Question about Technics Audio Players & Recorders
Fitted new belt now can only play 45s on 33 and can not play 33s cos too fast
  • 88 Answers
Suggest you disturbed something when replaceing the belt
Posted on Feb 08, 2010
I have an old record player. It was made in the 80's according to my mom. I have recently started to use it( it hasn't been used since 86). With the exception of 45s, the record player will only play side...
I must say I have never come upon a record deck that will only play one side of a good condition record!
The only action I can suggest is to replace the belt if it's a belt driven deck. Please make a note of how it fits before removing the belt. But why any record deck would treat a new record any different on one side than the other will be a mystery to any good engineer.
The only exception would be if the deck played one side good then played up on every other record. Till it's switched off for a while, then repeats this action.
The cause of this fault would be a part overheating the longer the deck is left on. When you stop it to turn over, the system fails. This is however more likely to happen on a direct drive turntable, not a belt driven one.
Aug 24, 2014 | Audio Players & Recorders
I have a Pioneer PL Z94 turntable that was working perfectly until belt snapped. Purchased new belt & stylus, fitted both, but when I came to play my records they speed up very fast on both 33 & 45. What...
The most likely cause is that the belt has been fitted in the wrong position.
If that is not the case, then you can look underneath the turntable at the base and see if you can see a speed pre-set (sometimes there are two, one for each speed). Turning this will adjust the speed. You might need a small screwdriver. Sometimes the hole for these pre-sets are covered with a sticker. If you find it, to get the speed right will be a case of trial and error. I find the best way to do this operation is to mount the turntable on a chair which has no seat in it. Thus meaning you can get to the underside while the disc plays.
Jul 16, 2014 | Audio Players & Recorders
Turntable has stopped working, possible belt stretch
I don't think it's likely that the motor is in trouble just by having the belt wrong. It would require more physical damage to cause the motor to play up. Having said that the motor could have been in trouble before you touched the belt. But you do need a new belt, all you need to do is measure the diameter of the belt in mm. You might also need to measure the width. To find a new belt put the words "turntable drive belt XXmm" into Google. You can add Crosley to the start, but many belts are universal. Your measurements don't need to be spot on with the diameter, so if you have measured it at say 95mm, a 90mm to 100mm belt will do the job. However fitting the new belt is a different matter. You need to know the correct way, or the speed might be wrong. I can't help you with the fitting of it, so you will need to check how to do it. Some makes have YouTube videos of the fitting. I would just look for Crosley and see if any look like your model.
If fitted correctly and there's a problem with speed still, then you should look more closely at the motor.
Mar 26, 2014 | Crosley Stack-O-Matic CR40 Turntable
45rpm spindle for model CR86
If you just have one spindle(a short one) and no automatic spindle(a long one) what they mean is that it will work with an LP directly, or by using a small round plastic that fits a 45 opening, you can use that in conjunction with the short spindle to play 45s. For more information or further questions, please visit my website an audioserviceclinic.com. Thank you.
Dec 14, 2013 | Crosley CR248 Turntable
Denon DP-61F Turntable Rotates Slower than 33.
The answer lies in that 33 button. The connections to the should be followed and investigated why it does play correctly when held.
Nov 10, 2012 | Denon Audio Players & Recorders
Convert 45s to mp3s - sound scratchy
Just check the connections to the cartridge on the Stanton. Make certain they fit and are correctly fitted. Also check or replace the stylus, if it is not new.
Jun 14, 2012 | Stanton T.92 USB Turntable
Need to make hole bigger on a 45 record
I am aware of jukebox mechanisms that would clamp down on the record, and if it detected a small-hole in the 7" disk, it would change the RPM to 33 1/3, and the large hole would mean 45 RPM.
However, if we drill down into the history of the development of the 45, we can see that it was developed as a replacement for the 10" 78 RPM disk. It was also intended to be played on a distinct 45 RPM player, and thus the large hole to discourage use on regular turntables.
Most of the 45s in the UK had a pushout centre (some round, some triangular). 33s didn't have this. Ex-jukebox records had the pushout pushed out, and clip-in new centres could be fitted
Mar 16, 2010 | Audio Players & Recorders
My audio-technica PL50 plays 45s at the wrong speed.
believe it or not not it probably doesn`t even play your lp`s at the right speed? Its probably because your drive belt has actually stretched? rubber belts do wear and maybe seek out a replacement drive belt?
try this company?
mailto:info@needledoctor.com
May 19, 2009 | Audio Technica AT-PL50 Turntable
Spring broken?
Solution #2 is correct. My Baygen Freeplay radio was running fast and mine had a broken belt. I could not find a belt on eBay. After hours of searching the internet, I fond a replacement belt at http://www.kenselectronics.com/lists/belts.htm I have the older large Baygen Freeplay radio without solar power and this is the belt that fit my radio... AV-SBS9.5 Replaces SBX9.5 & 1407-36 & SCX9.5 square 9.5 x .047" belt, Baygen Freeplay. Just search the website above... they also have a second size Baygen belt that might fit the newer Baygen Freeplay radios???
Feb 27, 2008 | Freeplay Energy BayGen AM/FM/SW Radio
42 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
