Question about HP DesignJet 130 InkJet Printer
My HP Designjet 130 is printing grayscale images in red (even when I set the printing option to grayscale). This started halfway through one image. The first half of the image printed in grayscale and then the second half was in shades of red. Now, it is doing this for the entire image. The black ink cartridge is 3/4 full.
  • nigelord Jul 13, 2010
    Just wondered if you'd had any success solving this problem as my DJ130 has started doing exactly the same thing. Kosmostorm has described cleaning the printheads in alcohol as a way of fixing it, but I don't think this is the problem - as my machine prints out a test sheet perfectly. It's only with a normal print job that it stops printing other colors and just leaves magenta. If you have come up with a solution, I'd be interested to hear..
  • 164 Answers
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 08, 2010
Error code 66-02
66:02:1 warning code (applicable to HP Designjet 130/130nr only)
Explanation
Horizontal clipping. May happen when the roll ends in the middle of printing an image. Could also happen when multi-pick occurs and two sheets are loaded together and they do not completely overlap.
Recommended action
Make sure the image size is within the selected WIDTH of the sheet.
top
66:02:2 warning code (applicable to HP Designjet 130/130nr only)
Explanation
Vertical clipping. May happen when the roll ends in the middle of printing an image. Could also happen when multi-pick occurs and two sheets are loaded together and they do not completely overlap.
Recommended action
Make sure the image size is within the selected LENGTH of the sheet.
Oct 21, 2014 | Office Equipment & Supplies
HP 722C has quit printing black in color draft
WORKAROUND: Select EconoFast or Draft as the print quality setting in the printer properties. This will prevent the color cartridge from being used. - Or - Try another color cartridge. The color cartridge is used to print grayscale images in Normal or Best print modes, so if one color has run out, the printout will have the wrong tint. With a full color cartridge, the colors can be properly combined to create a composite black. CAUSE: When printing with Normal or Best as the print quality setting, the HP Deskjet 710C or 720C or 722C series printer will use the color ink to improve print quality output, even when printing a grayscale image.
Sep 07, 2007 | HP DeskJet 722c InkJet Printer
Hp design jet z2100 printing in mirror image
I would recommend uninstalling the print driver, going to HP.com and downloading the latest driver and reinstalling it.
Feb 25, 2014 | HP DesignJet Z2100 InkJet Photo Printer
Printing files smaller than actual?
Because the 5500 does not print to the edge of the paper it will auto shrink the image to fit the paper ( a 36 inch wide image will shrink to 35.45" when 36" paper is used). Your image will need to be at least 0.55" narrower than the width of your paper to avoid this. so: Crop the image if you can, or use wider stock.
Feb 03, 2010 | HP Designjet 5500 (42 in.) InkJet Printer
Test page
from the printer driver go to start menu then go to settings then chose printer and right click on the printer icons chose properties then chose print test page
Sep 06, 2008 | HP Designjet 130gp InkJet Printer
2605dn prints red background randomly
n the Windows environment, the Automatic and Manual color options are on the Color tab in the printer driver. choose manual and click on grayscale
Jan 09, 2008 | HP Color LaserJet 2600n Printer
Sharp AR-M237 Grayscale Copier Problem
Yes.There should be settings to enhance that in your print driver properties page.
Easiest way to access that is to open a document and click "file' then 'print and that will bring up your printer options.
Look around the print driver for ways to enhance your prints.
Most drivers have several options in graphics areas to make adjustments.
You can access printers from the controle panel and also right click the printer and select properties to access it.
There definatly are ways to adjust that.
Hope this helps you some.
Dec 19, 2007 | Sharp AR-M237 Copier
HP DesignJet 130 InkJet Printer Logo
584 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
