Question about E-Machines eMachines Desktop PC
D3123 won'w work
Please help dont know much about computers please step by step. Have Emachine E3123 turns on but fan will not stop running and nothing comes up on screen what to do?
  • Makfl Feb 22, 2008
    Fathers computer trying to help not that old last year got it. Opened up try to see if anything out of place. Nothing out of place. Also plug in and both fans run all the time and nothing comes up on monitor. Eject button does work put in recovery disk but nothing. Also when I plugged in mouse and keyboard, Keyboard normally lights up nothing when I turned it on.
    Checked on warranty they said it ran out end of 2007, Thanks
    Scholar:
  • 121 Answers
Well it sounds like it's an old pc, is this correct? if it sounds like the fan then it could also be your power supply making that noise.. i would assume your power supply might be going bad..
if you happen to have recovery discs, then this should help.. will the eject button work on the cd rom? i woud shut it down completely, unplug an gadgets and only plug in the mouse, monitor and keyboard b4 you reboot and see if that helps.. chances are it's one of 2 things: fan or power supply.. let me know how it goes and if you are able to resolve your issue.. hope i was able to help..d
Posted on Feb 22, 2008
  • donna mcgill Feb 22, 2008
    if it's within a year that you purchased it, you can contact your tech support for your particular brand of pc.. it sounds like a hardware so usually there is a year on hardware for warranty when you buy one.. hopefully they can assist with no charge..
Radiator resivoir is cracked and fans not running and i need to replace the radiator and or run a toggle switch for the fan relay switch if the wiring is bad
It may already have a blown head gasket. The max pressure on the cooling system in normal conditions is 18psi.
How do you know the fan or fans are ok ? The computer signals the relay to turn the fans on if the engine temp reaches 220 degrees or you turn on the a/c. If the temp sensor does not have coolant to tell it the engine temp, the fans won't come on.
As for a toggle switch, you would need a relay mounted close to the fans because they will pull too much current thru only a switch.
Jun 27, 2012 | 1995 Dodge Neon
D3123 wont boot
Use System Restore
To use System Restore, first restart the computer by pressing[Ctrl][Alt][Delete]. When you see the message Please select the operating system to start or hear the singlebeep, press [F8] to display the Windows Advanced Options menu. Now, select theSafe Mode item from the menu and press [Enter].
Once Windows XP boots into Safe mode, click the Startbutton, access the All Programs ' Accessories ' System Tools menu, and selectSystem Restore. Because you're running in Safe mode, the only option on theopening screen of the System Restore wizard is Restore My Computer To AnEarlier Time, and it's selected by default, so just click Next. Then, followalong with the wizard to select a restore point and begin the restoration procedure.
Let me know if it helps you.
Use system utility tool like RegInOut to remove unwantted files and fix registry and windows errors.
Jan 04, 2012 | eMachines D3123 Desktop Computer With AMD...
D3123 windows wont boot
Use System Restore:
My emachine d3123 freezes after start-up when downloading updates and/or watching a video or movie.Pretty much only when I'm multitasking. Memory has been upgraded to two 1gig sticks of Ram and operating...
You could make sure you bought compatible RAM sticks.. here what Crucial.cm suggests:
http://www.crucial.com/usa/en/compatible-upgrade-for/eMachines/d3123
Also let Windows handle virtual memory settings, and blow out all the cooling fins on the processor's heatsink. Hope that helps.
Feb 17, 2018 | eMachines D3123 Desktop Computer With AMD...
My emachine d3123 keeps freezing after start-up when downloading updates. how do I fix this?
Some clarification is needed here. Are you getting an error message or a blue screen? Can you move the mouse at all after it "freezes" ? What exactly is updating?
The simple solution is to disable automatic updates for whatever is trying to update.
Apr 03, 2011 | eMachines D3123 Desktop Computer With AMD...
Can't download drivers for eMachine D3123
Please find the driver download location for this model
http://support.emachines.com/em/driver/
Chipset driver location:
http://global-download.acer.com/GDFiles/Driver/Chipset/Chipset_NVIDIA_4.90_XPx86_A.zip?acerid=633913626149764050&Step1=Desktop&Step2=D Series&Step3=D3123&OS=X01&LC=en&BC=eMachines&SC=EMEA_27E
Audio Driver:
http://global-download.acer.com/GDFiles/Driver/Audio/Audio_Realtek_5.10.0.5990_XPx86_A.zip?acerid=633909298198237378&Step1=Desktop&Step2=D Series&Step3=D3123&OS=X01&LC=en&BC=eMachines&SC=EMEA_27E
VGA / Display driver:
http://global-download.acer.com/GDFiles/Driver/VGA/VGA_NVIDIA_8.1.3.3_XPx86_A.zip?acerid=633909232477072708&Step1=Desktop&Step2=D Series&Step3=D3123&OS=X01&LC=en&BC=eMachines&SC=EMEA_27E
Note: The above drivers are for Windows XP.
Oct 29, 2010 | eMachines D3123 Desktop Computer With AMD...
Emachine problems
Hi..
Since your computer is working but no display at all. Hope this steps would be helpful in your problem.
1. Turn on your computer, If the problem works again and no display.
2.Turn off your computer by pressing long your power botton until the fan stops properly.
3. Unplug you computer 220volts power chord at the back of your computer.
4. Reconnect again the 220volts power chord after 1 minute.
by. arnold@supportsave.com
Jun 04, 2008 | E-Machines eMachines Desktop PC
Laptop fan stopped
emachine has laptop ?? what's the model ?
May 02, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
46 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
