Question about Savin 2545DP Black and White Copier
I have a recurring problem with a SAVIN 2545 at only one of my customers. The toner will clump & harden in the waste toner transfer box on the front end of the image unit. This prevents the fresh toner from passing thru to the dev unit. I believe it is related to a "damp" building & the humidity is causing the clumping. Anyone have experience with this issue & a preventive solution?
  • 903 Answers
I've never seen this problem, even in damp environments. Are you sure it's not a problem with the PCU's toner supply mechanism or with the dev unit's auger?
Is it a customer who runs a very low volume? I've seen problems with the toner clumping behind the cleaning blade, but never on the front side of the PCU like that. You might want to try asking around in Ricoh's tech forum, found on the Ricoh website:
http://www.tscweb.net
Posted on Jul 18, 2010
Error code C2257
Cleaning motor, motor functions to route old toner to waste toner box, motor located lower left side rear. Open close front door to reset if code comes back motor is bad or have a bad board. But first remove the transfer belt and check it cleaning system also the waste toner box, might have some toner that has harden and is not allowing motor to turn recommend get a KonicaMinolta tech to look at it.
Apr 06, 2015 | Konica Minolta Bizhub C452 Copier
Savin 2406wd how to change waste toner bottle
Do not attempt this , call a qualified tech, the drum can easily be damaged during this operation
Aug 14, 2014 | Savin Office Equipment & Supplies
Bizhub 550 error c2204
Waste toner motor. Remove the Waste toner box and transfer belt ensure the waste toner box is not jammed up and check the transfer belt toner removal section is OK. Also check the gears on the left side of the waste toner box is ok and the machine gears ok not jammed. could also have a jam in the internal tube that runs the old toner to waste toner box get a tech out to check
May 29, 2014 | Konica Minolta Office Equipment & Supplies
Where is the waste toner on savin 4051 sp
it's behind the front cover - lower right side...unlock the push/pull snap and side the bottle holder & bottle out of the front of machine. empty and reinstall.
Apr 08, 2014 | Savin 4051 Sp, Ricoh 2051 Sp, Copier W/net...
Error code c 2204 on konica minolta c652
Waste Toner Motor failure. check the waste toner box might have a issue where harden toner damaged the gear drive and or motor that takes care of the waste toner. worse case the control board is damaged $$$$$$$$$$$$$$$$$$$$$$$$$$$$. Have a tech come out mite require replacing some gears.
Jan 22, 2014 | Konica Minolta bizhub Office Equipment &...
Where is the run off waste on the Savin 9013?
If you open the right side door of the copier as if you are taking a paper jam out. On the inside of the door you will see the transfer belt unit. There is a Gray lever toward the front of the copier, It pulls up and to the right. The waste toner is inside that unit, it needs to be vacuumed out. Once the unit is out, there are two springs on the side of the unit remove them and there is a plastic clip that holds the belt in place. Release the clip and swing the belt up and lift it out. You will see six screws holding down a black cover, remove the screws and open, be very careful there is loose toner in the unit. Dump or vac out the waste toner and put the unit back togather and install it back into the copier and Ta Da..... Problem solved.... Good Luck.......
Feb 28, 2013 | Savin Office Equipment & Supplies
Changing waste container
The is no waste container on Phaser 6500. There is a "waste collection box" in every toner cartridge and the waste toner is discarded along with the empty cartridge. The is also a waste toner reservoir on the transfer belt and this one will be replaced along with the transfer belt.
If there is an error message saying, for example, "Waste Full Cyan Cartridge", it means the waste toner counter reached the replacement value for that color and you have to replace the corresponding cartridge. But the waste collection box is not really full.
Sep 30, 2012 | Xerox 6500/N Phaser Laser Printer
Waste toner is almost full on Savin C9020
The bottom left portion of the display gave the error message:
Waste Toner Bottle 1 Almost Full. Please call service.
They were still able to print, however this message would not go away.
To Fix:
Power down the printer using the normal shutdown method.
Open the top front door.
Remove the cover directly below the 4 toner cartridges.
The removable cover below the toner cartridges is actually the Waste Toner Bottle.
Bring this to the dumpster.
There is a round, clear-plastic tab on the underside of the "bottle". Remove this.
Shake the bottle around over the dumpster. Continue until all the toner has been removed.
Push the clear plastic tab back in place. Wipe off all toner residue before putting it back into the printer.
Put the waste toner bottle back into place. Power on the Savin. Confirm the message no longer appears and that users are able to print.
Feb 08, 2012 | Savin Office Equipment & Supplies
I have the same problem with a Ricoh aficio 700 SC495
check the door contacts and the contacts on the transfer unit these need to be clean also
Sep 17, 2009 | Savin 9935DP Laser Printer
Savin 2545DP Black and White Copier Logo
169 people viewed this question
Top Savin Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
Don  Farrell
Don Farrell
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
