Question about Audiovox ACD-24 CD Player
Dim Display The display is so dim that it cannot be seen at all during the day. It's ok at night. Still not too bright. i checked all the wiring and everything is fine.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 199 Answers
There may not be enough power running to the display. What are you using for a power source? My suggestion is to wire your power to your ACC if you have not already. The other thing I can think of is the connection is bad. Make sure the terminals used to connect your stereo are all tight also.
Posted on Jun 10, 2008
Buick Rendezvous Head Up Display
not sure about that one but there is a dimmer wheel by the light switch. move it up and down to dim and brighten the dask lights/cluster. wheel may need replacing. also work the lights on and off switch manually to see if there every thing works smooth or hopes from dim to brite.
Feb 16, 2014 | Cars & Trucks
Display is very dim in the daytime.impossible to see anything
Do you have the display lighting turned down, there is a control for the brightness.
Aug 17, 2012 | Cars & Trucks
Simple problem. The clock display on the Motorola DCX3501-M is very bright and is located in our bedroom. Its like trying to sleep with a 40 watt light turned on all night. Is there a way to dim the...
From "asvforum"...note this may require firmware upgrade of the device in order for the dim functionality to be present:
"With the unit currently powered on and the TV powered on, press POWER OFF and then press MENU. You'll then be presented with the "hardware setup menu" where you can set things like "native" output resolution vs. fixed output resolution, etc.
I believe that there is now a "display brightness" setting in this menu.
Of course I could also be wrong, and maybe this display brightness adjustment is just part of the "user configuration" setup menu. With the unit powered on, press MENU twice to get the main menu. Navigate to the Setup button and push OK. Navigate to Cable Box setup button and push OK. If the display brightness setting is in this "user configuration" setup menu, it should be seen somewhere in here.
But I think I remember reading that it was in the first "hardware setup menu".
Jun 05, 2011 | Televison & Video
Led display shut down when the detector detect an alert
You have the unit in dark mode. Press the Dim/Dark button again to get the unit to full brightness. THe unit has 3 levels of DIM. First the unit is at its full brightness, pressing the dim/dark button will dim the display and the unit functions normally. Press the Dim/Dark button again will futher darken the display but when the unit alarms the display is turned off and remain off during the alert. After the alert is over the unit waits 20 seconds of no alert to turn the display back on.
Mar 09, 2011 | DE-1740 Radar Detector
Dim Screen on the 2001 Toyota Prius
Yes the screen dims automatically when the lights are on to suit night driving. I am not specifically familiar with the 01 model, however on my 08 model, the display brightness is also manually adjustable via a button located below and to the right of the display. The button is marked with a series of short lines assembled in an arc. Hope this helps.
Nov 25, 2009 | 2001 Toyota Prius
The display is too bright at night. anyway to dim
Sorry this one was not built with any dimmer opportunities.
Sep 28, 2009 | Starlite Next Play Clock Radio with iPod...
Radio display is dim during night
Sounds like you have a dimming switch problem. You can pull the switch out, any I'd bet you have a burnt wire at the connector. It's a comman(<spelling?) problem.
Jun 19, 2009 | 2003 Chevrolet Monte Carlo
Dim Mode
Make sure the orange wire with white stripe is connected to your dash illumination/parking lamp circuit. There should be a tag on it that says 'ILLUM' (unless the installer clipped it). That should dim the display whenever your lights are on.
If that doesn't do it enough I think your going to have to dial down the brighness - and that will do it for all functions.
Feb 13, 2009 | Kenwood DNX7100 Car Video Player
I no longer get a bright display. The display stays on dim even when I switch to bright. I cannot see the screen at all during the day. I have a Cobra XRS 9930 that has developed a very dim display....
I had the same problem. I also live in Florida and I guess the display overheated in my hot car after time. I eventually bought a new one but it did the same thing.
May 18, 2008 | Vehicle Parts & Accessories
could be bad LED's inside, loose led screen or a problem occurring with the BRIGHT/DIM switch. if possible take to a tech center. radio shack, or circuit city.
May 06, 2008 | XRS 9330 Radar Detector
Audiovox ACD-24 CD Player Logo
168 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
