Question about Sony Ericsson K800i Cellular Phone
Several keys have stopped working..restarting doesn't help. the toggle has stopped working in the up and right directions too
Black screen when turned onno display
There are several reasons that your Toshiba laptop screen may not come on, even if the laptop appears to be running, and several options you may try to get your screen back up and running without an expensive service call.
Common causes for a blank screen include a backlight that is turned off, a display toggled to an external monitor and improper shutdown errors.
To avoid blank screen errors after your current error is fixed, make sure to follow all instructions in your user's guide to care for your Toshiba computer.
Shine a flashlight directly at your screen and look for an image.
If you see one, this means the backlight on your laptop is off but the screen is still working. This backlight normally turns off only when your screen is closed.
Look for a small metal or plastic pin near one of the screen hinges.
The screen pushes this pin in when it is closed, so if the pin is stuck in the screen closed position, the backlight will remain off.
Tap the pin several times to release it.
You may need to use a small object, such as a pencil tip or straightened paper clip, to reach it on some models.
Monitor Toggle
Press and hold down the "Fn" key if you do not see an image when you use the flashlight.
Tap the "F5" key several times while the "Fn" key is pressed.
This will cycle your screen through the various options that toggle the display to an external monitor.
Attach an external monitor, restart the computer and try this method again if no image appears on the laptop screen.
Click "Start," "Control panel," "Hardware and sound," then "Device manager "using the external monitor if you get an image there but cannot toggle the image back to your LCD.
Select the "Monitor" option to expand your selection and select your LCD monitor from the device list.
Click the "Driver" tab and select "Update" to update the driver, as this error is likely caused by a software driver error.
Force Restart
Press and hold the power button until the computer shuts down completely.
Check the indicator lights at the edge of your laptop to see if the computer is truly off or if it has simply gone into hibernation mode.
If it is off, all lights will be off except the battery-related lights if you have a charger plugged in. In hibernation mode, the power light will blink slowly.
Press the power button to restart the computer again after leaving it off for 15 to 20 seconds. This may fix the problem.
If the blank screen returns or you get a flash of images and then a blank screen, move on to the next step.
Force Power Down
Unplug your laptop from the power source.
Remove the battery by pressing outward on the battery latch and pulling the battery unit completely out of the computer.
Press the power button several times to completely discharge the computer.
Replace the battery and plug the computer back in after about 30 seconds.
Press the power button to turn on the computer.
If you get an error screen upon startup, choose to restart Windows normally.
This error is caused by improper shutdown procedures.
Hope this helps
Nov 14, 2012 | Toshiba Computers & Internet
My toshiba l355d black screen all fans and lights are working
Monitor Toggle
Click "Start," "Control panel," "Hardware and sound," then "Device manager" using the external monitor if you get an image there but cannot toggle the image back to your LCD.
Force Restart
Force Power Down
Hope this helps
Nov 03, 2012 | Toshiba Satellite L355D-S7901 Series...
Laptop is run and start but no display
Monitor Toggle
Force Restart
Force Power Down
Hope this helps
Oct 22, 2012 | Toshiba Satellite A500-ST5608 Laptop DC...
1994 toyata camry the alarm goes off and will not let me start the car.
factory security does not have toggle switches as far as I know so it is probably an aftermarket system. Try one of two things, turn the toggle switch the oposite direction with battery disconnected. Reconnect the battery and try again, the horn will beep a few times when you reconnect. try starting. If that doesn't work, disconnect the battery and turn the key to the on position and reconnect the battery and the horn will sound but will go off get in the car and try to start. It should start and run normally. shut car off, then you should be able to return the toggle switch to the previous position If this happens again turn the toggle switch to the opposite position with the batterry disconnected and turn the key switch to the on position and reconnect the battery and start when started go see a service that installs aftermarket systems and they should be able to reset it security system Hope this helps
Sep 19, 2012 | 1994 Toyota Camry
How to turned off silent mode
With the phone in standby, try pressing and holding the # key on the handset for 5+ seconds. This toggles the silent mode for the D1660 between "always on" and off. If this doesn't help, check the Ringer volume. (This can be set by pressing the volume + button with the phone in standby on some models.)
If this doesn't work, please add a comment with the specific model Uniden DECT 6.0 phone that you have? There are several. Manuals for many Uniden DECT phones are available from their customer support site: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . The manuals are in alphabetical and numerical order.
I hope this helps.
Nov 22, 2011 | Uniden DECT 6.0 Cordless Telephone...
Nothing works keyboard locked ? please help on-screen keyboard only
Hello Friend, Hold shift down both left and right shift key at the same time (do this for several seconds), it somehow solved the problem. Hopefully that fixed the issue. Also, go to control panel, click on accessibility options..in the keyboard tab, click on the settings buttons for sticky keys, filter keys and toggle keys and deselect the option to use shortcut.
Hope this Helped you..Thanks for Using FixYa..
May 08, 2010 | Computers & Internet
Touch Pad and mouse buttons
try it with toggle keys it may be work
May 03, 2017 | Sony VAIO VGN-N130G/W Notebook
My screen is blank and nothing is working
To reset iPod nano:
1 Toggle the Hold switch on and off (slide it to HOLD and then back again).
2 Press and hold the Menu and Center buttons for at least 6 seconds, until the
Apple logo appears.
Mar 15, 2009 | Apple iPod nano
My car stops on motion
several things it could be
alternator replacement
relay is bad
computer going bad
over heat saftey feature thats killing the power so you dont crack your block
make sure your fan is running and hook power to fan direct to an power fuse this is when you turn the key to on the fan starts running you can also add a toggle switch to cooling fan so when in accessory it wont run down battery
your vehicle is equipeted with an electric cooling fan if this shuts off your vehicle over heats and shuts off
this ensures vehicle is always running cool
May 11, 2008 | XO Vision GX1211 XOVision 12" Roof Mount...
Sony Ericsson K800i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
