Question about Ovens
When the oven control thermostat dial is in the OFF position, the Oven On indicator light flashes on & off, then when I turn the the thermostat up, the oven elements do NOT get hot. In addition, at times the oven indicator light is always ON ( when thermostat is in OFF position ), at those times the top element works at constant FULL power, ( no thermostatic adjustment). This is a GE oven / range, the only 2 numbers I could find are : 164D2874P035 & 205C1992G073
    Sergeant:
    Champion:
  • 263 Answers
Your thermostat is bad most likely. These numbers are not model numbers. It might have a part number on the part itself, once you take the front panel of the oven apart.
oven repair in orange county, ca
appliance repair orange county, ca
Posted on Feb 08, 2010
Westinghouse oven 688 my oven wont turn off
Sounds like something has happened to your on/off switch that has caused contacts inside to stick in the on position. You will probably have to have it replaced.
Dec 04, 2013 | Ovens
Zanussi ZKC6040
You need a new thermostat control for the oven fan. That is what determines when the temperature of the oven is low enough that the fan is no longer needed. Based on your description, the thermostat has failed in the "closed" position which means that it is always supplying power to the fan.
Nov 05, 2013 | Zanussi ZDQ495 Electric Double Oven
SMEG OVEN BRAND NEW WON'T HEAT
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 08, 2012 | Smeg Ovens
I have an aeg d2100-4-m oven. main lower oven not getting hot. Have replaced element, to no avail.Fan and light in oven both come on, but have noticed that the temperature dial light is not illuminating....
Hi .
Sounds like the oven thermostat is faulty.,
This gives a supply to the element .
The temp indicator should be lit, if it is not, then I would suggest repl;acing the oven thermostat.
Sep 28, 2011 | AEG D2100-4 Electric Double Oven
How do i turn on a white atlas ceramic electronic oven, the ceramic top is working,but the oven screen flashes from"0:00" to "auto" when i try and fiddle round with the oven...
Turn the oven control on. Now play with the buttons on the electronic timer/clock. Try all different combinations. Trying pressing them at the same time. This may take 5 minutes or more. If the timer is not faulty this will work, be patient. When the oven indicator light comes on the oven is on and the timer is now in manual mode.
Feb 25, 2011 | Ovens
Lower oven will not come on. Top oven and cook top works
Does the oven indicator light come on when you turn the oven on. If it does the oven element or the wiring at the oven element terminals will be faulty. If it does not come on it will most likely be a problem with the oven control thermostat.
Feb 24, 2011 | Ovens
Oven heats up when power to cooker is turned on ( dial is at off position)
It sounds like the oven thermostat/regulator is faulty, or the dial is not turning the switch off properly, this could be caused by the dial being cracked or broken.
Pull the dial off, and try the switch with a pair of grips or pliers to make sure it is completely turned off.
If it is, then the you need to replace the switch or thermostat as the case may be.
Hope this helps.
Please rate my solution.
Thankyou.
Jan 08, 2010 | Hotpoint Ovens
I need an owner manuel for Caloric Range Model # EST 345 I can'g figure out how to run the self cleaning oven cycle.
you might try the following, although it is the instructions for an old model, it may be relevant;
"The actual self-cleaning process is initiated by a simple 5 step procedure: 1. Set the range clock to time of day. Note: on models not equipped with an automatic oven timer, the self-cleaning cycle is preprogrammed for a 21/2 hour cycle. Use Steps 3, 4 and 5 only. 2.Establish the length of cleaning time by:
A. Setting the start time. Press and turn the start dial of the automatic oven timer clockwise to the desired starting time. B. Set the stop time. Press and turn the stop dial of the automatic oven timer clockwise to the desired stop time. Max time is 3 hours miniumum 1/12 hours. 3. Set the oven selector dial on the control panel to "Clean" 4. Set the temperature control dial to "off". If you temperature control dial has a "Clean" position, then set the dial to "Clean" instead of "Off". 5. Remove oven racks, broiler pan and broiler grid from lower oven. Close and lock the oven door by moving the latch lever as far right as it will go - into the locked position. If the lever is accidently dislodged restore it to the locked position. Otherwise, the self-cleaning process will not take place. Shortly after the cleaning cycle has begun, the oven temperatur reaches a degree in excess of the normal broiling temperature. The red "Clean" light will come on and the clean cycle will start. In a few minutes the door lock lever, which you have placed in the locked position, will automatically be secured to prevent the oven door from beging opened during the cleaning cycle. This latch remains locked until the clean cycle is complete and the oven temperature reduces to normal baking and broiling temperaturs. NOTE: Prior to self cleaning cycle operation, the oven and surface lights must be turned offed. The upper oven can be used."
I found this here; http://www.appliance411.com/archive/21155_caloric_oven_lost_cleaning_manual.shtml
Nov 18, 2009 | Ovens
Pizza, banana bread, etc. doesn't get done in the middle.
some oven temperature dials are adjustable by pulling knob off,turning a bit and pushing it back on in a different position.use an oven thermometer to determine the accuracy of your control knob.adjust knob or make note of difference between dial setting & thermometer reading.i.e.knob is at 350* thermometer says 300* set knob to 400* to achieve an oven temp of 350. could you E-mail me a slice of banna bread?
Sep 27, 2009 | Ovens
I have a Competence 52081 double oven. Ity has
Thermostat may need adjusting OR air may be entering the oven causing the problem
Sep 01, 2009 | Ovens
Ovens Logo
140 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
