Question about Motorola Mobility MOTO ZN200 Cell Phone
New phone, battery does not charge, not recognized.
How do I fix the vetch phone when it displays no battery
It will not recognize the return of the battery until the handset
is placed again into the charging dock or base.
FWIW, amazon.com has the best prices on new batteries
for these cordless phones.
Oct 05, 2014 | Vtech Lands Phones
Just bought a new Blackberry storm 9530 and it is not getting charged. Please help
Usually for brand new phones, the battery needs to be charged for two hours. But if you found out after it's been a while and it's not charging, make sure the battery is inserted correctly. If it's and the led is not on or no charge indicator, do the following, take out the battery, unplug the charger from the phone, press and hold the power button for five seconds. This drains out the battery. Now put the battery back in, plug the charger into the phone and let charge. Don't worry if it doesn't recognize it immediately. I hope this helps
Mar 09, 2011 | RIM BlackBerry Storm 9530 Smartphone
I connect my motorola w180 and my windows 7 does not recognize lost my charger and wanted to charge through the USB cable, I can do?
Your phone should actually be charging regardless of whether or not windows recognizes your phone. Double check the battery meter on the phone to see if it indicates that your phone is charging.
Feb 28, 2011 | Cell Phones
My usb for cect i9 does charge phone
my cect i9 was not charging from usb I though it was the cable but after I took out battery and scrapped the 3 contacts on the batttery with my fingernail it started to charge and be recognized by computer again
Jul 13, 2009 | Dual Electronics CECT P168 Cellular Phone
Phone will not maintain a charge nor will it recognize blue tooth
throw it away my friend had same problems with no avail
Jul 07, 2009 | Cell Phones
Dash phone battery won't charge using 3 different chargers
T-Mobile Dash charger input not recognizing it is plugged into charger. Tried 3 chargers...
Nov 01, 2008 | T-Mobile Dash Smartphone
Samsung SGH-A701 Wont charge when on the charger
Similar problem, battery ran out but cant get recharge it, sometimes the screen flashes if it take the battery out and put it back in, but then black?
Should I try an new battery or a new phone?
Jul 15, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Will not recognize battery typ
is this the same original battery?if so try a new battery.sometimes a phone will do this when the battery is going bad.
Jun 22, 2008 | Samsung SCH-u740 Cellular Phone
Won´t charge
My SLVR had the same problem, so I bought a new one from Amazon. When I plugged the new one in the first time it did fine, but when I ran the battery completely out, it wouldn't charge. I played around with it a little bit, and I think I've found a solution that works: try taking the SIM card out of the phone, THEN charge it. It works on both my new one and my old one that way. The drawback for you is that you can't use your phone while its charging, I just switch phones while the other is charging, a bit of a pain sometimes, but the SLVR is my favorite phone so its worth it. :-) Good Luck.
Dec 10, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Motorola Mobility MOTO ZN200 Cell Phone Logo
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
