Question about Motorola Mobility RAZR V3
Razr no light on flip up lcd screen
Fully charged
Still calls out and in
no light on lcd screen on front ot interior
  • Anonymous May 08, 2008
    interior lcd screen is blanc with lines running vertically.
    Problem Solver:
  • 3 Answers
This worked for me - I did have to repeat it several times, and I was never really sure whether I was supposed to start with the phone "off" or "on"
Press and hold simultaneously * # and the red "end" button. This is supposedly the equivalent of a "safe boot" for a RAZR. It worked on my phone when I had this problem Feb 4, I applied this solution on the 6th, my phone has been perfect since...
Posted on Feb 22, 2008
Very Helpful
Posted on Jul 31, 2008
I have a Motorola Razr V3. Very recently the exterior and main screen went black. The phone itself still works (I can still call people and receive calls) but I can not see anything on the screens. Do you...
The reason your phone interior and exterior screen went black is because there is a problem with the flex of the phone.
The flex is the mechanism like a ribbon that connects the screen to the panel of the phone.
All you have to do is to replace the flex of the phone.
To replace it on your own, the process to do this are as following;
  1. Get the appropriate screwdriver (Torx 5 screwdriver).
  2. Remove the four rubber stoppers surrounding the screen to reveal four screws. Remove these screws.
  3. You can now remove the front cover. To do this, use a credit card to lever the cover up. The cover clips on and the levering motion will unclip it. Start at the top, then unclip the cover at the bottom, then both sides.
  4. Now detach the camera from the phone. Simply pull the ribbon away from the phone to release it.
  5. Now unplug the other ribbon. The ribbon attaches like a plug and socket. Simply lift it up to unplug it.
  6. The ribbon you just unplugged is the flex of the phone, so you have to unscrew the lower part of the phone to remove it completely.
  7. To open the lower part, you have to open the back cover and remove the battery,
  8. Unscrew the screws you see, than split it open with a credit card or the tip of your finger, apply a little force to open it.
  9. Then unscrew the board, you will see where the other end of the ribbon is connected on the board, then you can remove it and fix a new one.
  10. Reverse the process to reassemble the phone together.
Take care
Jun 22, 2010 | Motorola Mobility RAZR V3
Blank screen
Try swap another flip and see what happen? could be flex connectors faulty or display faulty or dispplay PCB faulty,or software corrupted,you have to go to step find down probblem,good luck to you.
Aug 17, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Broken screen on Blackberry 8220 Pearl Flip
If you're tech savy you can use a blackberry repair guide that will show you how to disassemble it step by step and replace the screen, the screen is available on Ebay or you can go to the repair service.
Jul 15, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Screen problem
take teh phone and have the LCD replaced.
Dec 18, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Razr Inop
you need to take the phone back and have it replaced for a new one.
Mar 19, 2008 | Motorola Mobility RAZR V3
Screen on Razr
You will need a hot air soldering/desoldering gun for the work. Not possible. Only a trained technician can do it.
Oct 27, 2007 | Motorola Mobility RAZR V3
Screen went black and can not make calls
You Phone lcd has some problem or your flip doors are been lose so you must get your mobile phone check with someone proffesinal in repairing the mobile phone or if you mobile phone is under warrenty claim it .
Sep 22, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Water damage from my skin
You need to open the phone housing and try to dry up or clean the board for any wet situation or moisture and check for any bad connection specially the connector from LCD display into the main circuit board. This connection is frequently loose in Motorola phone due to the flipping function is not reliable. I am surprise that since a flip phone which is mean it will open and close almost every minute for million time per month or year htne how come they made the connection so loudsy. I have fixed these problems for my relatives and friends and always see this common failure in Motorola Flip phone. Everytime you are no longer see the display but still heard sound and ring which is mean that either your cable is loosen or bad then you have to replace it. Please see below link for hoe to replace the LCD: http://uselessinfo.pwp.blueyonder.co.uk/dismantlev3.htm I have an instruction of how to fix a water damaged phone but I have not been tried it before so you must read the instruction of water damaged guide carefully and make decision whether you want to do it. Please email me at joe_dao2003@yahoo.com so I can email you the link. I am at work so I cannot reach to my laptop hard drive to get the info. Try the link above to see how ot open the phone housing first then will try others later. Good Luck
Apr 06, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
425 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
