Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Bake elment wont turn on. i replaced it and the relay and still nothing
    Genius:
  • 1,036 Answers
Check that the element itself is not blown by comparing the ohm values on the good ones with the suspect one.
If it tests good, check wiring route and in particular the connections for any corrosion or heat damage.
Finally check the switchgear for correct operation.
Posted on Feb 08, 2010
Moffat oven fan wont turn off. just keeps blowing cold air but eveything else is working
Stove will not turn off CHECK
Temperature Control Thermostat
If the oven won't turn off the oven thermostat is often the cause of the problem. The electrical contacts inside the oven thermostat can weld themselves together and then the oven won't turn off. If this happens, turn off power to the entire appliance at the household circuit breaker or fuse. The oven thermostat usually cannot be tested and must be replaced if defective.
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn off it could be that one of the relays on the oven control board is shorted closed, providing voltage to the heating circuit. It can be dangerous if the oven won't turn off. Don't leave the oven unattended without turning off power to the oven.
Relay board:
Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately. ALSO CHECK THE BAKE AND BROIL ELEMENT.
: I offer free advice bcuz God is so good!
Jun 03, 2015 | Moffat Ovens
Broiler comes on on top oven every time you turn bake on and won't go off. Recently replaced temp sensor for similar sporadic problem and worked for a while but now happens every time
Oven Control Board
Relay board:
May 20, 2015 | Ovens
How do I fix oven staying on
Oven Control Board
Relay board:
Apr 22, 2015 | Ovens
Element heats up when we only put oven light on
Oven Control Board
Relay board:
Nov 17, 2014 | Whirlpool RMC305PV 30" Built-in Microwave...
Why will my whirlpool oven not cut off
Oven Control Board
Relay board:
Jul 28, 2014 | Whirlpool Ovens
Whirlpool gold electric oven code pf and broiler won't turn off, oven goes into clean mode when baking
Oven Control Board
Relay board:
Dec 22, 2013 | Whirlpool RBS275PD Electric Single Oven
I just replaced my baking element in my oven, and when i turned the breaker back on, now the new element automatically heats up by itself and stays on....with everything off. The only way I can get it to...
If the only wires you disconnected and reconnected were the 2 on the element itself, the bake relay is fused. Depending on the brand and model, the bake relay can be located on either a realy board or the electronic oven controller. Either the controller or the relay board (if present), will also need to be replaced.
Apr 16, 2011 | Stoves Ovens
I have no power going to oven or broiler after putting in new baking elment
You may have a blown thermal fuse. Usually located on back of oven. It is not a user-serviceable part but is not difficult to replace if you are experienced with electrical repairs.
Jun 26, 2010 | Ovens
My upper oven/ convection function on my dacor ecs230b will not heat
Bake and convection bake settings both use the bottom bake element to heat. It would be unusual for bake to work without conv. bake working. You also have pure convection which uses a different element surrounding the conv. fan on the back of the unit. If you press a feature and nothing happens it's the touch pad. If it comes on then turns back off it's probably the ERC (clock). If it comes on and wont heat only in pure conv. possibly an upper relay board or element problem.
Sep 22, 2009 | Dacor ECS230 Epicure Electric Double Oven
GE mod.JDS27G0P2BG Oven Wont start
You have a bad electronic control board.
No repair.
It must be replaced.
Feb 21, 2009 | GE Profile JTP18 Electric Single Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
93 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
