Monitor not working.
Motherboard was replaced. Need to re-install operating system. Monitor does not work when connected to PC, but works when cable is removed.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 61 Answers
Graphics incompatibility is the issue you are facing. there comes a converter for monitor cpu-end of lead by the connection of which u connect it directly to an external VGA.... try using that
Posted on Feb 08, 2010
Power but no display
THE EXTERNAL WORKS ? IF YES MAYBE IS YOUR INVERTER DISPLAY DEFECTIVE. IF NOT YOU HAVE PROBLEM WITH YOUR CHIP GRAPHICS ON MAINBOARD AND NEED REPLACEMENT
Oct 21, 2013 | NEC Versa Computers & Internet
No display on monitor
* verify if all cables are properly connected.
* Perform monitor self test by unplugging the video cable (ex.VGA) from the monitor, if you see colored bars showing on the monitor that means your monitor works fine but if there's NO colored bars showing on the monitor that means the monitor needs to be replaced.
* Go to safe mode, if successful, perform system restore. If system restore fails, run hardware diagnostic by going to F12. If no failure found, perform pc restore, if it still fails-you can reinstall you operating system.
*If all fails, you can contact your manufacturer.
***PLS NOTE that performing PC RESTORE and OPERATING SYSTEM REINSTALLATION will cause DELETION of DATA. IF YOU HAVE IMPORTANT FILES, BACK UP YOUR FILES FIRST BEFORE DOING the suggested resolution.***
Jun 04, 2011 | Intel D865GBF Motherboard
Screen is blank. Computer is switched on.
This is probably due to a video card failure. It could also be a ribbon that connects to the motherboard for the LCD monitor. You can remove the keyboard and find the strip that connects the lcd screen to the motherboard. Not too much info but thats a start...
Jan 28, 2011 | Toshiba NB205-N210 Netbook
My computer monitor says no signal
Check the monitor cable between the Desktop and the monitor. Remove it and reattach it. If you have another system try connecting the monitor to it to make sure the monitor is working correctly. If you have a spare monitor cable, use it to test the monitor. If both the cable and the monitor seem to be working correctly, you have a failed video board or video section of the motherboard.
If you have a add-in video board, remove the video cable and connect it directly to the video monitor jack on the motherboard to eliminate the video board as the failed component.
If you do not have a add-in video board, you can try a add-in video board or replace the motherboard.
Let me know if you have further questions. Thanks.
Oct 22, 2010 | Computers & Internet
Attempting to install tft lcd monitor on new processer, have intall disc, but monitor will not come on ????
Hello.
Be certain that the install disc software works with your operating system. What specific monitor and your operating system (Windows 7, etc.).
Also, be certain that the monitor cable is connected to a USB port. Try another port.
When you said "not come on" do you mean no power or a dark screen ?
Try your monitor on another PC to see if monitor problem.
Hope this helps.
Jul 20, 2010 | Gateway Computers & Internet
I have asus p5p800-mx mother board morboard working fine and also start but on monitor no display and i also try to install additional graphics card then also no display
Have you tested the monitor to see if it is working? Is the vga cable good? Are you getting the BIOS start-up display screens when computer is booting up or no display at all? It is odd that both the on board video and video card would be bad I would double check the cable connection and the monitor. If the cable is good and the monitor is working properly than the board might be bad. You should at least get the BIOS start-up screen display.
Sep 07, 2009 | ASUS P5P800-MX Motherboard
Monitor on HP Pavillion a656x---blew up the power supply--had an extra and installed it--when machine was turned back on--monitor displays "VIDEO CABLE CONNECTED?---what am I going to do----help!!!---
First thing I would do is try the monitor on another system to see if it's in the monitor or computer. Next would be to fire it up and see if you hear a beep from the motherboard. Most consumer pc's will come with a small speaker that sounds on startup. If you don't hear this beep it could be indicitave of a fried motherboard.
But it sounds to me like your video card or onboard video was messed up when the power supply conked out. If it's onboard video you may be able to switch to a video card. If it's a video card you may need to replace it.
Also check to make sure there are no loose wires, that your video card is seated firmly, and that your connectors are all snug. If none of this works then you're most likely looking at a motherboard replacement.
Apr 19, 2009 | Computers & Internet
Intel d845,one long 2 short beeps video problems
hi im josh in cebu phils.may i help you? friend try to use this solutions of mine surely it will help you.
Your PC uses beeps to communicate with you when something is wrong with the video setup. Check the settings on your video card to make sure that they're correct for your system. Also check any switches on the motherboard to make sure that they're set up correctly for your type of video card. (You should consult your system's instruction manual for details on this procedure.) Check to make sure that your video card is seated properly in its slot; you may even want to try inserting the card in another slot. If none of these suggestions works, try a new video card, or have your system examined by a professional.
In a pre-Windows 98, system, if you have two video cards installed at the same time, they can sometimes interfere with each other and cause neither to work properly. Try removing one of the cards; if this results in the remaining card working, you need to reconfigure one or both of the cards to better work together. (With Windows 98 and later you can install two video cards to run multiple monitors simultaneously
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} THE COMPUTERS SEEMS TO BE WORKING, BUT THE SCREEN IS BLANK.
- Check the monitor if turned on.
- Check all the LED power on the monitor, if it has one.
- Adjust brightness and contrast controls all the way to the maximum.
- Check the video cable from the monitor to the computer to be sure if it is properly connected.
- Check the power cable. If it is connected properly at both ends.
- Try different monitor on your computer. If it does not work, the display card is likely at fault. Replace the display card.
Try your monitor on a different computer. If it does not work, replace the monitor or have it repaired by a trained technician. Just try friend it will help you Good luck.
Mar 05, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
No video output on Intel D915GEVL motherboard with Intel GMA900
hi there
if you would power down the computer and the monitor and unplug the cord going to the pc from the monitor and the power cord for the computer,,, now open up the case and find the powersupply cable going to the motherboard and unplug it now preess the computers on button than the reset button .. this will discharge any esd than wait 3 min and plug it back in than connect the monitor to the pc and plug in the power cord for the pc and monitor and turn on the monitor and you should get a messzage that the monitor is working now turn on the computer and see if it works let me know how this works ok
best regards mike
Feb 22, 2009 | Intel D915GEVL Motherboard
Cooked motherboard
Personally, I've never seen a monitor damage a motherboard. Since monitors have their own power source, the HP answer of the monitor "drawing too much power" is bogus.
Possible failures could include the following:
  1. Failing Power Supply - if you haven't tried a different power source, then that is the 1st thing I'd look at, expecially if another system will run the monitor.
  2. A peripheral item, (Keyboard, Mouse, Printer, scanner or other USB device is preventing POST completion of boot completion.) try booting system with just video and power, nothing else.
  3. Check the monitor cable for bent/broken pins. I have seen bent pins on a cable connection short out a video card, this could cause a no post if the video is integrated.
  4. I just reviewed the HP site on this system, and it appears to ship with a PCI-E video card. It appears most likely that the Video Card (If one is installed). If you have the PCI-E video card in system, remove it, and connect to the intergrated video connection and see if ystem posts.
Feb 08, 2009 | Envision 19" Widescreen Flat Panel LCD...
Computers & Internet Logo
David Payne
David Payne
