Question about Canon ImageClass D880 Copier
A piece of paper is jammed at the out feed roller. I was able to get some of it out but not all. Is that roller removable? Does the Platen come off so that I can access this roller from the top? Thank you, Mark
    Problem Solver:
  • 5 Answers
You probably have a damaged fuser. It really takes a skilled tech to remove and replace the fuser. A new fuser costs about $200 and an hour labor to install it.
Posted on Aug 13, 2010
My oki c3400n continual paper jam's at the fuser. Paper comes out of the printer about 2 inches then jam's. I clear it and it happens again. Don't see any contamination on the fuser roller.
There are paper path cleaner sheets that you can get at supply stores or on line. They are sticky on both sides. They pick up paper dust from the rollers as it passes through the printer.
Feb 17, 2016 | OKI Office Equipment & Supplies
Printer is not print properly & paper jam problem. how repair the printer &how to troubleshoot the printer &how check out ,which part have problem.
When you removed the jammed paper, did the paper come out inone piece, if not did all the pieces that were removed make up the entire sheetof paper?
Otherwise there may be still a small piece/s of paper still in the printer,which is causing this error message.When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper.The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Nov 28, 2011 | HP Office Equipment & Supplies
When I hit print when the paper starts to feed the pushbar paper feed does so fast causing the paper to start slightly off caqusing a paper jam.. Is there anyway to adjust the feed
Nov 03, 2011 | Canon Pixma iP2600 InkJet Photo Printer
I need help repairing my copier. The pages are wrinkled when they come out. I was making multiple copies when it paper jammed twice in a row. i removed the paper (no pieces left) and now half of my paper...
Otherwise there may be still a small piece/s of paper still in the printer,which is causing this error message. When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Sep 04, 2011 | Office Equipment & Supplies
How do you replace the platenroller guide rollers?
to replace the feed rollers under the platen. 1 - remove the platen by squeezing the black plastic clips at the ends of the platen and pulling the platen straight up. 2 - pull the paper pan out, 3 - push down on the feed roller set and rotate it towards you. replace bad rollers and put things back in reverse order. there is a guide on the rod the feed roller unit sits on, make sure the guide on the feed roller unit goes back in this. there are pins at the right side and left side of the right and left feed roller units. these are for positioning the paper pan in the slotted tabs on the bottom of the paper pan. make sure the gear on the platen goes on the left side, position the clips to center on the frame, then push straight down. make sure both clip are fastened in. the only reason you should be replacing these rollers is if they are splitting apart or falling off due to the pins at the ends of the rollers wearing off (never seen this happen on a WW6) if you are having some sort of other problem, you might ask for a different solution before doing this - its harder than it sounds.
Dec 20, 2010 | Lexmark Wheelwriter 6 Series II Typewriter
Hi, "ALARM" appear on my
Hi Good day!! Maybe you have a paper jam that cause your printer to alarm.
To clear a rear-feed paper jam:
1. Turn off printer
2. Turn platen knob to back paper out of printer. Remove any ripped pieces of paper.
3. Reload paper, turn printer back on and press FF/LOAD button.
If your paper keeps jamming the chances are excellent that you have bits of paper stuck in the paper in the paper path. To eliminate this problem:
1. Turn off printer.
2. Use platen knob to back paper out of printer.
3. Remove the paper separator.
Thank you for using fixYa
Don't forget to vote thanks!!
Nov 03, 2010 | Oki Electric Industry MICROLINE 791 Matrix...
My dcp 150c printer has been jammed for weeks, i have done everything it said in the manual but it won't unjam
This Brother printer could have a piece of paper stuck in it. When a paper jams, assemble the jammed page pieces to make sure all the pieces came out.
A jammed paper can also knock loose the paper detect arm that senses a paper in the machine. This detect arm is usually near the platen (The roller the print head prints against) to detect paper in the machine. If this arm is stuck, it could be sensing paper when there is none.
Rubber paper rollers should all be cleaned with rubbing alcohol or a mild soap solution (I use Windex) to prevent feed jamming.
Mar 28, 2010 | Office Equipment & Supplies
My canon i850 is blinking 3 orange lights at me and refusing to print. any ideas. tried turning on and off. removing print driver and re-installing thanks!
3 blinks is a line feed error, something stopping the platen roller from turning, look inside where the paper goes and see if something fell in like an ink pen, paper clip, just something that doesn't belong. The platen roller is the gray roller behind the carriage and sometimes you can see thru under the white plastic guides something jammed.
Nov 25, 2009 | Canon i850 InkJet Photo Printer
Typewriter is a SD750 Paper will not feed in evenly.
Something is usually caught on a feed roller, like a gluey label or piece of paper..sometimes its on the back roller which you may not be able to see. Some time the only way to remove these is to remove the Platen(roller), which I don't recommend for the user to do.
Squipps
Jul 05, 2009 | Smith Corona Office Equipment & Supplies
Remove platen on Swintec 8011 typewriter
I can't remember which models have which features, but some Swintecs have pop out plantens, and some don't. If it is pop out, you will find a plastic V clip in the frame of the typewriter through which the platen shaft passes on both sides of the typewriter and platen. Pay close attention to which side the gear of the platen is situated before removing to make sure you put it back on the same side of the typewriter. Squeeze the V clips and pull the platen up and out. When re-installing, make sure the metal paper table is in correctly by aligning the fingers on each side into their mounting guides, or you will have paper jams, paper feed trouble, and other issues. You can clean the labels out with something that will not leave an oily residue on the paper table, paper feed rollers, or the platen. Re-install the platen by aligning the V clips to the frame on each side, and press them down until they snap into place.
Mar 23, 2009 | Office Equipment & Supplies
Canon ImageClass D880 Copier Logo
55 people viewed this question
old marine
old marine
