After awhile, picture goes black. Front led is also out. Remote functions work, and sound is ok. Unplug for an hour, it works ok again, but goes out after awhile again
  • 1 more comment
  • Frank Feb 08, 2010
    samsung LNT4032hx
    Sound stays ok. My soldering skills are fine. Your thoughts of it being a problem in the inver ter/backlight might be on track.. Question is how to trouble shoot it. I have no schematics, so was hoping that it might be a recurrent problem on this model, and for a direction based on this.
    Frank
  • 4,889 Answers
Please let me know the make and model of your tv so that I can help you with your problem.
Sai.
Posted on Feb 08, 2010
  • 1 more comment
  • eagle338
    eagle338 Feb 08, 2010
    Ok.. Try these simple diagnostics and let me know the result
    1)When the picture goes black darken the room and see if you notice a dull glow on the screen
    2)If there is no glow then flash a torch on the screen from a close distance and see if you notice a dull picture. Keep flipping the channels to make it more noticeable.
    Let me know your observations,
    Sai.
  • eagle338
    If you have sound then it is usually not a power board issue, but since the sound is out I am inclined to believe so. How good are your electronics/soldering skills?
  • eagle338
    Replacing the inverter board is usually very easy. It has a few connectors on it that you have to unplug from the old board and plug into the new board. There are two inverter boards in your set -master and slave. I have managed to locate only the master though. If you can take off the back cover and let me know the part number if the inverter slave then I can try finding it for you. You can get the master from the link below for around 40$
    http://www.shopjimmy.com/catalog/product...
How to fix my lcd tv and magic remote?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
May 29, 2015 | LG 47LW6500 47 3D LCD TV
JVC LT47 that picture goes black (sound fine) after being on for awhile. Can turn TV off, then back on & it's fine. But then happens again about ever hour or so.
Hello
Hello
It is due to some loose soldering points [dry soldering we say it technically], in the power supply section of the TV. Just check for it. Check the solderings of all components, that will heat up to an extent when the TV works on. Repeated heating and cooling may make solderings to the terminals of that components to get loose. Just resolder all the suspected solder terminals, by applying a little more solder, without making any solder bridge short in between adjecent solder terminals. This must solve the problem to your tV. OK.
Feb 11, 2012 | JVC Televison & Video
Get a picture but no sound
Unplug,replug the tv about an hour later.Let the tv reset it self.Go to the menu,go to Audio setting,go down reset.The tv audio will work again.Not,than ur Tuner board is dead.Must be repalced.
Apr 26, 2010 | Sony BRAVIA KDL-32S5100 32 in. LCD HDTV
Power on - Screen Black non responsive
Hi...
Look into getting the main power supply replaced
Check the web for someone near you
Apr 22, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Picture goes black but hear the sound
this is the problem related to display of ur TV screen...please contact the service centre...plz dont try to repair it urself..
Apr 30, 2009 | Sharp Aquos LC-C3234U 32 in. LCD TV
When turned on, no picture, sound or response. LED is OK
I had a similar problem with my HANNSLounge 32", the screen switched on with green light but none of the front panel buttons worked (screen is black apart from showing the input source in the top left).
After powering off numerous times I tried starting up with a blank SD card in the reader and the tv cycled between red green and blue screens and then reset itself. (Some sort of firmware restore?) After which point I had a working screen again! (Will have to see how long it lasts for!)
Feb 12, 2009 | Hannspree HANNslounge 32 in. LCD HDTV 32
Picture goes black
GO TO MENU, THEN SETUP, SCROLL DOWN TO TIMER AND MAKE SURE IT IS ON 0 (ZERO) MIN. SOUNDS LIKE ITS PROGRAMMED TO GO SLEEPAFTER A CERTAIN TIME. THIS TV ALSO CUTS OFF AUTOMATICALLY IN 15 MIN. IF ITS TUNED TO A VACANT CHANNEL( NO PICTURE).
Jun 18, 2008 | Toshiba 36AF42 36" TV
Televison & Video Logo
Top Televison & Video Experts
