Question about Acer Televison & Video
I need a manual for AGK 10219 - Acer Televison & Video
Need universal remote code for agk i had the manual but lost it with the code i need to work my freeview box with agk remote but need code so i can use it ?
Http://www.agknordic.com/new/index.php?side_id=76
manuals and code sheets for various remote models. fixed my problem..
May 25, 2014 | Televison & Video
Tip
BMW Motorrad Fault Codes
10167 Output stage to electric fuel pump GS/A 1200 Idling irregular
Battles to start
Fault appears to start intermittently
Bike may start and ride, then will
appear to have fuel starvation
This unit is situated on the
left side of the tank. It is a
little aluminium unit with
fins on. Check the o-ring
of this unit. Unscrew the
unit and check for
moisture in the cavity
below it. Use moisture
repellent spray and
contact cleaner to clean
this device.
If problem
solving does not
work then
replace the unit.
10218 CAN-Bus Timeout: No
communication with KOMBI
(Instrument cluster) control unit
GS/A 1200 Test with diagnostic
system.
Clear fault code.
10219 CAN-Bus Timeout: no
communication with ZFE (Central
vehicle electronics) control unit
GS/A 1200 Instrument cluster does not activate
properly.
Instrument cluster activates partially
and then fades away.
May start on intermittent occasions
system.
If all else fails
replace the ZFE
control unit.
(Very expensive).
10444 Fuse activated for component block
3 (starter relay, Immo (EWS) ring
aerial, ignition coils, injectors)
GS/A 1200 There may be a short on the battery
terminals or elsewhere. Can happen
in conjuction with fault code 10219.
23971 Rear wheel speed sensor: Signal
implausible
GS/A 1200 Possible dirt on sensor. Dirt on wheel
where sensor lost contact.
system.
Clear fault code.
Replace sensor if
fault code reappears.
24052 Electric System under-voltage GS/A 1200 Starter motor battles to turn
Instrument cluster fades and then
reappears.
Check Battery Voltage
Check that the alternator
is charging battery
Check wiring to see that a
short is not draining
battery power.
Replace battery if
it is not charging
or
Service alternator
24971 Pressure In Front Wheel Circuit To
High
GS/A 1200 Check Wheel Pressure! Release air out of front
wheel to the correct
pressure.
Clear Fault Code
Oter fault codes here http://bike-manual.mozello.ru/bmw-motorrad-fault-codes
on Dec 20, 2016 | Motorcycles
Want to use skype voice and video on inspiron 5160 - what microphone and camera should i buy
Personally that's up to you. At the end of the day you get what you pay for depending on how much your willing to pay.
I recommend either Logitech or AGK for both mic, headset and camera.
Logitech can be expensive and AGk are fairly cheap but both are as good as each other.
Regards.
Nov 26, 2009 | Dell Inspiron 5160 Notebook
Hello How can get driver for agk nordic webcam
go to:
http://www.agknordic.com/new/index.php?side_id=205 and download driver :)
Jul 29, 2009 | Computers & Internet
NEED CODE TO MY AGK UNIVERSAL REMOTECONTROL
i need the agk universal remote code to link it to my technosonic fta 204 t freeview box
Feb 24, 2009 | Televison & Video
Agk 101-54 code
i need the code to synchronize my philips freeview box with my agk universal remote modal 101-54
May 13, 2008 | Directed 434MHZ Remote Control
Universal remote code????
Hey...here's a bunch of codes that i found for alba tv's:
ALBA 003 009 011 027 028 053 062 068 083 162 169 171
Try em out, good luck!
Feb 29, 2008 | Directed 434MHZ Remote Control
Codes
Here is the site for remote codes:
www.remotecodelist.com/remotes/
Jan 03, 2008 | Televison & Video
Televison & Video Logo
177 people viewed this question
Top Acer Televison & Video Experts
Gareth Cockram
Gareth Cockram
Rommel Balcita
Martin Murray
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
