Question about Ricoh Office Equipment & Supplies
Error message says SC 441 Turn off on, on my Ricoh L2000n printer. Does it need to be clean?
  • 67 Answers
Replace thermistor
Posted on Aug 26, 2010
Error 441 mp 4000
SC 441 Trans/development motor error - check for binding/overload on motor -Carl
Feb 25, 2015 | Ricoh Office Equipment & Supplies
Ricoh aficio 2075 sc 441
This is a developer motor lock - may need the machine to be stripped down and cleaned out or a replacement motor.
Oct 18, 2013 | Ricoh Aficio 450 Copier
Error sc 441
SC 440 main motor malfunction.Check the gears and the drum motor mechanical parts on the drive transmissions.For more details please the copier model.
Mar 05, 2013 | Ricoh Office Equipment & Supplies
Repair error 441 in cl3500dn printer
SC 441 - development motor lock.Possible causes:
too much load on the drive mechanism
development motor defective
poor drum motor connector connection
interface board defective
Feb 03, 2013 | Ricoh Aficio CL3500N Laser Printer
Sc 441 error massege
The SC441 error means one or more of the developer units (PCU) is not rotating. You have to take the PCU out to see which color isn't rotating. One of the doctor (cleaning) blades might be flipped, usually caused by lack of toner in the PCU.
Basically, if you just open up the printer, latches and everything, and just make sure the parts are all able to move freely by giving them a bit of a test with your hand, then close the printer up turn it off then back on and it should be working.
Jan 04, 2013 | Ricoh Aficio CL3500N Laser Printer
My printer flashes alert CS 441 off on. Can you tell me what's wrong?
The SC 441 is a color pcu motor lock. One of the waste toner augers is clogged with waste toner not letting the drum turn. The only real fix is to replace the color pcu unit. If you could get the auger and drum out it might be possible to free it up, but you will probably damage the drum in the process.
Apr 15, 2009 | Ricoh Aficio CL3500N Laser Printer
SC 441 Alert, Richo Aficio CL 3500N
I have run into this several times with these printers. In every case, it has been the CMY PCU. These run about $300.
I have read that by cleaning the PCU, you can get it to work sometimes. So far, I have not been lucky enough for it to work.
Mar 03, 2009 | Ricoh Aficio CL3500N Laser Printer
Error message sc 172 on ricoh aficio color 2103
You'll need a tech on site for this one, but it may be difficult to source parts if required for this old box. One of the following situations has occured:
• Poor connection of CCD
harness
• Dirty optics
• Defective lamp regulator
• Defective main scanner IPU board
• Defective CCD
Feb 23, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
SC 441 Error code
Transfer belt cleaning unit.
open top cover, cleaning unit cover(2 black tabs rear)
pull unit slowly. check if paper jam or gears not turning
Dec 24, 2008 | Ricoh CL1000N Laser Printer
SC 441
Hi there the following is the description from the service manual hope this helps you Thanks J
441 PCU (CMY) motor error
The drive motor of the CMY
PCU is not locked.
• Defective gear
• Voltage between pins 2 and 14 (CN12 on engine
control board) abnormal (not +24V), or pin 12
(CN12 on engine control board) unable to send
motor clock
• Defective CMY PCU drive motor
1. Replace the CMY PCU.
2. Replace the engine control board.
3. Replace the main drive unit assembly.
I would try replacing the CMY PCU (Drums (Photo Conductor Units) first before any of the others.
Thanks J
Jan 06, 2008 | Ricoh Aficio CL2000 Laser Printer
123 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
