Question about Sony 2GB Memory Stick PRO Duo Memory Card
I cannot formatt my memorystick pro duo, magic gate, not even from the camera itself, or my pc. I need the info in it, so I need to formatt it cause it´s impossible to access to the memory stick. It suddenly gave me an error onmy sony cam. What can I do? How can I format it?
  • juliaelenama Feb 09, 2010
    ok, but i would like to recover the data from it.
    I though that if a can formatt I could be able to recover the data.
    so....?
  • april jerome espinosa
    april jerome espinosa May 11, 2010
    do you how to format in command prompt?? click start run type "cmd" then enter check what name of the drive of the memory stick appears in your computer for example it's drive f: type in the coomand prompt "format f: type yes type your label then exit try to open if it is ok.. if not or error occur before or after you have format it it means your memory stick maybe damaged... i hope i've help you..
    President:
  • 281 Answers
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format memory stick
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Posted on Feb 08, 2010
Ahoo.commy sony memory stick pro will not show photos it sais device error on my camera
If possible, copy the photos into pc and then format the memorystick by the camera
Jun 21, 2011 | Sony 1GB Memory Stick PRO Duo Memory Card
My Sony memory stick pro duo magic gate mark 2 is not shows images on pc but in my camera, but the photos are visible on Sony cybershot camera
Some Sony Cybershot camera's have a small amount of memory built into the camera. Double check that the camera is set to put the pictures onto the memory stick.
If the camera is set up correctly, the memory stick may not be formatted correctly for your computer. If at all possible, connect the camera to your computer directly with the USB cable that should have come with it.
May 31, 2011 | Sony 2GB Memory Stick PRO Duo Memory Card
Hello Sir.Madam, I have DSC-H10 digital camera. It is having memory of type "Memory Stick Pro Duo". This card was working fine till the day. To transfer images to my PC, I have accessed this card to SD...
Your problem is that you have formatted your MemoryStick from your computer. Your Sony camera uses its own proprietary formatting method and does not understand FAT32. You may also have corrupted your memory card if you didn't click on "safely remove hardware" or by right clicking on the icon of the MemoryStick in the My Computer window and selecting "Eject" from the drop down menu. (This assumes that you have a Windows pc, Macs will have their own way of doing this).
Try reformatting the memory card in the camera itself, this usually solves the issue but if it doesn't then you'll have to replace the MemoryStick.
Good luck, I hope that my reply has been of use and that you are able to save your MemoryStick. I'd be grateful if you would take a moment to rate my answer.
Sep 30, 2010 | Cameras
How do I "see" the Pro Duo card in the Sony HDR-sr12E Handycam on my PC. Can see the hard disks with photos and videos etc but not the card.
The camera is probably configured to record to harddisk now. Select your Pro Duo memorystick as the record media thru the menu's (select the memory stick icon), and you'll be able to see the stick content.
Sep 03, 2010 | Sony HDR-SR12 HDD Camcorder
My laptop cannot read memory stick pro duo 2gb
same problem here The driver is recognized but not opened
Mar 14, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
Memory Stick Pro Duo 8GB on PsP
Two possibilities.
1. The firmware on your PSP is too old to recognise the 8GB (only recognises up to 4GB).
2. If firmware is up to date you have a fake memory stick (easy way to check is to check the info for the memory stick on your PSP if its says that MAGIC GATE is unknown rather than supported then it is fake.
The fake ones typically double compress the data so that it appears to have 8GB when in reality it does not.
Nov 15, 2008 | Sony Memory Stick PRO Duo (2GB) for PSP
Clie T615 not reading memory stick
Either the stick is defective or the wrong format.
May 04, 2017 | Sony CLIE PEG-NX60 Handheld
Memorystick duo
try simply making one named "PHOTO" and place it in the root.
Oct 03, 2007 | Sony PlayStation Portable (PSP) Console
Sony 2GB Memory Stick PRO Duo Memory Card Logo
1,003 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Computer Links
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
