Question about Toshiba PDR-M25 Digital Camera
Lens no longer retracts.
I have a Toshiba PDR-M25. When the camera is turned on the lens automatically comes out and when turned off it retracts. Yesterday, the lens stayed out and I can no longer focus or take a picture. When it turns off the lens stays out.
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Feb 08, 2010
WHY ARE MY PICTURES BLURED IN THE CENTWER?
Dis you check the front lens? is it still clean and shiny?
Only clean a lens with a lens pen or tools special made for lenses. Normal cloth, and paper for sure can scratch the lens. The coating on a camera lens is very delicate and needed for the quality of every shot.
Feb 12, 2014 | Toshiba PDR-M25 Digital Camera
I need an owners manual for a digitAl Toshiba camera PDR M25. Can you help?
This camera came out in 2001...Even Toshiba doesn't have a manual for download. Probably time to think about a new camera.
Jul 28, 2010 | Toshiba PDR-M25 Digital Camera
I need to purchase a new cable that goes from the
At the electronics section of most department stores. Take your camera with you to be sure to get the right size plug for the camera end.
Nov 16, 2009 | Toshiba PDR-M25 Digital Camera
Toshiba pdr-m25 camera
Driver can be downloaded from:
http://www.camera-drivers.com/drivers/129/129568.htm
(requires free registration).
Any good camera store should stock a suitable usb cable.
Feb 18, 2009 | Toshiba PDR-M25 Digital Camera
Toshiba PDR-3300 Lens cover message
Hi Judy, thanks for coming to FixYa.
Sorry no one has gotten to you sooner. Your manual mentions this and this is what it says to do:
Turn the camera on and move the lens cover switch to the open. Then your camera should operate normally. Let me know if that helps.
Rob
Feb 16, 2009 | Toshiba PDR-3330 Digital Camera
Camera lens wont close
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Nov 30, 2008 | Toshiba PDR-M25 Digital Camera
Need software for pdr-m25
Sierra image expert 2000 is no longer produced or supported.
For more details, visit www.jasc.com.
Hope this will steer you to what you are looking for !
The Jasc Company has been bought by Corel and you can find the Jasc After Shot (Image Expert 2000) now bundled in their Corel Photo Album 6 available trial offer: -
http://download.cnet.com/Corel-Photo-Album/3000-12511_4-10181959.html
Let me know if this helps you or if you have any other questions.
Sep 28, 2008 | Toshiba PDR-M25 Digital Camera
Locked lens
your camera needs a new lens assembly.These lenses are not repairable .They can only be replaced.
Jun 23, 2008 | Toshiba PDR-3320 Digital Camera
Toshiba pdr-m25 digital still camera
You can download it here. Scroll down a bit to find your camera.
Dec 31, 2007 | Toshiba PDR-M25 Digital Camera
Toshiba PDR-M25 Digital Camera Logo
70 people viewed this question
Top Toshiba Cameras Experts
john milligan
Andrew Taylor
Andrew Taylor
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
