (Power Adapter) from the surge protector, and plug it directly into the wall socket.
Try this first.
1) I believe the power adapter is rated at 12 Volts DC, and 2 Amps, for the output voltage, and amperage.
(12 Volts times 2 Amps = 24 Watts.
12V X 2A = 24W)
Use a multimeter, and test the voltage coming out.
You can buy an economical multimeter for around $8 to $12. A lot of stores carry them. An auto parts store is but one place.
The plug end that plugs into the laptop, is cylindrical in shape, and has a hole in the center.
This is DC voltage you are testing.
The metal center of the plug is Positive. The outside shield surrounding the plug is Negative.
The Function Knob should be turned to DC Voltage.
(If it is a symbol, it will be a dotted line above a solid line.
NOT a curved line on a dotted line. This is for AC voltage)
If there is more than one scale, set the Function Knob to DC voltage 0-50 Volts.
The Red probe lead of the multimeter is the Positive lead.
The Black probe lead of the multimeter is the Negative lead.
AC adapter plugged into power, the Positive probe lead is inserted into the center of the plug.
Be SURE it doesn't touch the outside metal shell at any time.
The Negative probe lead is touched to the outside metal shell.
See if the voltage reads 12 Volts.
AC adapter (Power Adapter) checks out OK?
Suggest there is a problem with the small circuit board inside the MyBook.
Inside the MyBook WD500H1U-00 is an ordinary harddrive.
It is a desktop sized harddrive. 3.5 inches across in width.
(3 and a half inches, or 8.9cm)
It is a SATA harddrive.
http://www.youtube.com/watch?v=6FlySnyJ0CQ
Inside that plastic MyBook case is also a small circuit board. An interface circuit board.
The harddrive plugs into the interface circuit board directly, or there is a cable, or cables, that plug into the harddrive from the interface circuit board.
It is this interface circuit board that goes bad most of the time.
You can remove the harddrive out of the MyBook case, and put it inside a desktop computer that uses SATA harddrives, as a Slave drive.
Retrieve your information, and burn to disk/s, or flash drive/s.
{DO NOT move any jumpers on the back of a SATA harddrive. These are for the factory ONLY}
Or you can buy an adapter that the harddrive plugs into, and it has a USB cable.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2583340&CatId=3770
Or you can put it into a 3.5 SATA external enclosure, and use it as an external harddrive again.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2145406&CatId=2780
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 03, 2011 | Computers & Internet
My external Harddrive just up and stopped showing up on the computer. I mean the lights (red and blue) are on, it just doesnt show up. i even plugged both cables into my comp, and still nothing. I noticed...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Try your harddrive in different computer if it is not recognized on another computer too then power adapter of harddisk or your harddrive has internal issue.
Let me know if you need further assistance. Thanks for using FixYa
Oct 15, 2010 | SimpleTech SimpleDrive 160 GB External USB...
Blue screen on Laptop
I'm not going to state this is going to cure your problem, but here are some things you may wish to try;
1.Remove the AC adapter if plugged in. Remove the Battery.
Open the Memory Compartment door, and remove it.
Take the ram memory module, (Stick), out. If you have more than one, remove them both.
Now reinstall them/it. Reinstall the Memory Compartment door.
2.Remove the Harddrive Compartment door. Make sure the harddrive is plugged in tight. If you look, there is a rectangular shaped part on one side, in this compartment, that the harddrive plugs into.
This is a connector. (Actual name is Interface)
Push the back, (Opposite side of the connector), of the harddrive, to assure that it is fully seated in the connector.
Reinstall the Harddrive Compartment door.
Reinstall the Battery. Plug the AC adapter back into the laptop. Plug the AC adapter, (Charger), into the surge protector.
(Advise always unplug the AC adapter from the surge protector first, then from the laptop. If you do not, there is a chance of a voltage spike)
WAIT 1 minute, then turn on the laptop.
The Ram Memory can become unseated very easily.
The Harddrive has a metal frame around it, and the frame is attached to the main body of the laptop, with a scre-w, or scre-ws.
Still may be a chance, that the harddrive can become partially unplugged from it's connector.
Dec 25, 2009 | Office Equipment & Supplies
Lead from external harddrive to tv- to show films,--usb connection from harddrive to 15pin to tv
Dear ragalgey,
As far As I can remember, most TV design to receive the signal to watch whatever you want limited to available TV station in your local broadcaster.
If you think you connect your harddrive to TV USB or 15pin (VGA cable) then you can watch the movie file from harddrive is a totally wrong!
You need a drive or a player for those file that capable to configure your TV to play them. Or at least you need a PC or Laptop Computer that played your harddrive then send the images/video via Video Out Jack (Yellow) from your laptop, or connect the 15pin VGA jack from Laptop PC out then plug in to your TV. In this case you'll need the Jack/adapter to convert from 15pin VGA from laptop to available Video jack on your TV.
Good Luck!
Best Regards,
bionic23
Dec 08, 2009 | Samsung Computers & Internet
Can I put the harddrive of my dell 1525 laptop into the dell 1725
you can get an adapter that will allow you to connect your laptop hd to another pc through the usb port. Your hard drive is probably SATA so you would need a SATA to USB adapter cable.
Something like this cable would work.
Oct 05, 2009 | Dell Inspiron 1525 Notebook
External Harddrive Won't turn on
SimpleTech SimpleDrive Pininfarina 320GB External
I need to replace my ac adapter what is the voltage
6 volts or 12 volts
Dec 10, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
HP Compaq Presario 2200 Notebook Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
