Question about HP PSC 1315 All-In-One InkJet Printer
I replaced 2 ink cartridges yesterday and not the black one and all of a sudden the black will not print. The printer sounds like it is printing but the page comes out blank.
  • 164 Answers
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 08, 2010
Hp cn216a suddenly will not print or copy black ink
Have you installed a brand new black ink cartridge after this problem arose? Sounds like a good old fashioned clogged print head. You should also run the "clean print heads" routine from the printers settings menu (on the printer itself)
Aug 08, 2013 | Office Equipment & Supplies
Purchased Kodak ESP 3250 yesterday. Not printing photographs.
Yes sounds to me like one of your ink cartridge is empty. Replace and try again.
Jul 26, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer does not print using black ink
Check your settings i=under the Services Toolbox. Also go into printer preferences and see if you can force it to print in black only.
Apr 26, 2010 | Dell P703w Printer
Won't print black ink 3E
I got a paper jam while printing.Know my brother mfc-290 will not print black
Apr 25, 2009 | Office Equipment & Supplies
MFC 210c problem with Magenta ink
I had a similar problem with my black ink. The printer had indicated that it was out of black ink. I didn't have one on hand, so, for more than a week I couldn't print anything, because if you are out of any one of the four ink cartridges, it won't print at all. That delay in replacing the black ink cartridge apparently was enough time for the printhead to dry out. Big Mistake! I contacted Brother's Tech Support and they suggested I run the cleaning cycle and try to print a test page. Still nothing printed. They had me run another cleaning cycle, and another, and another. Finally, after the fourth cleaning cycle, something started to show up on the paper. They had me clean it two more times, six in all, and it was back to normal. From now on, if it says one of the ink cartridges is empty, I change it yesterday. The major disadvantage of all of this, other than not being able to print for awhile, is that this procedure used up about 1/2 of a brand new black ink cartridge.
Oct 06, 2008 | Brother MFC 210C All-In-One InkJet Printer
MFC210C can't print in blck
I had a similar problem. The printer had indicated that it was out of black ink. I didn't have one on hand, so, for more than a week I couldn't print anything, because if you are out of any one of the four ink cartridges, it won't print at all. That delay in replacing the black ink cartridge apparently was enough time for the printhead to dry out. Big Mistake! I contacted Brother's Tech Support and they suggested I run the cleaning cycle and try to print a test page. Still nothing printed. They had me run another cleaning cycle, and another, and another. Finally, after the fourth cleaning cycle, something started to show up on the paper. They had me clean it two more times, six in all, and it was back to normal. From now on, if it says one of the ink cartridges is empty, I change it yesterday. The major disadvantage of all of this, other than not being able to print for awhile, is that this procedure used up about 1/2 of a brand new black ink cartridge.
Oct 04, 2008 | Brother MFC 210C All-In-One InkJet Printer
I have and hpdeskjet 960c printer. The amber light over the symbol for the ink cartridges is blinking. I replaced both the black and color cartridges. The light is still blinking and the printer won't...
open the top cover and allow the print cradle to move to one of the icons this indicates what the problem might be
it either shows that the cartridge is not inserted properly or the incorrect cartridge
or may be low on ink.
remove the cartridge and reinsert
if all else fails replace with new cartridges
Oct 02, 2008 | Office Equipment & Supplies
Printer will not print black ink
Hi please try these steps:::
Right-click the printer icon, and then select 'Properties'.
2. Click the 'Maintenance' tab, and then click 'Deep Cleaning'.
3. Select 'All Colors', 'Black' or 'Color' for the print head to be cleaned.
4. Read the message displayed, and then click 'OK'. The power lamp blinks and print head deep cleaning starts. (Do not perform any other operations until print head deep cleaning is complete. Print head deep cleaning takes about 1 minute.)
IF ABOVE STEPS DOESN'T WORK TRY THESE STEPS BELOW
Check ink tank vent hole The ink tank requires air to flow through it so ink can move from the reservoir to the print heads.
  1. Confirm there is no orange tape across the top of the ink tank
  2. If the orange tape is as shown in Figure (1), it is properly removed.
    *BCI-3's shown in this example.
  3. If the orange tape is as shown in Figure (2), remove the remaining tape to the level shown in Figure (1).
  4. Make sure each ink tank is snapped into the printer.
    IF THESE STEPS DIDNOT WORK THEN YOUR PRINTER NEEDS REPAIR(You might need to change the printer head.)
Jun 09, 2008 | Canon i850 InkJet Photo Printer
Print quality is poor
if you replace the black ink cart with an original one then it's the print head
Solution: Cleaning the Print Head - C555 / C560 / C635 / C530 / C545
Untitled Document Follow this procedure to clean the BJ cartridge print head:
1. Press c755funckey.gif 2. Press c755cleankey.gif 3. Use c755down.gif or c755up.gif to select the [HEAD CLEANING]..
4. Press c755set.gif.
The MultiPASS cleans the print head.
Feb 12, 2008 | Cannon MULTIPASS C530 Printer
HP PSC 1315 All-In-One InkJet Printer Logo
78 people viewed this question
Seeker5211
Seeker5211
