Question about Compaq iPAQ MP3800 Multimedia Projector
Vivitek d326wx indicating "no source found" Windows XP
Projector driver
the projector is flaw
something wrong with the mother board of the projector
something wrong with the interface board (video board)
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD, motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 10, 2014 | Vivitek Office Equipment & Supplies
Hi--my new Vivitek D5 projector is not connecting to my Macbook. I have a mini DVI converter attached to a vga to DVI video adapter, but the projector can't "find" the source.
Please check your port with another source to confirm the working of the PC. Now also try to see if the projector connects with another PC. This will confirm the culprit as it is possible that there is a signal mismatch to the source input and hence not detected.
Oct 14, 2011 | Vivitek D511 3D Projector
Source not found I am using an Acer Aspire One
Make sure you are using ports other than the USB port. Vivitek Service indicates that at least some of their projectors do not use the USB port for input. "The USB port is not in input port. This is used for service only. Please use another input port such as RGB input. Regards, Vivitek Customer Service
Hope this helps.
May 16, 2011 | Vivitek D825MS Projector
The lamp turns on for a second and you can see the vivitek logo on the screen then it goes dark
some projector are normal like what what you mention...you need to connect a video source like computer or sound system that have a video output going to your projector...because if you power on the projector with out a video source you see only what you mention the logo of the projector..
Mar 10, 2011 | Vivitek D510 Projector
What remote controls that are compatiable to Vivitek model RP51HD41-A and what are the codes to use to the compatiable remote control?
your cable or satellite will do just fine. i have a vivitek rp51 and i was told that if i lost my remote i was SOT well i found out that the parent company of vivitek is DELTA and wouldn't you know it i programmed my direct tv remote using the brand delta wich was on the list and it worked... by the way vivitek is not on any list for remote control codes....
Sep 25, 2010 | Televison & Video
Looking for the enter code for vivitek tv model # rp51hd41-a a 51" micro display projection tv
Jan 14, 2010 | Vivitek V37655 56" DLP TV
Hi, when I start my IBM laptop I received an Unload error "1706 no valid unload source could be found for product." What does that mean and how do I repair the problem? I am using Windows XP.
as per my experince
I suspect your problem is related to the fact that you are loading
software on CD-ROMs from a DVD drive and XP is having problems
locating the drivers but the fix isn't simple.
Microsoft says that Error 1706 is a Microsoft Office Error code which
indicates that required files can not be found by Setup. Since you
are trying to install new programs I feel that this is probably the
correct interpretation of your error code.
Microsoft's Knowledge Base Article 297834,
http://support.microsoft.com/default.aspx?scid=kb;EN-US;297834
Oct 25, 2009 | Microsoft Windows XP Professional
Compaq iPAQ MP3800 Multimedia Projector Logo
Top Compaq Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Greg Cann
Greg Cann
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
