Question about Hotpoint RLA80 Refrigerator
Need a fridge no more than 49.4 cm in width
I bought a fridge freezer 20 years ago - a Zanussi - when we had our small kitchen remodelled the fridge was fitted in neatly. There is no way we can put in a larger one without totally re modelling the space again, and as pensioners I really don't want to do this again. I am worried that now the fridge is so old it will give up one day, and I had n o idea it would be so difficult to get another in this width.
Please help!!
  • 4,793 Answers
Although manufacturers stated width is 50 cm it is in fact 49.5cm (to fit 50cm) you need to measure the new f/freezer be carefull "all sizes are approximate"
a nominal 50cm should just slide in.....you need to go to your favorite local store and explain in detail, if after your explanation, it doesn't fit you are not legally obliged to pay for it.. take a witness......
and only pay a small deposit.
Posted on Feb 09, 2010
What are the dimensions for APM6855 fridge freezer. I need to replace mine
Depth - 570 (cm), Height - 1780 (cm) and Width - 560 (cm).
Feb 25, 2015 | Refrigerators
LG model LFX21960ST. No cooling in either fridge or freezer. The compressor comes on for about 7 seconds when first turned on and then will cycle on for a few seconds every few minutes. The fan in the...
There could be a loss of freon(unlikely but possible), the start capacitor for the compressor is bad (most likely) or the thermal cut off switch on the compressor is cycling from the hot compressor.
Mar 28, 2017 | LG Refrigerators
Zanussi ZFC 45/30 SS is hot at front between the doors..
This is normal. This is a defroster to keep moisture from condensation from freezing the doors shut.
Jun 30, 2009 | Refrigerators
Zanussi frost free fridge freezer leaking water at back
Here is a link for your unit's manual: http://www.serviceforce.co.uk/pdfs/U30164.pdf
May 15, 2009 | Refrigerators
Fridge on Fridge freezer not working
Ok there is a drain pan under the evap. coil under the fan that may be clogged and full of ice there is a 3/4" hole the water drains out of that needs cleared if there is a puddle of ice over it , the ice will also effect the airflow traveling down the duct to the fresh food section of the unit.
If there is no ice puddle at the bottom of the refrigerator then make sure the unit is cooling well by making sure it has been running for 10 min. or so and checking the coil in the freezer , it should have a small layer of frost on it showing its getting cold the whole way through it. Let me know how this works.
Phil
Jan 02, 2009 | Zanussi ZI921 / 8FF Bottom Freezer...
Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
Oct 09, 2007 | Zanussi ZX99 / 5 Bottom Freezer...
French Door to right swing on Fridge
Go to this link and you can see all the identical sized models with a right swing door. The hinges are the same so you could easily swap them; http://www.kitchenaid.com/catalog/category.jsp?categoryId=77#85 here's a link to the user manual if you need it; http://www.kitchenaid.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%202300253.pdf check page 7 and 8 for how to swap a door. Page 20 gives you contact details for spare parts. Hope this helps :)
Jun 27, 2007 | KitchenAid KBFA20ER Bottom Freezer French...
Looking for a fridge with narrow depth and finding it hard.
i need an american fridge freezer depth less than mm and wudth less than 90mm
Apr 09, 2007 | Hotpoint RLA80 Refrigerator
Hotpoint RLA80 Refrigerator Logo
75 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
