Question about Daewoo DVDS151 DVD Player
Finding the lense on a daewoo dvd s 151
Where is the lense located on the daewoo dvd s 151? I need to clean it.
  • vanvliet Feb 22, 2008
    I seemed to fix the problem by blowing into the disk opening to loosen any dust. The dvd player worked fine after that. I wondered about the effectiveness of a dvd lens cleaner disk. Is one worth the try? vanvliet
  • 979 Answers
How do you know this is what you need? There are actually 4 lense surfaces that can accumulate dust and dirt, and they are located on the optical traverse assembly. Once again, if you are not a servicer, I would not attempt this course of action due to the delicate nature of the laser assembly. Chances are, what is really needed is either a grating adjustment, or a spindle height change. What is your player doing?...accordianman
Posted on Feb 22, 2008
  • Michael Borelli Feb 23, 2008
    Nothing ventured, nothing gained. You may have just been lucky enough to have the set operate one more time after that "external cleaning"...accordianman
My DVD player is becoming very selective about the DVD's it will play, and the ones that it rejects as the wrong "format". It seems to be getting more selective by the day, and prefers newer...
Ya, it does sound like the lense is dirty. To clean it you can pick up a cleaning CD or DVD. It basically will clean your lense while it plays. You can find them at bestbuy or circuit city. The CD actually has a brush on it and will wipe the dust from the lense while the disk plays. Keep me posted. If you thought this solution was helpful please rate it when you get a chance. Thanks - Tech101
Jun 25, 2008 | Televison & Video
Daewoo DV-6T999B DVD/VCR Combo DVD player has suddenly stopped recognizing DVD's that it has played in the past, or new DVD's. It tries to load and ends up saying Bad Disc. There is nothing wrong with...
The step after using cleaner solution and disk is cleaning the pickup lens inside the DVD.
You need to disconnect device from power and remove the case.
Find the lens, that is the glass lens and under the DVD clamp.
Use a cotton swab and some isopropyl alcohol to gently wipe the lens.
Here is the complete procedure.
If it still does not work, you will need to replace the laser lens pickup that is the part below:
Use the schematics in the service manual if you decide to DIY
Or contact the nearest service.
Regards
Mar 30, 2008 | Televison & Video
Dvd player freezes in the middle of a movie, the player stops and freezes on a scene
It sounds as if your DVD player is having trouble switching to the 2nd layer of the Dual layer DVD. If the DVD player is older, it may not even support dual layer DVD's. If it is a more recent model (less than a few years old), then the lense may need cleaning. You can try blowing the compressed air into the slot where the DVD goes (DVD removed, tray out if it is a tray model) or an inexpensive DVD lense cleaner you can find at most retailers (Wal-Mart, Target, etc.). The second layer requires a different focus on the lense and has to penetrate a little deeper into the DVD so it will be problematic if there is any dust or foreign objects on the lense.
Feb 01, 2010 | Televison & Video
I have LG CD RW/DVD CD-ROM Combo Driver and my problem is that i can play CDs. When i insert DVD its showing blank or no DVD in the drive. How can I slove this?
It is your lense related issue.
You can clean your lense with disk cleaner disk purchase disk cleaner disk and put in dvd rom then play it.then it clean your lense.
But if still problem remains then your lense has issue.
So if your dvd rom in warrenty then take it to service center and replaced it .
It is is not in warrenty then you need to repair or replaced lense.
Jul 31, 2009 | Computers & Internet
My dv s5770 (yamaha)takes a long time to read the disc, if it does at all. sometimes it plays, other times it stops and skips to the next track/chapter. It goes from reading to dvd to info on the display...
The lenses of your dvd has a dust on it. You need to buy a cd cleaner , or you have to open the dvd and locate the lenses. Clean the lenses using cotton buds with alcohol.
Jul 23, 2009 | Yamaha DV-S5770 DVD Player
Dvd combo not detect dvd's
Your Lense has some issue.
You can clean your lense with disk cleaner disk.
Pur chase it from nearest shop it is called "Lense cleaner disk"
then put it into combo drive then play it then it clean your lense then check .
If still not access your dvd then if it is in warrenty go to service shop they replaced it.
And if it is not in warrenty then you should need to repair your lense or purchase new lense.
Thanks
Jul 22, 2009 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Dvd player is unable to read cd showing NO DISC
You can try resetting the setting to the factory specifications. To do this on your remote push the setup button. Use the up and down arrows to find highlight preferences. Press ok to enter the sub-menu. Once in the sub-menu use the up and down arrows to find default. highlight this and press ok. Then press the setup button to exit. This will restore the factory setting and hopefully the full use of your player. If this fails to restore the operation of you dvd player, you can try using a lens cleaner and see if the dvd compartment needs cleaning. You can do this with a can of compressed air. If you need to clean the dvd lense use a cotton swab and a small amount of isopropyl alcohol.Apply a small amount of the alcohol to the tip of the swab and gently rub it back and forth until the lense looks bright and shines. Use the other end of the swab to dry excess moisture from the lense. Also check the transport and see if it needs to have dust and debris from the tracks or gears removed. Use the same process with cotton swabs a small amounts of alcohol to clean it up. Once clean try playing a dvd. It should work fine. If not you may have another problem with the lense or motor. You can call Phillips customer support at this telephone number. 1-888-744-5477 they will be able to help you with getting service for you dvd player. I hope this information help you with your problem.
Mar 12, 2009 | Philips PET710 Portable DVD Player
Dvd player problem
check your lense condition it may need to be cleaned if there is any dust buildup.
Sep 27, 2007 | Daewoo DV-6T955B DVD Player/VCR
Daewoo DVDS151 DVD Player Logo
87 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
