FixYa.com
Tags:
Fein Multimaster Rs - Msxe 636 - 2 Rs
RPM will start to slow and then almost quit (by 2 users)
posted by mparis5551 on Feb 22, 2008
I have only used this 3 times and it is new. I started using it today and when you turn it on it goes back and forth in speed. The rpm's become very slow and it surges back and forth. No extension cord is used.
Very disappointed for what this cost.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Mar 17, 2008
I have had the same problem and just found out that Fein is recalling (& I hope replacing) those models that have this problem. Check with he dealer where you bought it.
Solution #1
posted on May 29, 2008
Not Rated (0)
hammer drill
Rank:Wiz Wiz
Rating: 83%, 90 votes
fein i believe is made in europe. i am guessing its the hz problem co`s the electronic to failed
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Tools and Hardware problems?
Tools and Hardware
Electric Ryobi String Trimmer
Where can I find a Repairman? Answer This...
Tools and Hardware
crosman 760
i need a clear diagram on how... Answer This...
Tools and Hardware
discontinued part by dealer
The gear assembly( part #... Answer This...
Tools and Hardware
Kwikset keypad front door...
Help! I need to change the code... Answer This...
Tools and Hardware
weed eater troybuilt tb425cs
run couple minutes cuts off... Answer This...
Repair Service
Find Tool and Hardware Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
