Question about Konica Minolta magicolor 2430 DL Laser Printer
HI. I haven't used my printer for a few months,all catridges are very healthy but Nothing on paper when printed. Any ideas
  • 164 Answers
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 08, 2010
When i print from my computer to laser printer, it just printed nothing. When i put paper and print direct from the printer, it did the same thing. I can still do it as scanner, but just can not print. No...
Ibuy A EPSON T-60 printer,i month ago,i use refil ,but i need daily head cleen,blue ink print iresult is not good,becuse,daily head clinig must,If daily head clean my printer can damage?
i am bangladshi, what refil drum is good for epson t 60.what is name?
Thak you SIR.
Sep 21, 2011 | Epson TM-T60 Printer
We have HP3210 all-in-one printer. It went unused for two months and during this time, I knew the black cartridge was out, so I finally bought one. Now - it doesn't print anything but a very light...
Cartrideges might be dried up.. how ever you have to replace the catridges... Try try do this tip..Take cup of little bit warm water(not too hot).. Dip catridge nozzles(take care water should not touch the contacts) up to one minute, shake the catridge, place on tissue paper verify weather ink spreading in tissue? repeat this process twice clean the cartride, place in printer then try... ensure that it's only tip...
Sep 12, 2011 | HP Photosmart 3210 Printer
My toner is printing few lines darker and few lines lighter
remove ink catridge and wipe with dry cloth ,replace catridge and print test sheet if its still doing the same ,ajust the paper intake this shoulf solve the problem goodluck
Mar 26, 2011 | HP 12A Toner (Q2612A) Printer
When i press print, the goes through the motoins but nothing is printed on the piece of paper, and there is plenty of ink the catridges, any ideas??????
Hi with your Epson machine normally its the print head that has dried up and the ink is not able to get on to the paper have you used the head cleaning on the machine? this can help and some people claim that using head cleaning liquid works (I have not found them to be much use)
if you have tried all the above then its down to replacing the print heads and this is not for the DIY person and in the Uk it usually not an economical repair
sorry Ian
Mar 15, 2011 | Epson Stylus CX6600 All-In-One InkJet...
HP842C continues to print with nothing on the paper but a line across the top of letters and numbers. The orange light will not go off. There was a paper jam which I removed then paper continued going...
Check your Catridges, they might be dried up if new, or empty, Remove them shake them to feel a presence of ink or tap them on a piece of paper to verify if ink will comeout if not then they are empty and need to be replaced they they have a bit of ink you need to shake and try printing again if this persists change the catridges, also make sure that the Printer is Clean, verify the Catridge Carrier for any dry ink deposits.
Dec 03, 2010 | HP DeskJet 842c InkJet Printer
Epson pro 4800 r prints grey not blank and says to set cartridge
I am having the same problem If anyone has an answer or whether judy you have found an answer.
If I do a greyscale strip to print my black is coming out as a dark grey. the bead off of the greyscale strip would appear that the pbk photo black is not actually printing.
This has been a problem for a few months but as I haven't been doing much printing didn't notice it just thought something was odd. Now I look at previous prints and the blacks are black I print it out now and it is a dark dark grey. Nothing has changed in my profiles or my workflow. I have tried hours of profile paper printing option changes and workflow adjustments but nothing changes, If I print 100 percent black from a file it comes out 95% grey I have tried it from three computers to clarify. It appears is a 4800 problem.
Perhaps it is not recognising that it is a PB catridge.
I have no idea.
I have tried adjusting the settings from the printer but there is no option to clarify catridge from the printer.
This is odd, if anyone has any idea.
Mar 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
Printer is not at all taking the paper to print
Pull open the front of the printer
remove the toner cart
clean the gray rubber roller with alcohol
Feb 01, 2009 | HP LaserJet 1100 Printer
Problem printing - Epson stylus photo 895
1 bring out the catridge of the printer to clean and make sure the ink flow during the cleaning.
2 insert and reset the catridge.
Oct 11, 2017 | Epson Stylus Photo 890 InkJet Printer
Not printing
hi sand;
you may try cleaning the copper in your cartridge with tissue paper and also the pins in the printer but do it slowly, and see if it works
thanks
Jun 05, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Ink not printin on paper
I have had the same problem although my colour ink works beautifully but no black ink??
Mar 10, 2008 | Lexmark Z615 InkJet Printer
Konica Minolta magicolor 2430 DL Laser Printer Logo
93 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
