Question about Canon PIXMA MP160 All-In-One InkJet Printer
Canon mp160 paper always feeds skew, can the paper be fed from the bottom instead of the top thanks Peter
Solution obtained on cannon website-paper can only be fed from top(back).This is a common question as the paper tends to feed skew.
Posted on Feb 09, 2010
Canon mp190 pulls paper in right side only
Canon support has info regarding this problem for your model. You must be willing to type in the question:
"Paper feeds skewed" and click <Search> button.
Review the top solutions. I recommend that you clean your feed rollers.
Canon MP190 Feeds Skewed
Dec 20, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Canon Pixma MP470, paper feed not straight
Hi Dave
First thing to check is that the left hand paper guide (as you look at the printer from the front) is up tight against the edge of the paper stack in the feeder. I've seen many printers where (over the course of day to day use) the paper guide has progressively moved itself to the left so that the paper is not held at all. The pick-up for the paper is at the bottom right hand corner and if the guide is loose the paper can skew as it goes in - and then it only gets worse.
Another possibility (and this has just happened to me) is that the long piece of sponge that runs the length of the platen (you'll only see it if you open the top and shine a light in) has come adrift slightly. Mine actually came completely out after 2 or three skewed/crumpled sheets. I washed it, dried it out with kitchen towel and then carefully refitted it. Now the printer is running like a demon.
Let us know what your outcome is.
Dec 06, 2009 | Canon PIXMA MP470 All-in-One Printer
E2 and error 5100
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokio-16
Aug 26, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Printer "grabs" only a corner of the paper, then cannot pull it completly into inside
Also check that the paper guide in the feed tray is tight up against the edge of the paper. If it is not, the paper can skew as it is picked up and then jam on the way in.
Jul 24, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Printer is not feeding the paper through but acts as though it is printing
hi,
prirweto-i-7
Apr 20, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Feeds multiple sheets of paper at once
This usually happens when "paper dust" builds up on the take in rollers. Clean the rollers with cotton and alcohol.
Sep 26, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA MP600 printer - paper feed
Issue: Paper feeds skewed
Solution: Clean The Paper Feed Rollers Using The Operation Panel - MP600
Clean The Paper Feed Rollers Using The Unit's Operation Panel If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit. Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary.
  1. Ensure that the machine is powered on and remove any paper from the auto sheet feeder or the cassette.
  2. Use the <Feed Switch> button to select the paper source where you do the paper feed roller cleaning. Click for here additional information.
  3. Press the <HOME> (A) button.
  4. Use the Easy-Scroll Wheel (B) or press the right / left arrow to select [Settings], then press the <OK> button.
  5. Use the Easy-Scroll Wheel (B) or press the right / left arrow to select [Maintenance], then press <OK>.
  6. Use the Easy-Scroll Wheel (B) or press the up / down arrow to select [Roller cleaning], then press <OK>.
  7. Use the up / down cursor button to select [Yes], then press the <OK> button. (The paper feed roller cleaning starts.)
  8. To check if the rollers are clean, load a sheet of Letter-sized plain paper in the same paper source you selected in step 2.
  9. Use the Easy-Scroll Wheel (B) or press the up / down arrow to select [Roller cleaning], then press <OK>.
  10. Use the up / down cursor button to select [Yes], then press the <OK> button. (Paper will be fed.)
    Note: If paper is not fed properly, repeat steps 4 through 10 above up to three times.
Paper Source
Press the <Feed Switch> button to switch to toggle between the Automatic Sheet Feed (ASF) or Cassette. The light will come on when the <Feed Switch> is set for that paper source.
ASF
The above illustration shows a PIXMA MP500
Cassette
Note: When printing from the computer, if paper does not feed from the source you have selected on the operation panel, check Paper Source setting in the printer driver. If the option is not set to 'Paper Feed Switch', paper will feed from the source selected in the driver.
Click here to return to step 2
May 31, 2008 | Canon PIXMA MP600 all-In-One InkJet...
HP 4250 - always prints askew with left margin at bottom approx 5mm greater than at the top. Any help greatfully received. John
It sounds like the paper is skewing as it is picked up by the roller - watch a sheet go through and see if thst is the case. Make sure the paper guide in the paper tray is pushed solidly to the left edge of the paper and check if it is loose. If it is loose then it might allow the paper to skew as it feeds in
May 09, 2008 | Office Equipment & Supplies
Paper Jams and Margin Incorrect
Check the humidity of your paper, type and weight. Nothing more than 32# will run through the tray, any heavier should go through the bypass to prevent jamming. Margin follow the internal tutorial for moving your margins. Xerox machines do skew 3 degrees left for some reason or the rollars that feed from tray 2 need to be changed.
Peter
Apr 01, 2008 | Xerox Phaser 7750DN Laser Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
368 people viewed this question
old marine
old marine
