Question about Liebherr Premium K 2954 Top Freezer Refrigerator
Freezer not freezing, or if it is lettuce etc in fridge freezes
Bought a Liebherr CUP 2721 fridge freezer on 23/12/09 as old one broke down again (once to often). It is inside a brick outbuilding. We plugged it in but the freezer was not working so as instruction book said turned the switch in fridge up to max. Freezer froze but so did 4 lettuce and salad stuff in the fridge for Christmas. So turned it down to 4.5 and the bread in the freezer thawed out. Have been trying for the last month to sort it but no luck yet. Even at 6 it is not cold enough to keep bread frozen it is just chilled more than it would be in a fridge. At the moment I am using the whole thing as just a fridge (lucky that I have another large upright freezer stood beside it). PLEASE CAN YOU HELP ME.
    Genius:
  • 1,036 Answers
With fridge freezers, there is usually a solenoid at the back that controls where the refrigerent goes. It consists of a sealed valve and a solenoid coil. It is possible that this has become open circuit so cannot direct refrigerant to the freezer section.
Another alternative problem may be the thermistor in the freezer section. This sensor will tell the control board the temperature in the freezer section. If it gets it wrong, then the freezer will overcool or not cool at all. Often a manufaturer will standardise on a part, so swapping the fridge and freezer thermistors around can identify that this is the fault - then just buy another 1.
If these tests don't work, you're looking at a new control board. Second hand ones may be available.
Best of luck.
Posted on Feb 08, 2010
My freezer isnt working correctly ,isnt freezing the food and the fan only kicks in now and again and there is ice at the back of the freezer .can you help
It seems that the efficiency of the fridge has dropped as there is frost forming within the system due to a possible failure in the control circuit or the auto defrost timer.
It can also be related to a failure of the circulation fan or the thermostat.
Shut off fridge for about 6 hours and if it cools then the defrost timer must be checked along with the heaters.
Aug 02, 2011 | Beko TLDA662
Turn fridge into freezer
Not really. UCR means under counter refrig. It could freeze some products, like lettuce, but the unit will not function for long periods of time as there is not defrost cycle and it will freeze up.
Jul 22, 2010 | Beverage-Air 6.2 cu. ft. / 176 liter...
Food keeps freezing in my fridge. Even at the lowest temp.
in the fridge compartment check behind the control panel where the light bulbs are remove this cover and make sure the damper vent door opens and closes when adjusted with the fridge control sometimes they ice up from condensation and freeze in one position and this may let too much cold air in from the freezer for too long,otherwise it also could be a defective electronic control board in this same area
May 13, 2010 | Jenn-Air JFC2070KRS Stainless Steel Bottom...
Food freezing in fridge compartment in my side by side
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Jan 26, 2010 | KitchenAid KSCS25FKSS Side by Side...
Freezer stopped working
Pour about 1/2 cup of water into ice maker . If it dumps the cubes , then replace the water valve . If it doesn't , replace the ice maker . Also make sure the refrig coils are clean and free of dust , lint , pet hair , etc....
Aug 12, 2009 | Refrigerators
Fridge too cold
First, clean it the unit out and fully defrost.  Clean the condenser coils.  Don't pack in so much food, don't open the door too frequently.  Never block any air channels. Never leave uncapped liquids in the fridge or freezer.  Set the fridge at about 40 degrees...use an outdoor thermometer.  Freezer at about 0-5F.
Aug 21, 2008 | Kenmore 64802 Top Freezer Refrigerator
Freezer cold but not freezing
Check the settings for the freezer control. Refrigerator temperature control normally controls the run time of the compressor. if the freezer control is set to low the refrigerator temperature will be fine and the freezer will be warmer. Setting the freezer control to a colder setting will hold back more cold air in the freezer and reduce the air volume supplied to the refrigerator. Check and make sure the condenser coil is clean.
Jun 08, 2008 | Liebherr Premium CTP 3153 Top Freezer...
Fridge is freezing food
no more than likely that your thermostat is faulty all f/freezers have 2 stats 1 to keep fridge cool and 1 to the freezer u will need to replace the 1 in the fridge m8
Aug 15, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Liebherr Premium K 2954 Top Freezer Refrigerator Logo
394 people viewed this question
Top Liebherr Refrigerators Experts
Dan Webster
Dan Webster
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
