Question about Welding Tools
Weld-pak 125. The speed control doesn't work
I have a weld-pak 125. The speed control doesn't work. It spits wire out at top speed when the trigger is pulled. I checked the wire speed potentiometer out and it ohmed out properly. Any ideas? It hasn't been used much, but it is an older unit.
  • Anonymous Mar 24, 2014
    wire speed drops after welding starts
  • 677 Answers
Check out this lincoln website for parts :I whttp://content.lincolnelectric.com/pdfs/products/navigator/parts/lemenu.pdfould
I would say it is the speed contoller.
Please let me know what you find out.
Posted on Feb 08, 2010
Wire feed have erratic speed when welding.
adjust your speed either up or down to match the amps required to weld
Jun 08, 2015 | Lincoln Electric Handy MIG K21851 Welder
Why does wire weld to tip when trigger is pulled when welding aluminium
The tip of the welder may need cleaned out, your feed speed might need slowed down, check the polarity is it straight or reverse?
Sep 20, 2014 | Welding Tools
Lincoln weld pak 100, no heat penatration on the D setting
I believe your voltage control rheostat (potentiometer) must be worn out. Check your owner's manual for the part number and request it, it's not expensive and it is an easy part to replace. If you are doing that would be a good idea to do the same for your speed control rheostat.
Or clean them if you can, take off all the carbon particles that it build up with the time.
Mar 20, 2014 | Welding Tools
Weld-pak 100 Hd Problem
There is a reset button located in the wire feed spool compartment,
check to see it stays in when pushed. It is a safety when the machine
overheats, it normally resets when machine cools off. If it is working properly I suggest contacting Lincoln Electric Dealer for service.
Mar 03, 2012 | Lincoln Welding Tools
I have a clarke weld 85 en mig welder which starts to weld without having to press the trigger on the gun. what could cause this please
I have a clarke 85en no gas welder. the gun on this particular welder is always live the trigger only feeds the wire
Mar 08, 2011 | Welding Tools
Weld arc not stable. Wire feeds, good ground, everything looks good, liner pulled and cleaned, new tip.
Try moving the tip closer to your work and try turning your wire speed down
Most people want to crank up the wire speed when it spits and sputters
Turn it down
See if this helps
Mar 16, 2010 | Hobart Handler 140 Mig Welder
I have a Lincoln Weld Pak 100 that was working fine. I shut down the machine though and when I came back to it about 5 hours later the wire feed motor wouldn't turn anymore. Has anybody else had the same...
Check the voltage at the wire feed motor when the trigger is pulled.
I had a Weld Pak 100 that with 0 volts at the wire feed motor, and the problem wound up being that 2 of the big power (stud) diodes were shorted.
Feb 26, 2010 | Welding Tools
I have a Migmate 120 Dual purpose welder, it is difficult to get a smooth weld. I have adjusted the wire feed over and over. It seems as if there is not enough pwer?. All the leads and power supply are...
it is a combination of feed speed and welding amps and correct gas flow
if you are using core flux wire and not gas make sure that you reverse polarity for the flux wire
Jun 27, 2017 | Audio Players & Recorders
Welding Tools Logo
202 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
