Question about Zyxel Prestige 660RU Adsl 2+ Ethernet USB Router
I have an EQ 660R ADSL router supplied by embarq for a internet modem. After 8 plus minutes, I get consistently dropped from the internet. Restarting computer, restarts the internet, which then repeats dropping me. Any suggestions?
I have the same problem trying to connect throw usb
Posted on Feb 08, 2010
Adsl ok (green). But no internet connection (red).
Hi. You can "powercycle" your deviced first. turn off your computers, router and modem (make sure you unplug the router and the modem from their power source), wait for 2 minutes then turn the modem on, wait for another one minute then turn the router on, wait for another minute then turn the computer/s on. :-)
Jun 04, 2011 | Belkin Computers & Internet
I have a ZyXEL P-660R-D1 router connected to my Linksys Wireless-G 2.4 GHz Broadband router and I'm having a few problems. First, the internet light on my ZyXEL won't light up EVER. I am not sure if that...
First of, unplug your Linksys and go right into your ZyXEL, (you might need to run a cable) Run that way for a while, If your not cut off then it's your router. Do this first and we can go from there.
Dec 22, 2010 | Zyxel Prestige 660R Router (91004397002)
I can't get my belkin 37E1 to talk to the modem an embarq 660. I have a gateway computer running xp
ISP : EMBARQ
Step 1 : Connect Belkin - Computer ( Computer Should go to Any one of the four the Grey colored Wired slot)
Step 2 : Make sure the embarq modem is not connected to the belkin
Step 3 : Open the Router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 4 : On The Left under LAN Setup Click Lan Settings
Step 5 : Leave the Password Blank And Click Submit
Step 6 : Change the LAN IP To 192.168.3.1
Step 7 : Click Apply Changes
Step 8 : Connect EmbarQ modem to the Yellow Slot in the Router
Step 9 : Connect Modem - Router - Computer ( Check if you Have Internet !)
Setting Up A Wireless Connection
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.3.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Oct 17, 2010 | Belkin (F5D7231-4) Wireless Router
How can I setup my Linksys 54g v2.2, with my ZyXel 660r modem from embarq so that I can use my laptop with the routers wifi?
First of all you need to set you modem router to bridge mode. go to this link will explaine in more detail
http://kb.earthlink.net/case.asp?articale=69205
remember to change the linksys router ip to 192.168.2.1 or 192.168.0.1 somthing different from the modem .
Hughes modems are all set to 192.168.0.1 so simply setting the linksys router to default 192.168.1.1
you need to change the linksys router IP to somthing different 192.168.0.1
Oct 27, 2009 | Linksys Wireless-G WRT54G Router
Even after doing a hard reset on a zyxel eq-660r router/modem the stupid 1234 password won't work.I s there another way of getting into the router to change configuration?
Go to the manufacturer's webpage - the password may be incorrect for your router. Try another hard reset if the password is confirmed; software is fallible (just look at computers!).
Sep 08, 2009 | Zyxel Computers & Internet
When trying to install gets message cant find internet trying to hookup to embarq 660
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi there! This are some steps on how to setup your modem/router
New DSL Modem Available
Embarq is now shipping an updated version of the DSL Modem called the "660". It is smaller than the older model (645) and is much easier to setup.
A few years ago, Sprint/Embarq changed the way their servers communicate with the DSL modems. The new method is called DHCP, which is how the 660 modem works. The older 645 Modem used "PPPoE". So it's best to have the new 660 DSL modem.
The older 645 modem also had the same default IP address as the Linksys Router (192.168.1.1) - so you had to change one of the addresses to make them work together.
The new 660 DSL modem uses 192.168.2.1 as the default IP address. This does not conflict with the default IP address of the Linksys Router (192.168.1.1). Note that if you had changed the Linksys Router IP address to 192.168.2.1, then you will first need to reset it back to the default address 192.168.1.1.
If you call Embarq and request the new 660 DSL modem they will sent it to you at no cost. When you install the 660 DSL modem, you need to be sure that you power down the old 645 modem amd leave it off at least 1 hour before you plug in the 660 DSL modem. The Embarq server needs to "forget" the old 645 modem. After an hour, all you should have to do is plug in the new 660 modem and everything should start up properly.
Call Embarq Tech Support 1-877-646-3282 if you have problems setting up the modem. If the Internet Lights does not come on after a few moments - then call Embarq Tech Support.
Aug 15, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
I got Embarq DSL a few weeks ago, i can get online for a minutes then the internet will go out, i have to reboot the modem several times before it will come back up, ive tried changing where the modem and...
If Embarq cannot or willnot help you, drop them and get another service.
First connect your modem directly to the computer to isolate the problem. If it solves problem then difficulty is in the router. Then contact the router manufacturer.
If problem persists the Embarq should help you.
Apr 29, 2009 | Dell Microsoft Windows XP Home Edition
EMbarq/Zyxel 660R/eHarmony/Windows Don't Play together well
Upgrade to the latest firmware on the modem, disable the modem firewall, or bridging the modem will resolve this
Sep 03, 2008 | Zyxel Prestige 660R Router (91004397002)
2wire dropping xp pc
hello!
you may try this and see if this help solve your problem
Step 1try to connect your computer directly to the modem and check if you will also experience problem
Step 2: Shutdown the computer.
Step 3: reset the router while power on then Unplug the router’s power cable.
Step 4: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 5: Plug in the Broadband modem’s power cable and wait for its lights to appear
stable.
Step 6: Plug in the router's power cable once the modem’s lights appear stable.
Step 7: Power on the computer on and configure router settings if neede
Step 8:test the Internet connection.
if this still didnot work, maybe you need to upgrade the firmware of your router
May 01, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
Zyxel Prestige 660RU Adsl 2+ Ethernet USB Router Logo
2,808 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
