Question about Asko Washing Machines
F6 is flashing on my washer what can I do? - Asko Washing Machines
    Brigadier General:
  • 3,917 Answers
F 06 is a fault with the motor control board
· Check wiring to motor or the wiring harness attached to the board next to the motor.
· Replace motor if necessary
Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
Posted on Feb 08, 2010
I have an f6 code and the machine will not operate once it comes up
The F6 error code means that the computer on the control didnt detect that the motor reached a high speed on the spin cycle, sometimes it thinks the washer didnt spin fast enough because of a loose wire connection either on the motor or the control boards (motor &machine control) if you find that the washer did actually spin at high speed (clothes dont come out sopping wet at the end of cycle) the wire connections or the motor control board will be the potential causes of the F6 error code. Try unplugging the machine for five minutes to let the computer reset then try again. Next check the control panel wires. f6 code flashing on display Kenmore Elite HE3 Washing Machine
May 19, 2015 | Washing Machines
We have an ASKO W6451 flashing F6. appears to jump from 1 minute to go to 20 minutes to go then flashes F6. would it be something electical?
Asko F6 error is apparently a motor fault. The motor could be jammed, open circuit , burnt out?? It may just be a broken wire or connection come off. Check "Google" and type in Asko F6 error. There is a lot of info about it.
Dec 27, 2014 | Asko Washing Machines
Why does the washer stop during a load and "F 06"
GENE
Sep 09, 2011 | Kenmore HE2 Plus Front Load Washer
F6 error! Machine stops working. Flashes F6 and beeps.
Hi!!
The F6 error means Drive motor tachometer error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU) • Check the Drive Motor • Check the MCU • Check the Wire Harness
Replace failed component.
Good Luck! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa!!
Feb 16, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washers is flashing f6 and it partially washes then stop
Youve got either a bad motor control, slipped belt, a bad motor, or the wires have come unconnected. If your tub is turning in the few tumbles that it does do then you can probably rule out the slipping belt.
Jan 09, 2011 | Whirlpool GHW9150 Front Load Washer
Kenmore Elite front load
theres an error between the motor control board and the central control board,,meaning you might have lose connection,,or burnt,wire,,this i would let a technician look at,,,good luck
Jan 03, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3t
The machine control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check Wire harness connections between the Drive Motor/Tachometer and the Motor Controller, and between the Motor Controller and the Machine Control
• The Drive Motor has failed
• The Motor Controller has failed
Jun 14, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he4t
CHECK DRAIN HOSE coming from washer TO ENSURE WATER IS DRAINING PROPERLY down drain.
USUALLY YOU CAN RAISE DRAIN HOSE A LITTE AND RESET WASHER TO RINSE & SPIN F6 is caused by water not draining Fast Enough
Dec 12, 2007 | Kenmore Elite 45986 Front Load Washer
F6 flashing and won't spin
There may be a bra wire stuch between the drums. Try to pull it out through one of the holes and keep in mind that if it is a bra wire, that it is curved and will need to be pulled out at an angle.
Oct 23, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
