Question about Dell Latitude D520 Notebook
I think motherboard power problem
When i press power baton,power stay 2/3 second than it going to off.i alredy diassemble my laptop.instant i just connect my addepture and motherboard problem is same.i connect processor,ram and switching,problem is same.
    Genius:
  • 3,587 Answers
Hmmm...sounds like the connections are fine. mayhaps you have a major component failure, like uP?
check your warranty for FREE here
Posted on Feb 22, 2008
I have nx9500. No power on response UNLESS 1.) battery is removed and 2.) on/off switch held down for 30+seconds and 3.) AC brick then plugged in. When all this is done and on/off switch pressed, the LEDs...
It would appear from what you say, there is a short on the motherboard. This can cause the adapter to shut down, which it is suppose to do. Unless there is an object in the laptop, the motherboard is damaged and must be repair/replaced.
Please rate this solution.
Apr 07, 2011 | HP Compaq nx9500 Notebook
I have a compaq presari R3000 which fell down when I put it my bag. After I tried to trun it on, when I press the power button, the power light just on,the both fan run about 5 seconds and stop, after 10...
The ribbons of the laptop inside may have been dis-attached, please bring it to an expert immediately and don't try to open or touch anything inside it.
Mar 08, 2011 | Compaq Presario R3000 Notebook
No power comes to the laptop..what could be the issue? dont see any lights lighting up...
First: Pull out the battery and try to power it on with the AC adapter only
Second: If that doesn't work check the power Jack, sometimes it gets deattach from the Motherboard, you may need to diassembly your laptop
Third: If you find no problems there, then it may be the video card: for this you need to reflow the motherboard. A local computer shop may be able to do it. if it's too expensive you may be better buying a new laptop
Nov 19, 2010 | Gateway MX3416 Notebook
I have a dell Inspirion 9400 and it won't start. When I press the power button, all that happens is the power light and the dvd player light comes on and about 3 seconds it turns off. Does it with and...
It shows no power on your laptop but it shows you the dvd player led comes on then off. I would suggest try the following:
1. Remove laptop battery, optical drive, hard drive and ram. Remove external peripherals as well. 2. Make sure AC Adapter is not yet connected to the laptop. Press and hold on the laptop's power button for 10 seconds to drain the power flea. 3. Connect the AC Adapter to a known good power outlet, check AC Adapter power LED if it is on. Try to sense if AC Adapter is not making a bit of noise when it is plugin to the wall power outlet. 4. Connect now the AC Adapter to the laptop. Check if AC Adapter LED stays on when it is connected to the laptop. If the LED stays on means the AC Adapter is fine. If the AC Adapter LED turned off check the AC Adapter pin that goes to the laptop AC socket if it is loose. 5. If AC Adapter stays on after connecting to the laptop try to power on laptop. If no power LED comes on then this is motherboard problem. 6. Before replacing the motherboard there is one checking needs to do. If you can open your laptop bottom part then good, do this when laptop is not connected to any power source. Try to reseat the laptop CMOS battery then try to power on laptop after, if still fails then replace motherboard. I hope this helps.
Dec 12, 2009 | Dell Inspiron 9400 Notebook
Problem with Biostar P4M800-M7A Motherboard
The motherboard isn't the problem, it seems something is conflicting with another thing. If your using IDE (the buttload of pins on a thin long cord) you might need a cord that has 2 wires that go to the same pin. They usually are faster anyways. Get a new set of IDE cables then. Or your ram is malfunctioning and you need some new sticks of some. The last ones could be that your processor is fried and well you figure that one.
Sep 27, 2009 | Biostar P4M800-M7A Motherboard
NO VIDEO OUTPUT FROM LCD OR EXTERNAL MONITOR ON TOSHIBA SATELLITE L20 LAPTOP
you may do follow steps
1) eheck memory : reseat all RAM or change other same model RAM
2) take out wireless card at back of laptop MINIPCI. try it
3) still nothing run, your otherboard hardware damaged, need to change the motherboard. the parts please reference here
http://shop.ebay.ca/items/__Toshiba-Satellite-L20-motherboard_W0QQ_kwZToshibaQQ_kwZSatelliteQQ_kwZL20QQ_kwZmotherboardQQ_ckwZlaptop?_trksid=p3286.m104.l1200
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
May 22, 2009 | Ultra Computers & Internet
When I turn on the power to my laptop, tries to turn on but dies
According to me, you should check your power adapter. I think it is not working and is not producing sufficient power supply for your laptop. And due to this, your laptop have not been charging.
Jan 17, 2009 | Intel Motherboard
Dell Latitude C610 Laptop won't turn on
If the light comes on for three seconds and then go out ,generally means a power distrubution problem . remove the optical drive and memory from the system and try powering it on. If u get the same result , its time to take it to service tech , as your motherboard needs to be checked
Apr 07, 2008 | Dell Latitude C610 Notebook
Dell Latitude D520 Notebook Logo
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
