Question about Logitech Cordless Internet Handset Phone
Using Cordless Internet Handset with MSN Messenger
I am trying achieve the above.
The handset comes up as an option for speakers and microphone. I cannot hear sound when I run the sound test, I assume that the phone must be set to receive this but cannot work out how.
I can set it as the microphone but can only get it to register once I have pressed the dial button, after a few seconds however I get the incative tone!
Hopefully you can offer some assistance.
Many thanks in advance for your efforts!
  • 3 Answers
If you're running the sound test through Skype's options and you click on the make a test call option, then you won't hear anything through the handset. I had the same problem and I spent a few hours trying to figure out why it wasn't working. In the end I found out it was actually working all along.
What you need to do is add the Skype contact echo123 to your contact list. It should be the first one in the list from the United Kingdom.
Once that's done you should be able to bring it up on the contact list through Skype and initiate the call through the Handset at which point it will work properly and you should be able to speak to and hear the test call. That was the only way I was able to verify that it was in fact working properly.
Posted on Apr 08, 2008
Unmute handset
Mute Microphone
With the handset
You can temporarily turn Off the microphone so that the person you are talking with cannot hear you.
1)Press menu/del during talk mode (while phone is in use).
2)Press ring/vol/? or ring/vol/? to move the pointer to Mute and then select/
Mute On and appear in the display. To cancel muting, repeat above step again when Mute
is set to on, Mute Off appears.
With the base
While using the base speakerphone, press mute on the base to turn Off the microphone.
Press mute again or press (speaker) to cancel muting.
Jan 01, 2015 | Uniden Lands Phones
The handset is unable to receive calls via Skype,nor am I able to make calls via Skype Handset says Disconnected
If you use windows vista, and installed windows live messenger, you wil have alway`s this problem, solution is, dont let msn start up with your pc.
The best way, under software remove msn messenger, and install again en dont let it start wen your pc start up. skype and msn dont working together.
i hope your problem is solved
Feb 08, 2010 | Logitech Cordless Internet Handset Phone
Since upgrading to Windows 7 my phone does not work
uninstall windows live messenger restart and your phone should work again, i installed the handset using the vista installation files no compatabilty changing at all but for some reason the handset does not like windows live messenger!
Nov 08, 2009 | Logitech Cordless Internet Handset Phone
Hand set out of range disply is on. How do I reset.
here are some tips from my manual for out of range problems
hope they help
• Only one handset can be used to make or answer a call anytime.
If another handset attempt to do so, the screen will display OTHER
HANDSET ON and then OR OUT OF RANGE. You might press PHONE
or SPEAKER again until no other handset is using the line. Use the call
transfer feature to transfer a call to another system handset
or use the speakerphone feature so multiple members of your
house can be on an active call at the same time.
• Move the cordless handset closer to the base. You might have moved
out of range.
• Ensure that the base is powered up.
• Place the cordless handset in base cradle for 1 minute to allow the
cordless handset and base to resynchronize channels.
• If the cordless handset is in its base and the charging light does not
come on, refer to the charge light is off in troubleshooting guide.
• Reset the base. Unplug the unit’s electrical power. Wait for 15 seconds
then plug it back in. Allow up to one minute for the cordless handset
and base to reset.
• Other electronic products can cause interference with your cordless
phone. Try installing your phone as far away from these types of elec
tronic devices as possible: wireless routers, radios, radio towers, page
towers, cell phones, intercoms, room monitors, televisions, personal
computers, kitchen appliances and cordless phones.
Jul 16, 2009 | GE 29897GE1 Corded Phone
My logitech webcam chat has no sond!!!!!!!!!! before when i recorded videos i had sound played when i recorded, and my mic works i tried it on another program and it works.
The information in this article applies to the following 3rd party software
MSN Messenger 6.x
MSN Messenger 7.x
Window Live Messenger 8.5
The information in this article applies the following platforms
Windows 98
Windows ME
Windows 2000
Windows XP
Windows Vista
Note: The information in this article is not product specific. For details regarding camera driver and operating system support please see article 3428
Step 1: Getting Started
Before we begin setting up the sound in MSN or Windows Live Messenger, ensure the following is complete:
  • Connect your camera and verify that it is working properly
  • If using headphones, verify that your device is connected and functioning
  • If using speakers, verify that they are functioning properly
  • If using a headset, verify that both the headphone and microphone are connected and working properly.
Step 2: Executing the audio and video setup procedure within the messenger application
This procedure will allow you to assign an audio input and audio output device, as well as assigning the video device of your choice to work with the messenger application. The following example uses Windows Live Messenger 8.5 however, the same procedure can be used for earlier versions of MSN Messenger 6.x and above. MSN Messenger users please skip directly to step 4 below.
Note to Windows Live Messenger users: There are multiple ways to execute the following steps depending on being signed in vs signed out of the messenger application, and which version of Windows Live Messenger is being used. To avoid confusion, please execute the following steps while signed out. We also recommend updating to the latest version of Windows Live Messenger.
1. Sign out of your account.
2. Launch the messenger application (make sure you are not signed in to your account).
3. Locate and click the "Help" drop down button towards the top right corner and select "Show the menu bar"
16480.gif 4. Now click the "Tools" option in the menu bar and select the “Audio and Video Setup” option.
5. Click “Next to begin the setup process.
6. In the “Speaker Setup” window, select the output device you would like to use with the messenger application. This step is specific to speakers or headphones. If your speakers or headphones are USB devices and connected to your computer, select the device by using the drop down menu provided. If your speakers or headphones are connected to your soundcard, the device listed will be the make or model of your soundcard device.
You can also set the desired volume level and click “Play Sound” for an audio sample. Click "Next" once you are comfortable with the your selected options.
7. In the “Microphone Setup” window, select your desired input device from the drop down menu provided.
3172_msnad04.jpg This selection will be specific to a microphone connected to your computer. If your Logitech video camera has a built-in microphone, this option will be presented as “Logitech Mic” with your camera model name in parentheses as shown above.
If you have an external USB microphone or headset device connected to your computer that hosts a microphone, select the devices name or model number in the drop down menu. If your external microphone or headset is connected to your soundcard, the device listed will be the make or model of your soundcard device. Once your device is selected, adjust the microphone volume level to your preference and click next.
Note: The microphone volume level may need to be tested in order to find a comfortable volume level. As a starting point, try setting the level midway and adjust when necessary by re-executing this procedure.
8. In the “Webcam Setup” window, select the video device you would like to use with messenger application. Once selected, you should see a display sample in the window provided. You can also click the “Options” button to make camera specific adjustments. Once completed, click the “Finish” button to apply your changes.
Once you have completed this process, the messenger application should now be configured to the correct audio input (microphone), audio output (speakers or headphones), and video device (webcam) to use when engaging in an audio and or video conversation.
his article covers how to configure a Logitech camera's audio and video settings to work with Skype 3.6 or above. trnsp.gif Answer This article applies to the following cameras:
All Logitech USB Webcams
This article applies to the following platforms:
Windows Vista
Windows XP
This article applies to the following 3rd party application:
Skype™ 3.6 or above
To set up Skype for video please be sure that your Logitech webcam is connected and working. This can be verifed by launching your QuickCam software and checking for a video stream withinin the QuickCapture video window. Once the webcam functionality is verified, please close the QuickCam application and follow the steps below.
  1. Launch Skype™ and click on "Tools" as shown in the figure below
    Fig 1
  2. When you click on "Tools" you will see a drop down list
    Fig 2
  3. Click on "Options" at the bottom of the drop-down list
    Fig 3
  4. A new screen appears. Click on the left side of the pane under "Video Settings"
    Fig 4
  5. Under the "Select webcam" drop down, please choose your Logitech camera, then click the "Save" button.
    Fig 5
  6. Click on "Tools" as shown in Fig 6 to get your Logitech Audio setup.
    Fig 6
  7. When you click on "Tools" you will see a drop down list
    Fig 7
  8. At the very bottom of the drop down list, please click on "Options"
    Fig 8
  9. When you click on "Options" you will see a new screen
    Fig 9
  10. On this new screen click on the left side of the pane under "Audio Settings"
    Fig 10
  11. You will now have the option to select your Logitech camera's Microphone as your main Audio source. Under the "Microphone" drop down, select the Logitech Microphone, and click "Save"
    Fig 11
  12. You should now be ready to use your Logitech webcam and microphone in a Skype video call.
Aug 11, 2008 | Logitech Quickcam Chat Webcam
You advice was such a blessing
Haven't experienced this one, it should open if you right click on the icon in the tray at the bottom.
However you should still be able to change your Skype options, click on "skype", then "Tools", then "Options", then "Audio Settings", change microphone and speakers to "logitech" or whatever your computer has listed your device as. This should have the effect of changing logitech to "use handset" and gets the same result. Unfortunately the phone will never work as good as it should, for instance I can't make test calls. I hope this helpful.
Jun 13, 2008 | Logitech Cordless Internet Handset Phone
Logitec web cam
You will be required to run an audio setup wizard through the messenger application in order for MSN or Windows Live Messenger to recognize sound using a microphone and produce sound through speakers, headphones, or headsets.
The information in this article will describe the correct procedure to setup audio and video within the MSN or Windows Live Messenger application to achieve proper audio functionality.
trnsp.gif Answer The information in this article applies to the following 3rd party software
MSN Messenger 6.x
MSN Messenger 7.x
Windows 98
Windows ME
Windows 2000
Windows XP
Windows Vista
Jan 24, 2008 | Logitech Webcam
Mic
First, be sure to have the latest software from logitech's website, and the latest MSN.
Then perform the following:
Execute the audio and video setup procedure within MSN Messenger 7.5. This procedure will allow you to assign an audio input and audio output device, as well as assign the video device of your choice to work with MSN Messenger.
1. Launch MSN Messenger and select the “Audio and Vide Setup” option from the “Tools” menu.
Figure 1
2. Click “Next to begin the setup process
Figure 2
3. In the “Speaker Setup” window, select the output device you would like to use with MSN Messenger. This step is specific to speakers or headphones. If your speakers or headphone device is connected to your computer, select the device by using the drop down menu provided. You can also set the desired volume level and click “Play Sound” for an audio sample. Once you are comfortable with the your selected options, Click “Next”
Figure 3
4. In the “Microphone Setup” window, select your desired input device from the drop down menu provided. This selection will be specific to a microphone connected to your computer. If your Logitech video camera has a built-in microphone, this option will be presented as “Logitech Mic” with your camera model name in parentheses as shown below. If you have an external headset device connected to your computer which hosts a microphone, select the devices name or model number in the drop down menu. Once your device is selected, adjust the microphone volume level to your preference and click next.
Note: the microphone volume level may need to be tested in order to find a comfortable listening level for you contacts. As a starting point, try setting the level midway and adjust when necessary by re-executing this procedure.
Figure 4
5. In the “Webcam Setup” window, select the video device you would like to use with MSN Messenger. Once selected you should see a display sample in the window provided. You can also click the “Options” button to make camera specific adjustments. Once completed, click the “Finish” button to apply your changes.
Figure 5
6. Once you have completed this process, MSN Messenger should now know the audio input (microphone) audio output (speakers or headphones) and video device (webcam) to use when engaging in an audio and or video conversation.
Jan 07, 2008 | Logitech QuickCam Express Web Camera
Logitech Cordless Internet Hnadset Phone on VISTA! for SKYPE
Handset shows DISCONNECTED.
On Logitech support page lookup document 6674 (search).
Boot computer with minimum og services and programs running.
Start Logitech handset program - this starts skype.
the handset will disconnect.
As soon I start the new LIVE MESSENGER BETA - the hanset disconnect.
Therefor I installed a msn messenger extension in Skype extras.
This gives me the opertunity to use msn messenger without using the LIVE MESSENGER PROGRAM - if I do - Logitech Handset will not work.
Sep 06, 2007 | Logitech Cordless Internet Handset Phone
Logitech Cordless Internet Handset Phone Logo
118 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
