Question about Mitsubishi WS-65907 65" Rear Projection Television
Static noise at start up
Have Mitsubishi WS-65907 65". Bought Nov 2000. Great tv but lately after turning on, there is periodic static noise with picture and without picture. Also screen may go black with noise. Volume control works to quiet or mute sound. Stays that way for 2 minutes or so and then runs perfect rest of the day. Shut off tv and go out. Come back and turn on. Does it again. Not sure if this is going to get worse over time. Seems to have this problem for no more than 2-3 minutes whenever I turn on.
Thanks,
Parker
  • Red Rag Feb 22, 2008
    Thanks Donster.
    Yeah, I've been wondering how long the bulbs would last. I have been lucky I guess. And they probably got shook up a bit three years ago when the tv was moved across country.
    As for the start up static noise problem, I'll be going out in a while. Before I do, I'll unplug and replug into wall. I have had a Bose system hooked to this forever so I guess if we completely lose the sound eventually we can always run the Bose.
    I'm not going to accept the solution till I return later and turn it on.
    I'll let you know what happens plugged into the wall.
    Thanks
    If that's the case why would the sound be static noise. Sometimes the pic is fine with static noise.
  • 796 Answers
Im assuming it's the lamp however the error menu will tell me more
If the standby light blinks five times repeatedly, that's indication of a "Lamp driver error". The probable cause listed is, "lamp driver faulty". Its also possible that the internal antenna used to detect the presence of high voltage has become mis-positioned. The lamp driver provides the high voltage. If no high voltage is detected, it is assumed that the lamp driver is faulty.
Otherwise, it is assumed that the lamp is bad and the LAMP LED lights
the part number for the lamp is XL2000U. Its available for $200 at http://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do. Use the Part or Accessory Number to locate the part.
Posted on Feb 26, 2008
  • 50 Answers
Being that this is a CRT-base TV, t sounds to me like the tube could be going out as it is having problems when it is warming up.
Posted on Feb 22, 2008
  • 2,336 Answers
The noise it may be comming from one of the CRTs leaking coolant and creating moisture near or around the high voltage connection.
In some cases that can be an easy repair by locating the leak and try to seal it and cleaning the moisture of the CRT, after you will need to apply more sealant to where the high voltage is connected. I have used "dow corning 3140" for that purpose.
The worst case scenario will be to replace the CRT, but for that you should take the TV to a repair tech. If the repair will cost you more than 1/3 of the price of the TV; I would say it may be time to buy a new one.
Let me know if i can assist you further.
    Scholar:
  • 121 Answers
Hi.. i'm sorry to hear you are having so many issues..
if you have any other devices connected besides your cable box, try removing them all while the tv is off.. if this doesn't work, it sounds like the bulb may be going out on your rear projection since they only last typically 3-5yrs depending on use. i had one that started to do the same thing and it seems to be same issue.. it will probably get worse over time until it just goes out since it's about 8years old.. hope this helps..d
  • donna mcgill Feb 22, 2008
    as for the noise, i'm not sure if that is directly related but as far as the tv goes, wow you definitely got your $$'s worth out of that bulb.. is it hooked into something that could be going bad.. maybe a speaker or receiver noise issue but you would have to try and isolate that noise problem between the tv, received and speakers.. let me know if that helps.. just try and plug the tv in the wall with nothing else and see if you hear the noise.. thanks..d
  • donna mcgill Feb 26, 2008
    hi.. just following up to see if you resolved your issue? i didn't see where you have rated anyone so can i be of any help to you? was any of my comments helpful, if so, feedback appreciated if at all possible since i'm a new member;).. let me know if you did resolve this at least and i will mark it as complete on my end.. thanks a bunch and take care! d
Purple static lines and a jumpy picture
Your picture tube is about to go.
If it's still under warranty,take it back.
Hope this helps.
Nov 26, 2013 | Mitsubishi VS-45607 45" Rear Projection...
I have a Mitsubishi rear projection TV (WS-73909) that didn't turn on and had a green blinking light. I replaced the 7 DM capacitors and now it turns on. Both the remote and front control panel ca
Let me know as I can look for this---the set has a keyboard lockout that is cleared by holding the menu or another front button for more than 5-10 seconds with set on---I can find the service manual and check if needed.
Nov 04, 2012 | Mitsubishi WS-73909 73" Rear Projection...
Static on Powering on
You can start out by resoldering all poor solder connections and look for bad capacitors they will be puffed up on Top.
Oct 01, 2012 | Mitsubishi WS-65907 65" Rear Projection...
We have a mitsubishi 55" big screen tv , bought
call sears they will come out for $99 and a free estimate but bringing off the wall I don't know if they will do that but ask them you never know. mine cost $300 to fix and it works great.
Dec 19, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Loud static noise without warning
The audio may be randomly disconnecting or something. I know that when my TV has no signal coming in, that it makes a bunch of loud static.
Jun 04, 2010 | Tatung V20KQDX 20.1 in. LCD Television
When the tv is first turned on, the tv will show fine then occasionaly go to a static screen and audio
SOUNDS LIKE A HIGH VOLTAGE ARC. THIS CREATES NOISE THAT PASSES TO ALL OTHER CIRCUITS. THERE CAN BE SEVERAL PLACES THIS CAN HAPPEN ALL AROUND THE TUBES. THERE SOCKETS AND THE HIGH VOLTAGE TRANSFORMER
Dec 27, 2009 | Mitsubishi WS-65857 65" Rear Projection...
Turns of after being watched for several hours.
Do you have the tools required to solder electronics? Do you know how to solder electronics? Have you been trained in CRT safty ? Do you know about High Voltage safty? Is the tv Model number WS-65809? Do you know how to perform static geometry adjustement on a WS65809 if needed? Do you know how to perform static convergence alignment on a WS-65809? Do you know how to perform fine convergence adjustement to a WS-65809?
IF
The answer is :yes yes yes yes yes yes yes yes
AND
You can retreive an error code of 23 or 24 right after the tv shuts
itself off .
THEN
There is a 95% chance that I could tell you what to solder , no parts need to be replaced in your television and you would not have to pay someone to repair it.
Oct 04, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Loud static Noise
that sertainly doesn't sound normal to me
Jul 29, 2009 | Televison & Video
Mitsubishi ws-55809
Sounds like moisture got into control surface.. Try hairdryer around buttons to dry it out..
Jun 30, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-65907 65" Rear Projection Television Logo
131 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
