Question about Lakewood Oil-Filled Electric Radiator Heater
My heater just stopped working. I tried it in
My heater just stopped working. I tried it in different outlets, but no luck.
Mr. heater big maxx keeps blowing fuses, Replaced everything in it and still does it. sometimes it will run for a while
Maybe its the wire or the outlet. Does the wire get hot? Try a different outlet that is on a larger amp breaker.
Dec 07, 2016 | Mr. Heater Heating & Cooling
Gfci trips heater not turned on
GFI is Ground Fault Interrupter (or GFCI - Ground Fault Circuit Interrupter) It is doing its job, telling you that there is a short in the unit or wiring. Have a certified electrician check the wiring and unit.
May 17, 2014 | Pentiar Pentair MiniMax 100 BTU Natural...
Bosch gwh 425 hno-l
CHECK LIST
- is the BTU'S enough for the space
- is there proper flow through boiler
- should have 20'F-30'F difference between inlet and outlet temp
- is there air in the system
- is there a lock on via controls that is set to lock out under 20'F
- no matter what if boiler is working properly it should be able to maintain 20-30'F temp difference from inlet to outlet
ex. 60'F in, 85'F out = 25'F split boiler is working right, if temps do not rise means house insulation my be so bad BTUS calculated for the coldest conditions was to low
May 20, 2017 | Water Heaters
My Dimples heater is four years old and this is the first problem I've had with it. The problem: After I turn it on it runs for about five minutes and then quits. I've tried it on different outlets...
it may have some internal lose connection or beeing a heater its darmostart may failed...... please check it out and have a trail with out dharmostart... so that you will get exact solution.........
Oct 22, 2010 | Dimplex DS5603 Heater
Using my wet/dry vac - less than 5 hours on the thing - it just stopped - can't get it to switch back on. Tried different plugs - different days. Although I purchased over 2 years ago, it has hardly been...
It may have gotten hot if you went too long before cleaning the filter. It sounds like you may have burnt it up. I hope not! You might also check to see if you tripped a breaker on the electrical panel. Try plugging it in an outlet that is not on the same circuit. If it works in another outlet, then you have just tripped a breaker.
Good Luck!
Jim
Sep 30, 2010 | Genie Company GV150 Wet/Dry Vacuum
Lakewood oil-filled heater not heating up
It is quite possibly the thermostat. Dont risk your health these heaters are not very expensive and I would suggest going to buy a new one from your local department store.
Feb 02, 2008 | Lakewood Oil-Filled Electric Radiator...
Honeywell Compact Quick Heat Ceramic heater with tilt feature - HZ 325
Your prob is their is a thermostatic solinode that is trigger the unit to go off--because it thinks itself as too hot and unsafe to be on--this trigger was defective or damaged by disuse and/or fatigue------give it a shake-- better yet, when cool and unplugged-vacuum or blow out with compressed air-with out disturbing integrity of workmanship on device--if that no worky--time for new one---thermostatic element is dirty, device being of differing Mghz than outlet, if fairly new device--amperage of outlet is too small for device to work properly. If it is a 240 volt or a 120 volt device and your attempiting to use the wrong voltage outlet--STOP USING THE DEVICE
Jan 21, 2008 | Honeywell HZ-325 KAZ Ceramic Compact...
Delonghi TRD0715T Safe Heat Oil-Filled Radiator will not work, won't turn on its new just taken out of the box
Ditto same problem. Took it out of the box, plugged it in the electric outlet and did not turn on.
I tried atleast 5 different electric outlets to make sure nothing is wrong with the outlet. Tried changing the timer settings. No use.
Returned it to Lowe's.
Nov 17, 2007 | DeLonghi TRD0715T Oil Filled Radiator...
Heater is getting power, but will not work
I guess of heater element are open and this can cause the fan from not working because both of them are on the same wiring
Jan 26, 2007 | Marvin 3150 Mid-Size Heater
Lakewood Oil-Filled Electric Radiator Heater Logo
115 people viewed this question
Top Lakewood Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
Paul Carew
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
