Question about HP Color LaserJet 2600n Printer
Images on copies
We had a paper jam a month ago that we had to tear the paper out. we think that a small peice of paper is in there somewhere as anytime we print something there is a small triangle that shows up about 5 times on the paper. any ideas how to remove the piece of paper> can we pop the top off? we have replaced all the cartidges so we know it isn't that.
  • jeaniemac Apr 29, 2008
    There is a faded black mark appearing on the paper (sort of heart shaped). It apears about every 75 mm. I cannot find any problem on the exterior of the black toner cartridge.
  • 152 Answers
Your teflon sleve triangle cut
replace fuser teflon sleeve
Posted on Feb 28, 2008
  • Harshad Patel
    Harshad Patel Feb 28, 2008
    rub that area of triangle cut if black powder remove in particular
    area . so confirm that your teflon sleeve cut
Error message 077-900 help there is no paper visibly that I can see
There is probably a small bit torn off somewhere. Unplug the machine, take the screws off and open up the lower portion from underneath to check. Use a flashlight. Always "fan" a paper ream before placing a pad of paper into the hopper drawer. Using thicker paper helps prevent jambs. Recycled paper, although good for the environment, is not good for printers or copy machines, it contains 20% virgin wood fibre and 80% paper mache'. Recycled paper tears easy as it doesn't have enough fibre to handle the forces of the rubberized spindles along the paper path. Machines that bend the paper twice in the paper path such as HP's are worse at jamming than are Epsons, for example.
Apr 14, 2015 | Dell C1765nfw
Our HP L7680 keeps telling us there is a paper jam...and there for will not let us copy etc. There is no papaer jam?
Unplug the power, open up all the covers and make sure there are no foreign objects (even small peices of ripped paper).
Close everthing up and power on.
If the message persists, there is a sensor problem
Mar 24, 2010 | HP Officejet Pro L7680 All-In-One Printer
My Lexmark 4350 printer keeps saying that there is a paper jam when there is not, can this be easely fixed!
check for any small peices of paper that may have been left behind from a previous jam even a very small peice in the right place can cause this
Jan 17, 2010 | Lexmark P4350 All-In-One InkJet Printer
Message states paper stuck in printer, but no paper is visible.
This often occurs either shortly or immediately after a paper jam in which someone has to pull out the paper that was fed through, tearing it at the same time. A small piece is still in the machine somewhere. If there is a back panel you can remove from the printer it often helps to remove that. Unplug the printer, check with a flashlight, and you'll most likely need tweezers once you find it. You should also be able to roll the paper feeder by hand with it unplugged, if not, check near the gears or at a point where it may block multiple pages from feeding.
I've lost count of how many printers were given to me by owners saying it was broken, and all it was was a tiny peice of paper crumpled up inside.
Jul 15, 2009 | Canon PIXMA iP2000 InkJet Printer
Printer says there is a paper jam but there isn't
: Clear the jam from paper tray 1
  1. Remove all paper from the output tray.
  2. Turn off the product.
  3. Unplug the power cord from the back of the product.
  4. Lift the output tray and then check for jammed paper in input tray 1. Use these steps to remove any jammed paper.
    1. Raise the output tray. Figure 3: Raise the output tray c01321359.gif
    2. Grasp the jammed paper and pull it out of the product, toward you.
    3. Lower the output tray.
  5. Plug the power cord back into the product.
  6. Try printing a document.
    4. Lift the product off tray 2.
    5. Remove the jammed paper from the bottom of the product or from tray 2.
    6. Reposition the product on top of tray 2.
    7. Plug the power cord back into the product.
    8. Try printing a document.
    • If the issue is resolved, do not continue troubleshooting.
    • If the issue continues, proceed to the next step.
If you would prefer to view a video with audio instructions, click here (in English).
  1. Turn off the product.
  2. Unplug the power cord from the back of the product.
  3. Remove the ADF input tray and open the ADF cover. Figure 4: Open the ADF cover c01285903.jpg
  4. Remove the jam cleanout part. With both hands, lift up on the two handles until the part unsnaps. Rotate and lift the cleanout part and then set it aside. Figure 5: Remove the jam cleanout part c01285904.jpg
  5. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open. Figure 6: Lift the green lever c01285905.jpg
  6. Check the ADF paper path for jammed paper. Figure 7: Paper jammed in ADF paper path c01461018.gif
  7. Check for jammed paper where paper enters the ADF paper cleanout. Figure 8: Paper jammed as it enters the ADF paper cleanout c01461019.gif
  8. Gently remove the paper without tearing it. Figure 9: Remove the jammed paper
    • If the paper does not come out with gentle pulling, follow these instructions.
      1. Open the ADF, and then use both hands to gently loosen the paper.
      2. When the paper is free, gently pull it out.
      3. Close the ADF.
  9. Lower the green lever.
  10. Reinstall the jam cleanout part. Push down on the two tabs until the part snaps into place.
  11. Replace the ADF input tray.
    • Figure 11: Follow the correct method to attach the ADF frame c01461020.gifc01461021.gif
    • Make sure that the ADF cleanout part attachment is secure. If it is loose, push down on the two tabs until the part snaps into place.
Jun 22, 2009 | HP Officejet Pro L7680 All-In-One Printer
Pixma mp480 jams paper!!! It occurs on the left side Ive tried different paper and it continues to do the same thing I really disappointing because I just bought 4 months ago and I thought canon was a good...
Please try this and also try cleaning the printer and the paper rollers that it has.
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Canon Pixma MP480 All-In-One InkJet...
PAPER JAM
try this
alternative :
Mar 19, 2009 | Sharp FO DC500 Plain Paper Laser Fax
Crinkled paper and jamming
Where is the paper jam ???? If you have a paper jam in the back of your printer it maybe the fuser unit.....Make sure thaht you don't have a little peace of paper somewhere in the paper path...
For your drum, did you reset the drum counter ????Normally the instruction for resseting the counter is in the drum box...
Mar 26, 2008 | Brother MFC 7420 All-In-One Laser Printer
DCP-7020
My suggestion is to take the printer to the highest floor in your building open a window and see if it can fly. or just use it as a $200 paper weight because after 3 months it has been to the shop 3 times and still is not working they way it should. Bad equipment bad support, and just plain bad product all around.
Mar 04, 2008 | Brother DCP-7020 All-In-One Laser Printer
HP Color LaserJet 2600n Printer Logo
104 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
