Question about Whirlpool Duet GHW9150P Front Load Washer
Water inside the drum. - Whirlpool Duet GHW9150P Front Load Washer
  • 5,911 Answers
If the washer is continuing to fill with water while not in use, this is often caused by a water inlet valve that is leaking by, or a pressure switch malfunction. The following link explains how to troubleshoot and repair:
http://www.fixya.com/support/r3753262-front_load_washer_fills_when_not_in_use
This is a very simple and inexpensive repair. If parts are required, you can order on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Use whatever parts source you like, but these sites offer great service with competitive pricing, so shop and compare. The first three sites on the list also offer helpful exploded view parts illustrations to help you locate and properly identify the parts you need. If you have questions, please let me know. I hope this helps you.
Posted on Feb 08, 2010
Zanussi zwf 1221 will not turn drum, the end light flashes the water goes into the drum and drains out when a program is selected but the drum will not turn at all. You can turn it by hand and it moves...
you need to check the pressure switch inside the washing machine there a small hose connected with the pressure switch to sense that the level of water inside the drum is ok if this hose blocked the machine will not run
Oct 10, 2011 | Zanussi ZWF1430W Front Load Washer
LG WD12020D Inverter Direct Drive 7.5kg front loader. Has never had visible water level in the drum. I have even stopped the machine, turned off the power, waited for the door to unlock, pushed the wet...
No water that high. But you may have an extra water button that allows you to add slightly more water to each wash load. Water should be just above bottom of inside drum in the back of the drum as it rotates
Jul 01, 2017 | LG Washing Machines
Hi I have a Maytag Neptune model MAH5500BWW Serial B4585662GA. When I turn the drum, I can still hear water inside/behind the drum. Thank you
This is normal. There is a balance ring filled with water attached to the inner drum. The balance ring is sealed and is not supposed to be empty. When you turn the inner drum by hand, you're hearing the water settling down from the now upper chambers of the balance ring.
Oct 14, 2010 | Maytag Neptune MAH5500B Front Load Washer
Water is leaking from the middle of the washer under the washer ? doesnt seem to be any water on the inside from looking down arond the tub .
you will need to remove the front panel to view the inside for this leak. Most likely a leak has occured at a drain hose at the clamp area. They always tend to leak near the clamp
Aug 11, 2010 | Maytag Atlantis MAV6451 Top Load Washer
Really bad smell from drum?
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the hose to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting. Being the first time you shd note what you doing, what goes where. You certainly don't need techs for this; and techs who come are useless anyway.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Pl give me a ‘very helpful’ rating for the free help, thanks!
Mar 08, 2010 | Hotpoint WMA64 Front Load Washer
My washer fills up, but not inside the machine. If I put the machine on spin, the water drains out. Why won't it fill inside the machine?
The water is going into the machine, but somewhere below the inside drum. I can hear it sloshing around if I move the inside drum. If I put it on the spin cycle, it does not spin, but the water comes out of the hose and into the sink.
Nov 09, 2009 | Kenmore 2.1 cu. ft. Portable Top Load...
Water leaking under washer but no appearance of leaking from hoses
water seal inside washer drum may be damaged, causing water to come out along drum shaft.
Oct 24, 2009 | Frigidaire Washing Machines
The drum is stuck - it will not move
overloaded & unballanced has mabe pulled drum away from the rear bearing!
& jammed iself!
only way now is to disconnect power & water & undo cabinet to inspect it!
Cheers rob.
Jul 28, 2009 | Washing Machines
Water is collects in drum after a few hours after cycle is complete
no your inlet water valve is defective, youll need to repalce it, part number 8181694. in the mean time just turn off water in beween usages.
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
there may be a foreign object that is partially blocking the drain from the outer drum. open the back and remove the drain hose connection from the drum. Using a long screwdriver as a test prod, carefully try to feel this foreign object. Also try to look up into the drain outlet using a flashlight and mirror.
Aug 18, 2007 | GE WBSR3140DW Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
70 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
