Question about Ovens
I am a baker and just got some vanguard vectronic ovens and dont know how to put new programmes into them eg scones 20 mins 180 c they only have 3 buttons and they have some programmes in them but would like to add more
The fan in my oven takes about 20 mins to come on, is there something I can do? Or what is the reason for this?
No make or model some fans are programmed to come on at a certain temp around 180-200F
Feb 09, 2015 | Ovens
Kenmore oven take a long time to heat up, but bakes just fine once it reaches temperature. Is there anything I can do to speed up the heating process?
Start earlier?
>> check all elements for current,
check seals
check temperature calibration (allowed to be 15% ie 180 can be 153 or 207 Celsius!) no wonder Margs' scones cook faster at her house :-)
Oct 15, 2013 | Kenmore Elite Stainless Steel 40" Dual...
Faulty programmer - oven switches itself off
Try powering everything off at the main switch, waiting a few mins, switching back on and set the clock. Make sure the oven clock is in manual mode and switch the oven on and see what happens.Let mw know.
Jan 01, 2010 | Stoves 720EF Electric Double Oven
How do I turn oven off with the oven programmer on zanussi oven
TURN ON THE OVEN AND THEN UNPLUG IT WHILE IT IS ON THEN WAIT FOR 10 MIN AND TURN IT BACK ON AND IT SHOULD HAVE A BLANK PROGRAMMER .
Nov 07, 2009 | Zanussi ZHQ575 Electric Double Oven
SLOW HEATING OVEN
you may want to check your broil element
turn the unit on and wait a few minutes
see if you can feel the heat from the upper broiler elemnet
some model use both elements to preheat
i dont have your productiuon number so i cannot be sure with your model
anyway
14-20 mins is the industry standard for a 350 preheat...
Oct 25, 2009 | GE 30" Built-In Single Electric Wall Oven...
Baker's Pride P-44s P44s
You can get parts here at this link.
http://www.tmeinc.biz/xbpride.htm
Good luck and please rate
Sep 24, 2009 | Bakers Pride P-44S Oven
Thermostat setting for bakers pride y600 oven.
Hi, those screws are for the calibration of the knob to the thermostat, so your calibration is correct. Most likely you will have to contact a servicer to check the calibration, and set you knob and plate where they will align with the actual temp again.
Hope that helps, and thank you.
May 19, 2008 | Bakers Pride Y-600 Gas Single Oven
Door on my bakers pride y600 pizza oven
Theses are called 3/4 door busings and should be changed when you replace the left side door rod (complete)and are available from any parts depot that sells bakers pride parts
Jan 20, 2008 | Bakers Pride BAK-DS805 Gas Single Oven
Ovens Logo
209 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
