Question about Brother IntelliFax-1860C Plain Paper Inkjet Fax
Why does my fax machine use up tje color
Why does my fax machine use up the color cartridges when i dont make color copies
    President:
  • 3,085 Answers
All ink jets mix all of the colors every time, even for black.
Posted on Feb 08, 2010
Why do copies in color have multicolored streaks while black & white are fine?
There is a good chance that your color ink cartridge needs replacement. You can tray wetting a paper towel and putting in the microwave for 5 to 10 seconds then placing the cartridge on it for a few minutes. This sometimes will correct that type of problem...Be careful the paper towel will be hot (handle with care).
Aug 04, 2014 | HP Officejet Pro 8600
Black ink not working lexmark pro915
Check ink level, clean contacts on cartridge and machine.
Oct 10, 2013 | Lexmark Pro915 Wireless All-in-One Inkjet...
Received faxes, cartridge has run out how can I print or send to PC
some new fax machines has, fax memory older models dont, so if your fax machine is old. the fax has been lost, because when printing is one time (dont preserve on fax memory, only the comunication numbers. try talk to your fax senders send again a fax copy,
Jan 14, 2010 | Office Equipment & Supplies
Running out of color ink even though we dont use the color
It's probably not running out but drying up. Make a color copy from time to time to keep the ink fluid.
Apr 09, 2009 | Brother Office Equipment & Supplies
I Need to Print
Sadly in a word, 'No'.
Here is the exact answer from Brother:
Your Brother machine is designed to stop ALL printing operations
(printing from the pc, printing received faxes and printing copies or reports) when any of the ink cartridges are empty. This is to ensure the life of the print head and maintain premium print quality. If the unit were to continue printing, print jobs and cleaning cycles would suction air from the dry cartridge and damage the printhead. Even if you print in black only or change the print settings to MONO or GRAYSCALE to avoid printing in color, the programmed cleaning cycles would still suction the dry cartridge, because they are programmed to clean ALL the ink nozzles.
The only way to continue printing is to replace the empty ink cartridge or cartridges.
While memory is available, black and white faxes will continue to be received into memory. If a color fax is being received, the Brother machines HANDSHAKE will request the fax be sent as black and white fax.
All faxes received into memory will automatically print once the ink cartridge is replaced.
NOTE: Brother strongly recommends that customers do not use generic ink or refill their Brother ink cartridges. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability since the ink formulation in genuine Brother ink cartridges prevent smearing and clogging of the print head. The Brother limited warranty does not apply to any problem that was caused by the use of unauthorized third party ink and/or cartridges.
Nov 26, 2008 | Brother Multi-Function Center MFC-240C...
HEWLETT PACKAED OFFICE JET K60XI-WHEN I TRY TO MAKE A COPY THE SCREEN SHOWS REMOVE AND CHECK COLOR CARTIDGE
Try disconnecting the power. If you've removed and checked your color cartridge and it looks fine, the problem is most likely a defective cartridge. Cartridges can be defective right out of the box, or they can fail if they haven't been used for a while. Replacing the color cartridge should solve your problem.
Aug 10, 2008 | HP Office Equipment & Supplies
Copy machine won't copy
you will probably have to have all cartridges working.
Aug 04, 2008 | Brother MFC-8220 Fax
Brother IntelliFax-1860C Plain Paper Inkjet Fax Logo
66 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
