Question about Bosch Axxis+ WFR 2460 Front Load Washer
Front door will not open
My front door will not open. I have a service call, but they can't come for 3 weeks. Need some suggestions of how to get it open again. TIA
  • 2 more comments
  • Anonymous Feb 24, 2008
    door will not open it is locked how do I get it open
  • Anonymous Mar 04, 2008
    I am in the same boat. There should be a way to manually open the door if you have a power failure.
  • spainface Jun 14, 2008
    WFR 2460 - have the same problem with the door not opening.
    Tried the emergency release to no avail (ran another cycle, turned off power, checked child lock...)
    Any suggestions would be most welcome.
  • umonka Jan 12, 2009
    I noticed that the door made some noise when I closed it the last time. But after finishing the cycle (remove laundry on display) door won't open anymore: tried another spin cycle: no luck. Also tried pulling down the door release from the drain cleanout - but I am really afraid something in the lock mechanism actually broke off. Can I open the machine in any other way?
On the bottom right-hand side of the washer, there should be a door that contains the drain cleanout. Open the door and in the upper right-hand corner of the opening, there should be the end of a plastic handle. It may barely be showing, so look closely. Pull it down with your fingers or a plyers and your door should release.
Posted on Mar 07, 2008
Issue one: interior smells issue 2 : door won't open. have 1.run the cycle thru again.2 paused & started. 3 re-set. 4 turned off. 5 turned off at power point (1hr +)6. run the rinse & drain cycle...
Solution 1: leave door open when not in use and run enzyme cleaner like affresh, or 2 cups of distilled vinegar weekly until smell is gone.
Solution 2: Most of the front load waahers have a manual door lock release. This is usually accessed by removing the bottom front cover and reaching up to the door latch assembly, to pull onrelease cord/plastic ring. If door locks stuck again, you will need to replace the door lock/latch assembly.
Nov 08, 2013 | Whirlpool AWM6100 Front Load Washer
Service code sc520
Paper tray error.Try reset by open/close the front door,if not reseting enter in the service mode :press mode(yellow)key-107-Clear/Stop(red)key (keep pressed more 3 seconds) enter in SP mode,open the front door and turn OFF the copier.Wait 1 minutes and turn ON.
Mar 27, 2013 | Ricoh MPC3500
Hp cp2025 error reads "front door open" when front door is closed
pront door liver switch open not work it ,or it displace.you should check it or service need
Sep 12, 2012 | HP Laserjet Cp2025n Printer
I need information on how to replace (or service) the door latch mechanism on my merc. I have realigned the door (and realigned the striker rod) and it will still not close. The latching system does not...
Removal
  1. Disconnect battery ground cable (14301).
  1. Remove front door trim panel (23942) and watershield from front door (20124).
  1. Mark the location of the bolt retaining front door glass run front retainer (21572). Remove the bolt.
  1. Check all rod connections against the appropriate illustration. Correct any disconnected or loose connections and check operation before replacing parts.
  1. Remove power door lock actuator (218A42).
  1. Disconnect the rods from the front door latch (21812). The front door latch remote control link (21940) and the latch-to-lock cylinder rod cannot be removed at this time because of the rod's end configuration. Remove wiring from clip on front door latch shield.
  1. Remove front door latch control cylinder rod (22134) from the door lock cylinder (21985).
  1. Remove front door latch remote control and link (21818).
  1. Remove the front door latch retaining screws. Disconnect the door open warning lamp switch (14018) if so equipped. Remove the front door latch from the front door.
  1. NOTE: Do not damage anti-theft shield.
    Remove anti-theft shield from the front door latch.
  1. Remove front door latch remote control link, front door latch control cylinder rods and door open warning lamp switches from front door latch where applicable.
Installation
  1. Follow removal procedure in reverse order.
  1. Tighten front door latch retaining screws 4-8 Nm (36-70 lb-in).
Item Description 1 Front Door Latch Control Cylinder Rod 2 Front Door Latch Remote Control Link 3 Bushing 4 Door Latch Shield 5 Power Door Lock Actuator 6 Front Door Latch Control Cylinder Rod 7 Front Door Latch 8 Latch (1 Req'd) 9 Screws (2 Req'd)
Feb 13, 2011 | 1997 Mercury Cougar XR7
Need to remove drivers door panel
please rate if this helps. Section 01-05: Trim, Interior 1995 Thunderbird, Cougar Workshop Manual REMOVAL AND INSTALLATION The interior trim component Removal and Installation procedures generally apply to all models. If some of the steps do not apply to the particular models being serviced, proceed to the next step. Trim Panels, Door Removal and Installation
  1. ssd~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not pry front door trim panel (23942). Prying on front door trim panel will break the hook retainers.
    Disconnect battery ground cable (14301) .
  1. Carefully pull front door trim panel finish panel (23712) away from front door trim panel .
Item Part Number Description 1 23713 Front Door Trim Panel Finish Panel 2 17B676 Outside Rear View Mirror Control 3 14028 Door Lock Switch 4 55928-S55 Screw (5 Req'd) 5 14529 Window Regulator Control Switch 6 23942 Front Door Trim Panel
  1. Disconnect wires from front door lock switches (14017), outside rear view mirror controls (17B676) and window regulator control switches (14529) , if equipped; remove front door trim panel finish panel.
  1. Remove front door trim panel retaining screw through front door trim panel finish panel opening.
    Trim Panels, Door
    Item Part Number Description 1 20124 Front Door 2 23942 Front Door Trim Panel 3 383356-S100 Nut (2 Req'd Each Side) 4 56903-S58 Screw (2 Req'd Each Side)
  1. Remove interior lamp lens cover.
  1. Remove screw through interior lamp opening.
  1. Slide front door trim panel upward to disengage hooks.
  1. Rotate top of front door trim panel away from front door (20125) , and lift bottom hooks from front door.
  1. Disconnect window regulator jumper wire (14A630) .
  1. Remove front door trim panel.
  1. To install, reverse Removal procedure.
May 07, 2009 | 1994 Mercury Cougar
I cannot open the door of my washing machine. Is there some sort of emergency button to automatically open the door? it's been jammed for 3 weeks now. Please help!
To manually unlock the door lock system:
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about quarter inch or until a click is heard.
6. The door may now be opened
Or pull out your dispenser tray, along the rear edge you will find a cord, pull this like above. Depends on your model.
Apr 01, 2009 | Bosch Washing Machines
Creaky car door
I believe you will need to replace the part that limits the opening of the door. It is found between the 2 hinges.
Mar 14, 2009 | 1995 Saab 900
Front Doors Won't Open?
Hyundai sonata have small spring about 3 cms long which corrodes and brakes. When this happens you cannot open the front two doors. you have to unfortunately cut a hole in the door trim and open the door by realeasing the latch with hand and then replace the spring.
Oct 03, 2008 | 1997 Hyundai Sonata
Washer Door will not Open
door lock blown motor problem for the noise appliance doctor
Jan 29, 2007 | Hotpoint WMA58 Front Load Washer
Bosch Axxis+ WFR 2460 Front Load Washer Logo
294 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
