We need to replace the drain hose in our Kenmore Elite HE3t washing machine. How do I get access into the machine to replace the hose? Is it from the top or the back?
  • 5,911 Answers
To replace the drain hose, follow these steps:
1. UNPLUG the washer and turn it around so you can access the rear panel.
2. Use a wet/dry shop vac and pull a vacuum on the drain hose. This will remove any existing residual water that remains in the drain line and pump minimizing any mess you may have to clean up later. NOTE: There is about a gallon of residual water that normally remains between the lower wash basket, drain lines and pump.
3. Remove the rear panel by loosening the screws around the perimeter of the back panel. With the screws removed,the panel should lift off. NOTE: There is a smaller access in the center of the back panel that can also be removed. Removing the entire back allows for better access though. Trying to work through the center access can be a cut hazard due to the sharp edges on the metal.
4. Move around the the front of the washer and remove the lower toe panel under the door. You may have to prop up the two front feet of the washer to access the screws under the bottom front edge. With the screws removed, the panel will drop down, then lift off.
Additionally removing the front toe panel will give you full access to the drain pump from the FRONT and the REAR. The pump sits closer to the front of the washer where you can easily access the hose clamps. The drain hose inserts from the rear, however.
Since you have the washer apart, now would be a good time to check the drain pump clean out trap to ensure there is no debris build up that can restrict drainage. The following link explains the recommended procedures to check the drain pump:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
If you have any questions about any of this advice, please post back and let me know. I hope you find this information helpful.
Posted on Feb 08, 2010
I have the kennmore elite he3t. Error code f 02 and it will not drain Is there a solution to this problem you know of?
The fault code indicates a draining problem and the display can be cleared by pressing the Pause/Cancel button twice. Either the pump filter is blocked, the drain hose is clogged/kinked, the pressure switch is stuck in the full position, or the pump itself is not working.
Disconnect power and
remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
Jan 03, 2011 | Kenmore Elite 45986 Front Load Washer
My Kenmore elite he3t is giving me a problem in the spin cycle. Even thought the spin setting is set on high or extra high, the drum turns very slowly and will eventually stop and the washer starts...
The machine will not advance to the high-speed spin cycle unless the water is drained first. The F02 error code manifests this condition as it means draining problem. Either the pump filter is blocked, the drain hose is clogged/kinked, the pressure switch is stuck in the full position, or the pump itself is not working. The display can be cleared by pressing the Pause/Cancel button twice.
Disconnect power and remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Dec 20, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he3t stream showing error code sud then f35
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 01, 2010 | Kenmore Elite 45986 Front Load Washer
I find water in the bin after the cycle has
It sounds like the water inlet valve is letting water enter the machine at times when it shouldn't.
The valve can be replaced and is part number 8181694 it runs about $40.00. The valve can be accessed by taking 3 screws out of the machine top located on the back of the machine, slide the top up and back to remove. The fill hoses connect to the valve in the back and the remainder of the connections are inside from the top.
Apr 22, 2010 | Kenmore Front Load Washer
Kenmore elite he3t steam front loader - 110.4674-2 --- f35
Oct 03, 2009 | Kenmore Elite 45986 Front Load Washer
''SUD'' Code on Kenmore Elite HE3t after new pump.
Run some white vinegar through a rinse cycle to get the excess soap flushed out.
Eric
Sep 17, 2009 | Washing Machines
Kenmore Elite HE3t which F21 code
I'm guessing the HOSE is the drain hose.
The goop is causing the drain motor to overheat causing it to report error. (luckily or it'd burn out).
Give it a empty load with nothing in it to see if it flushes it all out.
Just water.
See if it completes full cycle and check pump filter again to see if clean.
TIP. Make sure you check ALL pockets before you wash clothes.
Apr 16, 2017 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite He3T problems, won't drain
The machine knows when there is water left in the tub and will not function properly because the level switch indicator is still open.Ok, to simplify this ,you have a clogged pump and if there is no access into the machine from the front then look at the back to see if there is.Open the panel and remove the hoses from the pump and remove what is caught in it.Also look into the ends of both the 2 hoses.Don't wash RUGS,MOPS,COIN MONEY,NAILS,JEWELERY,UNDER WIRE BRA'S,OR ANY THING THAT DOESN'T BELONG IN THE WASHER,cause these little things don't make it past the pump,therefor washer leaves water inside and error messages start rolling.
May 25, 2008 | Washing Machines
Washing Machines Logo
138 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
