Question about Samsung CLP 300 Laser Printer
The printer either works, or it doesn't. When it
Re my Samsung CL-300: The printer either works, or it doesn't. When it does not work, the symptom is an immediate "clunk" noise, at which point the red light comes on. There is no evidence that the printer even "attempted" to pick-up a sheet of paper. Nothing that I do resolves this problem. Sometimes I can get the printer to work by turning it upside down, removing the paper tray, "jostling" the main feed roller, and then putting things back in place and starting it up. But, this does not work consistently, and the "fix" may last only three or four pages before it reverts to the non-functional condition. Printer is lightly used, very clean, no paper dust, etc. Feed roller is like new, very clean. This printer has printed only 1250 sheets of paper in its lifetime (2 1/2 reams).
Bit late, but did you solved the problem? have the same issue now.. :-/
Posted on Dec 11, 2011
  • PowerSchlumpf Dec 11, 2011
    bit late, but did you solved the problem? have the same issue now.. :-/
  • Steve B
    Steve B Apr 09, 2014
    Had same issue - try emptying the "waste" container.
It's sounds like something is getting loose as printer attempt to print, check all the door, are any of the door becomes loose as printer try to print ?
Vinay
Posted on Feb 09, 2010
Fix samsung clp300 printer
I played around with mine for a few weeks and could not find a simple fix. The printer was GREAT, until it wasn't. Repair cost was more than replacement, so it was time for a new printer. I sold my extra ink carts on CL. Sorry this isn't much help....
Jan 23, 2015 | Samsung CLP 300 Laser Printer
I have a Samsung CLP-325W. I set mey own password and user, and now its not letting me in thrugh web app. And Samsung say that I have to delver my laser to a repair centre to reset password and user!
Try using username admin and password sec0000
Those are the defaults according to my owner's manual
If that doesn't work, try:
username admin and password admin
username blank (don't enter anything) and password as the last 8 digits of the MAC address, found on the back panel of the printer.
Aug 09, 2011 | Samsung CLP 300 Laser Printer
Printer connected to a Asus router RT-n56u via usb port System with Windows 7 Ultimate 64Bit Usb port enable through Asus Printer Utility Driver select (auto) during installation SAMSUNG UNIVERSAL PRINT...
I'm having the same issue with the same router and printer (mine is CLP-300/XXA).
At first when I try t print a pdf file or an image or any text/word document file with pictures/images I get an SPL-C error.
I have upgraded the firmware and it worked great on my laptop! Then, I tried to install the printer driver on my desktop, but now none of them work correctly.
Still not solved, but here are some suggestions:
1. Try to upgrade the firmware. 2. Try to install the original samsung printer driver 3.0.1
3. If it didn't work try to install the updated driver 3.0.4 4. If it didn't work try to install the Universal Printer Driver
5. IMPORTANT: between uninstalling and installing driver, disconnect both printer and router A/C power adapter and try to reboot you PC after removing the previous driver!
I'm going to work on it and see if it works. The DD-WRT firmware solved the exact same problem on my previous RT-N13U router, but unfortunately DD-WRT doesn't support RT-N56U yet!
Note: I called ASUS and they told me that Samsung printers are not supported for printer sharing server :(
Jun 19, 2011 | Office Equipment & Supplies
My Samsung CLP 300 seems OK, but when it is instructed to print, the red light starts burning. If I order a test run from the stop button I get the same result. There is no paper jam and the printer was...
Hi, if the red light is on and one of the colors light is on too.
that means that that toner is empty. if the main light is blinking, it means that that toner is low.
please check your user manual on page 6-8..
The printer will stop with an audible "clunk", and the symptoms above if the used toner container is full.
mine is the same way, to solve this I elevated the bottum by 2 inches, then i kept it off, also i blow a fan on it while running.
also, you need to clean the filter (the gray "L" inside) black dust should come out.
lastly, mine actually broke because it overheated.
Thanks fro using fixya...
Nov 01, 2010 | Samsung CLP 300 Laser Printer
How it (CLP_300) fit with Windows7 OS and what have to do when old CLP-300 and new Computer with Windows7
Go to
http://www.samsung.com/us/consumer/office/printers-multifunction/color-laser-printers/CLP-300/XAA/index.idx?pagetype=prd_detail&tab=support#
click on 'drivers', then download the 3.03 driver, it should work with win7.
Jun 11, 2010 | Samsung CLP 300 Laser Printer
Samsung CLP 300 Printer
smasung clp300
just clean toner weast chember and also drum unit.
sometime if u user refilled cartridges after use this u have facing this porblme.
pl do this it work perfect.
www.howtorefill.com
Jun 02, 2010 | Samsung CLP 300 Laser Printer
Samsung CLP-300 printer is not recognized by new MacBook
Thank you for mentioning it, I can't believe it was the reason. It worked! Fabulous! I put about 8 hours figuring it out.   M.L.
Dec 07, 2007 | Samsung CLP 300 Laser Printer
Samsung CLP 300 Laser Printer Logo
126 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
