Question about Konica Minolta magicolor 5430 DL Laser Printer
I am getting yellow spots on everyting I print. I
I am getting yellow spots on everyting I print. I have cleaned off the yellow print cartridge and the waste toner, but it didn't help
    Scholar:
  • 39 Answers
This is a laser printer and not an inkjet printer. Cleaning the "Print Head" isn't an option and putting alcohol on the printer's toner cartridge isn't the answer either. Minolta indicates that it is likely the yellow toner cartridge is bad. I have had a magenta toner cartridge exhibit the same problem. I just had to replace it which solved the problem.
Posted on Apr 29, 2010
  • andrewn0 Sep 21, 2010
    If the spots are about 0.1 mm in diameter, they are supposed to be there to prevent counterfitting etc.
  • rbarger Sep 21, 2010
    No. The spots of toner shouldn't be there. Use the menu to run a test print and if the problem continues try to clean laser lens using the special tool and following the manuals instructions. (I am on my iPhone or I'd type exactly what to do ). If the spots still occur on the test print after 20 or so prints I'd say the toner cartridge is bad and you should try a new cartridge. Keep the old one until you can confirm that is the case.
  • 164 Answers
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 08, 2010
Testimonial: "Cleaning help was very helpful. I do keep my cartridges full because I use my printer every day. A manual with my printer would have been helpful."
MFC 240C will not print yellow despite new cartridge
check if plastic cover on ink cartridge . may need a lot of cleaning of print heads may need to get cleaning alcohol and a cloth and clean print head physically
Dec 24, 2014 | Brother Multi-Function Center MFC-240C...
Cannon Pixma MG5520 printer
Remove all cartridges, clean the ink from where the cartridges make contact with cloth,(paper towels can leave trash in there) be sure all is clean then replace the cartridges and print something. Those streaks shouldn't be there any longer.
Sep 09, 2014 | Office Equipment & Supplies
DeskJet 895Cxi Printer ran out of black ink before my summerholliday. Back on job monday I replaced a new inkbox, HP 45 Black. The colour ink was changed just before my holliday. Still the orange light...
Follow each of these steps until the problem is resolved:
Remove and then reinsert the print cartridge(s) into the printer.
Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
Manually clean the print cartridges and print cartridge cradles:
Open the printer cover and wait until the carriage moves to the center.
Press the Power button to turn off the printer.
Disconnect power cord from the back of the printer.
Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
Lightly moisten a cotton swab with distilled water.
Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
Reinsert the print cartridges.
Close the printer cover.
Connect the power cord to the back of the printer.
Press the Power button to turn on the printer.
Calibrate the print cartridges.
If the light is still flashing, replace the print cartridges.
http://www.fixya.com/support/t5472914-hp_deskjet_932c_went
Aug 04, 2010 | Office Equipment & Supplies
Yellow ink will not print
On the Brother MFC series printers it uses remote ink trays as you will know, instead of having print heads directly on the ink cartridge. Whilst this approach makes it cheaper to produce the ink, and easier to change the cartridge, it can make it difficult to clear clogs.
There are several things you can do which may help, but B. and C. are at your own risk. All steps assume you have a new yellow ink cartridge.
A. In paint or another program, create a full page yellow image and keep printing it out. See if it gets any better after each print. If it does, continue until it seems to be working fine.
B. If you can manage to get to the print head, you can get a cue tip, dip it in rubbing alcohol and gently clean the print head. Leave 20 minutes to dry, and then do step A. again.
C. (AS A VERY LAST RESORT AT YOUR OWN RISK. THIS IS GOING TO RUIN YOUR YELLOW INK CARTRIDGE SO USE AN OLD YELLOW ONE IF YOU CAN) If steps A. and B. fail, you can put a "little" rubbing alcohol in the Yellow Ink Cartridge, and keep trying step A. If Yellow starts printing again, swap to a yellow cartridge that does not have rubbing alcohol in it. You are now going to have to cycle through many pages to clear the rubbing alcohol from the ink lines.
Note that if you keep cleaning the cartridges, it is going to use a lot of ink, and may actually hinder solving your yellow ink problem.
Good uck
Apr 24, 2010 | Brother MFC 240C All-In-One InkJet Printer
Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Mar 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
My printer wont print color!
Hi.
First check if you are using compatible cartridges for the printer. Use the following weblink to check for compatible cartridges for lexmark printers:
http://www.lexmarkstore.com/store/lexmark/DisplayProductFinderPage
if using correct carts and still issue, then you may try the following to clean the cartridges and print contacts:
Remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Snap the cartridges back into the cartridge carrier and check if it prints color.
To clean cartridge nozzles:
Click on "Start," go to "All Programs," and down to the Lexmark. Click on the "Solution Center." Next, click on the "Maintenance" tab. Select "Clean to fix horizontal strips." This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean to fix horizontal strips" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution Center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge (or cartridges) from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean. Also, wipe the contacts inside the printer (on cartridge carrier).
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean to fix horizontal strips" one more time. If this fails to address the problem, the entire procedure may need repeating.
Hope dis helps u...
Apr 24, 2009 | Lexmark X2600 InkJet Printer
My printer will not print color
Hi.
First check if u r using compatible cartridges for your lexmark printer. You may use the following weblink to find the comaptible cartridges for lexmark printers:
If using correct carts and stil issue, then check the below info to clean the print contacts and cartridges:
Remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Snap the cartridges back into the cartridge carrier.
Try it out..
Apr 24, 2009 | Lexmark X2500 All-In-One Printer
Yellow Toner Ink Spotting
Take a tissue and clean the area where the toner is. Do not use anything wet at all. Just a soft tissue. Re-install toner and try again to print. If the problem continues, it may be a leaking toner catridge. The cartridge has a cleaning blade built in and it may be deffective. Try a new toner cartridge if so.
Feb 11, 2009 | Brother DCP-9040CN Laser Printer
Red spot, Yellow Spot, Blue scratch on the printing document
Hi hope you fine.
is it just a spot or a continous line kind of?
is just a spot check the service kit on the front door (ETB ) alighnment might be touching the prnt drum units.
Sep 21, 2008 | HP Color LaserJet 2600n Printer
Spots/Lines on the prints
Take out the drum cartridge (piece with the long green arm) and look down inside the printer for any toner that may be leaking on your pages.
So I understand correctly, you were seeing different color toner on the cyan and yellow rollers?. If so gently clean that side of the roller off. Rotate the white gear on the right side of the toner cartridge back towards you and see if the correct color comes back on the roller. If you were seeing grooves on the roller then they will have to be replaced.
Put the toner cartridges back in and run color calibration.
Press menu/select. Right arrow key until you get to engine. Press select. Left arrow key until you get to service.
Press select. Right arrow key until you get to color calibration.
Press select.
Any other information would be helpful.
Jul 17, 2008 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta magicolor 5430 DL Laser Printer Logo
831 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
