Question about Kenmore Dryers
I have a 400 series kenmore model 110.77432600. not heating up after 60 min cloths are still wet.
  • 2692 Answers
SOURCE: Manual for a Kenmoore 60 series soft heat large capacity dryer.
Here is the website for Kenmore driers and the manuals to download for free in Adobe format. They are only listed by model number.
http://www.kenmore.com/shc/s/search_10154_12604?vName=Kenmore&cName=Washers+%26+Dryers&keyword=kenmore+drier&sLevel=0
Posted on Dec 22, 2008
jsrock516
  • 5911 Answers
SOURCE: No heat
If the burner assembly is not lighting I would recommend you look into an igniter replacement. If the igniter is worn, or does not work at all, the gas safety valve will not open and you'll never get ignition. The part number is 279311.
If the burner assembly lights, then goes out after a few minutes, I would recommend you replace the gas valve solenoids. There are two of them on the burner assembly. It is recommended that you replace BOTH of them at the same time. The part numbers are 69540 and 69539. Searspartsdirect.com has an excellent illustration of your dryer. Just type in your model number and look under the "Burner Assembly" heading. The igniter is listed as item 4. The solenoids are items 13 and 14.
If you have questions, please let me know. I hope this is helpful to you.
Posted on Mar 03, 2009
  • 686 Answers
SOURCE: Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Posted on Apr 06, 2009
  • 105 Answers
The most likely cause is a bad ignitor part number 279311. It has to glow to open the valve and ignite the gas. You should hear a loud click when you first start the dryer. That tells us there is voltage to the gas valve.
Posted on Apr 07, 2009
  • 18 Answers
SOURCE: My Kenmore Series 400 dryer spins & heats, but
Check the outside vent again while the dryer is running. There should be a good strong air flow, if not then your problem is in the exhaust system somewhere
Posted on Jun 21, 2009
Kenmore model 90 dryer electric will dry the clothes takes a long time. Leaves the floor surrounding the dryer damp actually wet just not puddled
Are the clothes wet AND hot? If so - check the exhaust / vent hose for kinks or obstructions. That includes the cap / flap on the outside of the house.
If the clothes are wet AND cold, then the electric heating element isn't heating likely due to a broken or poor electrical connection, burned out heating element, defective thermostat, etc..
Jul 14, 2015 | Kenmore Dryers
Kenmore 400 series gas dryer doesnt dry clothes
Replace timer, if you are sure that it is not working.
Do an internet search for kenmore driver parts and get dozens of hits.
Aug 03, 2014 | Kenmore Dryers
My kenmore 60 series gas dryer stopped drying clothes.
Check for restriction in lint chute, blocked exhaust tube, plugged lint screen
Feb 12, 2013 | Kenmore Dryers
I have a Kenmore 500 series dryer, model number 110.79522800 that will note completely dry clothes. It seems like it doesn't run long enough, heat high enough or a combination of both. What can I do to...
Your Sensor that senses the clothes are wet or dry is shorted out. The dryer works likes this so the dryer heaters dont stay on while the clothes are dry. When the sensor senses the clothes are damp or wet, the heater stays on, when they start drying the sensor senses it and starts to turn down the heaters
http://tlc.howstuffworks.com/home/dryer6.htm
Mar 10, 2011 | Dryers
It takes 50 min to dry a load of clothes in my 400 series electric dryer can you tell me the problem. I checked the exhaust it looks clear thanks.
It could be heating problem and best way is to check for continuity in heating element and sensors and thermostats and limiters and thermistors in the dryer
Nov 17, 2010 | Kenmore 400 6943 Dryer
Dryer not heating up
Ignitor may not be working, or gas valve is not opening.
Apr 30, 2010 | Kenmore 73952 Gas Dryer
My Kenmore 400 series is taking too long to dry
Make sure the vent and tube are clear and not blocked in any way, if clear try washing off the lint screen with hot water, softener will clog the filter
and not allow proper air flow, water will bead up on screen if this is true
Oct 27, 2009 | Kenmore Dryers
I have a kenmore 400 series dryer model no heat
Srart by pulling each thermostat wires and tape them together until you find the bad one. You should have 3 of them to test.
Oct 25, 2009 | Kenmore Dryers
My Kenmore Series 400 dryer spins & heats, but the clothes stay wet. I've cleaned the lint basket & have checked the vent from dryer to outside. Any suggestions?
Jun 21, 2009 | Kenmore 73952 Gas Dryer
Dryers Logo
175 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
